Serial printer EPSON (Wha is the protocol (program) and topology?)
Dear Basic Stamp´s Friends
I would like to know if you have worked in any proyect to controller a
serial printer and parallel printer... Because i need to controller one
Epson printer with this two port, I need to create a board with select to
controller two type printer
One of them is serial, the other is parallel... I don't know what is the
topology and protoicol to controller one printer by serial port... Can you
help me please......
i find in the web yahoo Parallax site one file to controller a parallel
printer, but i don't find the file to controller serial Printer, please help
me about what is the topology and protoicol to controller one printer by
serial port
I appreciate your help and prompt response
Best Regards
Atentamente.
Ing. Damian Trujillo G.
VENPROELEC C.A.
Caracas - Venezuela
) +58-416-8180941
+ familiatrujillo@c...
serial port
Best Regards
Atentamente.
VENPROELEC C.A.
Caracas - Venezuela
) +58-416-8180941
There is no real 'standard', but there are certain
conventions.
1. When the printer is out of paper, or its buffer
is full, it will drop the 'DTR' signal, to say it
is not ready. Your program should monitor this
signal so you don't overrun the buffer.
2. Some printers let you set 'XON/XOFF' (as a
DIP switch setting in the printer). When
this is true, when out of paper, or its buffer
is full, it will send an XOFF character (CTRL-S,
CHR(19)) When it is ready to receive characters
again, it will send an XON (CTRL-Q, CHR(17)).
If you send at 300 baud or so, ANY printer should
be able to keep up.
3. You MUST use a MAX232 or similar driver chip.
Printers want the full +- voltage from RS232.
--- In basicstamps@yahoogroups.com, "Ing. Damian Armando Trujillo G"
controller a
one
select to
is the
Can you
parallel
please help
printer by
> serial port
> Best Regards
> Atentamente.
> VENPROELEC C.A.
> Caracas - Venezuela
> ) +58-416-8180941
only use TX (pin 2), RX (pin 3) and GND.
If you use hardware handshaking, you'll also
need DTR (pin 20).
It depends on the printer if they 'listen' on
TX, or 'talk' on TX. You'll have to verify that.
A simple swap of RX and TX pins will fix that.
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
wrote:
> Serial printers tend to be rare -- but they do exist.
> conventions.
> be able to keep up.
G"
> controller a
controller
> one
> select to
what
> is the
port...
> Can you
> parallel
> please help
> printer by
> > serial port
> > Best Regards
> > Atentamente.
> > VENPROELEC C.A.
> > Caracas - Venezuela
> > ) +58-416-8180941
Thank you for your email... You try to tell me .. that i only need to plane
one MAX232 to conect the two line of the parallax and i only need to use the
command SEROUT..... and use only TX and RX..... I appreciate your help....
Mr... Plaese let me know what is the more easy topology to connect the
parallele printer... I appareciate your help
Best Regards
Atentamente.
RIESE & CIA, S.A.
Caracas - Venezuela
) +58-212-7934266/4377
7 +58-212-7940791/0908
+ dtrujillo_riese@c...
Original Message
Date: Mi
The company I used to work for sold probably 3000+ of the 300 and 300+ in
the last 6 years.
Original Message
conventions.
be able to keep up.
controller a
one
select to
is the
Can you
parallel
please help
printer by
> serial port
> Best Regards
> Atentamente.
> VENPROELEC C.A.
> Caracas - Venezuela
> ) +58-416-8180941
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
