PC to Smoke Machine
Hello,
I am a student at Central Saint Martins School of Art and Design in
London and am currently doing my MA in Interactive Design.
I am currently looking for a way to connect a smoke machine to my PC
and have the smoke machine triggered by some scripting done with
flash mx or lingo.
I am thinking i could connect the PC to a Basic Stamp which will
send the signal to the smoke machine, but i do not have any
experience with this. I would really appreciate any suggestions.
Could you also let me know which Stamp would fit my needs and any
other equipment i would potentially need. Any help would be much
appreciated.
Thanks Again,
Steve.
flash mx or lingo.
appreciated.
Thanks Again,
Steve.
probably hack the switch on the remote control and attach it to a relay,
triac or some such.
On Mon, 1 Dec 2003, minimaforms wrote:
> Hello,
> flash mx or lingo.
> appreciated.
> Thanks Again,
> Steve.
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and Body
of the message will be ignored.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"Do not fear mistakes, There Are None" - Miles Davis
language of Director, right?). If so, the Stamp can accept the commands
and do as you like. I believe the remote switches on smoke machines are
simple arrangements, so you should be able to substitute the
(appropriately rated) contacts of a relay.
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: minimaforms [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=d4m2D0x1MZeaRCiyR9ujMVF5rIHA29DsWd2oqeN-tcVqvwwVV8YGcka0NWk-AoC3gSb0jgdq-RohBNUNzQ]minimaforms@y...[/url
Sent: Monday, December 01, 2003 4:06 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] PC to Smoke Machine
Hello,
flash mx or lingo.
appreciated.
Thanks Again,
Steve.
and Body of the message will be ignored.
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
that the wiring inside is very simple. You should have three wires--
1- ground - this goes to the neon bulb and the switch
1- power for the neon bulb - you should leave this be as on my unit
the neon bulb has two brightness settings - high when the unit is reheating
and low when its ready to generate smoke. I'm not sure on the voltages that
are required to fire a neon bulb, but I think they are high enough not to
play
with.
3 - return to controller
simply unsolder the ground and signal wires from the switch and put them
on the n.o. contacts of a relay or a ssr.
Shawn Lowe
> [noparse][[/noparse]Original Message]
> From: Jon Williams <jwilliams@p...>
> To: <basicstamps@yahoogroups.com>
> Date: 12/1/2003 6:15:42 PM
> Subject: RE: [noparse][[/noparse]basicstamps] PC to Smoke Machine
> I believe you can send serial data via Lingo (Lingo is the programming
> -- Jon Williams
> -- Dallas Office
Original Message
> From: minimaforms [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=IWxnX-AR8hc1VFpxCIKJKz8s6gpwnHLnJk2t0AXYOfeKYhS6jJb22Yb2AnRIFaEfvIkcRsHXrRau4cukmg]minimaforms@y...[/url
> Hello,
> flash mx or lingo.
> appreciated.
> Thanks Again,
> Steve.
> abuse@p....
