Split a numeric Word into byte, then store it in scratch pad RAM
I'm using the Scratch Pad Ram when passing variables from different
Banks on the BS2p.
I need to pass a numeric word, but the scratch pad only store a byte.
How it is possible to split a word into two bytes, then rebuilt it
in another bank?
Stein.
Banks on the BS2p.
in another bank?
Stein.
PUT spAddr, Word myData
GET spAddr, Word myData
The equivalent in PBASIC 2.0 is this:
PUT spAddr, myData.LOWBYTE
PUT spAddr + 1, myData.HIGHBYTE
GET spAddr, myData.LOWBYTE
GET spAddr + 1, myData.HIGHBYTE
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
eeee….. you forgot to tell that the next address in scratch pad is
affected.
I made this little test program to study the PUT and GET a word
variable affecting the next address:
'{$STAMP BS2p}
'{$PBASIC 2.5}
X VAR Byte
Page VAR Word
x=0
Page=6500 ` try different nr
PUT 3,x
PUT 4,x
PUT 5,x
PUT 6,x
PUT 5, Word Page
GET 3,X[noparse]:D[/noparse]EBUG "3:",DEC X,CR
GET 4,X[noparse]:D[/noparse]EBUG "4:",DEC X,CR
GET 5,Word Page[noparse]:D[/noparse]EBUG "5:",DEC5 Page,CR
GET 6,X[noparse]:D[/noparse]EBUG "6:",DEC X,CR
END
Stein.
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> With PBASIC 2.5 syntax you can PUT and GET Word variables.
> -- Jon Williams
> -- Dallas Office
Original Message
> From:
again.
When using the Word modifier, the low byte of the word is written to (or read
from) the stated address, the high byte is written to (or read from) address +
1. Note that you can even mix and match byte and words:
PUT 0, $00, Word $0201, $03
... will put $00 in address 0, $01 in address 1, $02 in address 2, and $03 in
address 3. Be careful that you don't attempt to write past the end of the
Scratchpad RAM space.
-- Jon Williams
-- Dallas Office
Original Message
