Multi-tasking problem?: and what about javelin ?
And what about javelin ?
Somebody knows something a bout multi-tasking
and the javelin stamp?
Thanks: Joe
PS: Are them difficult to be programble?
> --- Jon Williams <jwilliams@p...> wrote:
> > Oops... made a mistake. This is better, and I
> added
> > comments.
> > Main:
> > DO
> > FOR idx = 0 TO 4 ' loop through channels
> > IF (timer(idx) = 0) THEN ' if timer
> expired,
> > check sensor
> > IF (sensor(idx) = IsOn) THEN ' sensor
> > active?
> > timer(idx) = TimeDelay ' -- yes, load
> > timer
> > light(idx) = IsOn ' -- yes, turn on
> > light
> > ELSE
> > light(idx) = IsOff ' timer expired,
> kill
> > light output
> > ENDIF
> > ELSE
> > timer(idx) - timer(idx) - 1 ' update this
> > timer
> > ENDIF
> > NEXT
> > PAUSE LoopDelay
> > LOOP
> > END
Original Message
> > From: Jon Williams
> > Sent: Friday, December 12, 2003 10:24 AM
> > To: basicstamps@yahoogroups.com
> > Subject: RE: [noparse][[/noparse]basicstamps] Multi-tasking problem?:
> > need to turn on the
> > lights for 10 seconds while ...
> > This is off the top of my head...
> > Main:
> > DO
> > FOR idx = 0 TO 4
> > light(idx) = IsOn
> > ELSE
> > light(idx) = IsOff
> > ENDIF
> > ELSE
> > timer(idx) = 0
> > ENDIF
> > NEXT
> > PAUSE LoopDelay
> > LOOP
> > END
> > The ideas is to use a small loop delay value (say
> > 100 ms) and run it
> > multiple times (the value of TimeDelay) to create
> > your long pauses.
> > -- Jon Williams
> > -- Applications Engineer, Parallax
> > -- Dallas Office
Original Message
> > From: Joe Terk [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ghDZkPBYwn4IlFXd2I5rKIaJHQAcSR3FpAtXR1xRKCbmJ8rTD6zSWWemvaxC5Do-q8t2gOevrcw]joeterk@y...[/url
> > Sent: Friday, December 12, 2003 10:06 AM
> > Subject: [noparse][[/noparse]basicstamps] Multi-tasking problem?:
> need
> > to turn on the
> > hi,
> > I have 5 human detectors and
> > I need to turn on 5 110volts lights for differents
> > amounts of time (i.e. 10 seconds)
> > But if I place a 10 seconds of pause
> > (i.e. pause 10000) for the first relay
> > to close the circuit for 10 seconds,
> > it will be impossible to detect human
> > using the other 4 sensors.
> > Is it a multi-tasking problem ?.
> > Any help is welcome thanks: Joe
> > __________________________________
> > Do you Yahoo!?
> > New Yahoo! Photos - easier uploading and sharing.
> > http://photos.yahoo.com/
> > To UNSUBSCRIBE, just send mail to:
> > basicstamps-unsubscribe@yahoogroups.com
> > from the same email address that you subscribed.
> > Text in the Subject
> > and Body of the message will be ignored.
> > Your use of Yahoo! Groups is subject to
> > http://docs.yahoo.com/info/terms/
> > This message has been scanned by WebShield. Please
> > report SPAM to
> > abuse@p....
> > Text in the Subject
> > report SPAM to
> > abuse@p....
> > Text in the Subject and Body of the message will
> be
> > ignored.
> Do you Yahoo!?
> Text in the Subject and Body of the message will be
> ignored.
Do you Yahoo!?
Thanks: Joe
> added
> > comments.
> > Main:
> > DO
> expired,
> > check sensor
> > active?
> > timer
> > light
> > ELSE
> kill
> > light output
> > ENDIF
> > ELSE
> > timer
> > ENDIF
> > NEXT
> > PAUSE LoopDelay
> > LOOP
> > END
Original Message
> > From: Jon Williams
> > need to turn on the
> > Main:
> > DO
> > FOR idx = 0 TO 4
> > light(idx) = IsOn
> > ELSE
> > light(idx) = IsOff
> > ENDIF
> > ELSE
> > timer(idx) = 0
> > ENDIF
> > NEXT
> > PAUSE LoopDelay
> > LOOP
> > END
> > 100 ms) and run it
> > your long pauses.
> > -- Jon Williams
> > -- Dallas Office
Original Message
> need
> > to turn on the
> > hi,
> > Do you Yahoo!?
> > Text in the Subject
> > report SPAM to
> > abuse@p....
> > Text in the Subject
> > report SPAM to
> > abuse@p....
> be
> > ignored.
> Do you Yahoo!?
> ignored.
Do you Yahoo!?
timers so the process defined below is a little easier to code with
precision.
-- Jon Williams
-- Dallas Office
Original Message
From: Joe Terk [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=y3xvWJfgvQOYbpSKjsP4ly07xiBS6CfWaT_7ev0pajavR-RSqirxAUeE0ubYITwbPBk-Vh5kDhg]joeterk@y...[/url
Sent: Friday, December 12, 2003 12:54 PM
Subject: [noparse][[/noparse]basicstamps] Multi-tasking problem?: and what about javelin ?
Thanks: Joe
> added
> > comments.
> > Main:
> > DO
channels
> expired,
> > check sensor
> > active?
> > timer
on
> > light
> > ELSE
> kill
> > light output
> > ENDIF
> > ELSE
> > timer
> > ENDIF
> > NEXT
> > PAUSE LoopDelay
> > LOOP
> > END
Original Message
> > From: Jon Williams
> > need to turn on the
> > Main:
> > DO
> > FOR idx = 0 TO 4
> > light(idx) = IsOn
> > ELSE
> > light(idx) = IsOff
> > ENDIF
> > ELSE
> > timer(idx) = 0
> > ENDIF
> > NEXT
> > PAUSE LoopDelay
> > LOOP
> > END
> > 100 ms) and run it
> > your long pauses.
> > -- Jon Williams
> > -- Dallas Office
Original Message
> need
> > to turn on the
> > hi,
> > Do you Yahoo!?
> > Text in the Subject
> > report SPAM to
> > abuse@p....
> > Text in the Subject
> > report SPAM to
> > abuse@p....
> be
> > ignored.
> Do you Yahoo!?
> ignored.
Do you Yahoo!?
from the same email address that you subscribed. Text in the Subject
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
it does implement the Ubicom SX28-ish 'pseudo peripherals'.
These are UARTS, Timers, etc implemented 'inside'
an interrupt service routine. Thus you get a
UART that 'looks' like it's asynchronous, filling
a buffer, which your JAVA code can access when
it wants to.
> Thanks: Joe
> > added
> > > comments.
> > > Main:
> > > DO
through channels
> > expired,
> > > check sensor
> > > active?
> > > timer
turn on
> > > light
> > > ELSE
expired,
> > kill
> > > light output
> > > ENDIF
> > > ELSE
> > > timer
> > > ENDIF
> > > NEXT
> > > PAUSE LoopDelay
> > > LOOP
> > > END
Original Message
> > > From: Jon Williams
> > > need to turn on the
> > > Main:
> > > DO
> > > FOR idx = 0 TO 4
> > > light(idx) = IsOn
> > > ELSE
> > > light(idx) = IsOff
> > > ENDIF
> > > ELSE
> > > timer(idx) = 0
> > > ENDIF
> > > NEXT
> > > PAUSE LoopDelay
> > > LOOP
> > > END
> > > 100 ms) and run it
> > > your long pauses.
> > > -- Jon Williams
> > > -- Dallas Office
Original Message
> > > From: Joe Terk [noparse][[/noparse]mailto:joeterk@y...]
> > need
> > > to turn on the
> > > hi,
> > > Do you Yahoo!?
> > > Text in the Subject
> > > report SPAM to
> > > abuse@p...
> > > Text in the Subject
> > > report SPAM to
> > > abuse@p...
> > be
> > > ignored.
> > Do you Yahoo!?
> > ignored.
> Do you Yahoo!?
