Pulsin from r/c receiver
Hi,
I'm having trouble centering my servos, so what I want to do is get
the pulse from my r/c receiver, get my bs2p to read it, make
the "center" value +/- 10ms, and send the same pulse to 4 modified
servos.
Currently, I have 2 control wires from my Hitec receiver from ch. 1
(plugged into P1) and ch. 2 (plugged into P2). 2 servos are
connected to P14 (ch. 1) and the other 2 servos are connected to P15
(ch. 2). I can pulsout the servos, but I'm having trouble with
pulsin.
If anyone knows how to get the pulse from an r/c receiver, please
let me know. The center value for my bs2p is 1795 ms.
Harrison
servos.
pulsin.
Harrison
I'm doing a similar thing with a Robbe Futaba receiver.
My problem was that I did'nt get response on Pulsin, the cause was that the
pulse-voltage from the Futaba was about 3 volts which is not enough for te
Stamp.
My solution is to put in a transistor which amlifies the pulse and also
inverts the signal. No problem, the Stamp can handle a negative Pulsin.
It works fine here, I hope you will find a solution to your problem to.
Klaus
Oorspronkelijk bericht
Van: gizmo_dude_2000 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=cvW8pnI8CuyDtyxGK8DwiZII1LviUk27AptiM0O_DSk6sTHvX6xb3mdyErmh4FjYmg1VxJ7prLsT15Jd9bxw]gizmo_dude_2000@y...[/url
Verzonden: maandag 1 december 2003 2:08
Aan: basicstamps@yahoogroups.com
Onderwerp: [noparse][[/noparse]basicstamps] Pulsin from r/c receiver
Hi,
servos.
pulsin.
Harrison
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
display it on a serial LCD -- check it out and adapt it for your BS2p
(which has better PULSIN and PULSOUT resolution).
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: gizmo_dude_2000 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=77KZR75x7M-mgIV4eQJ7SKio2gMfCZ168GkB0y0O9Rij4CnM2O60BXc70JwIMa0iF4uYwoUOjCrGPjluscBfOHH_Cw]gizmo_dude_2000@y...[/url
Sent: Sunday, November 30, 2003 7:08 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Pulsin from r/c receiver
Hi,
servos.
pulsin.
Harrison
and Body of the message will be ignored.
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
messages. Are you sharing a ground between r/c
receiver and stamp??
Matt
__________________________________
Do you Yahoo!?
Free Pop-Up Blocker - Get it now
http://companion.yahoo.com/
try this.
servo1 var word
loop1:
pulsin pin#, 1, servo1
debug dec servo1,cr
goto loop1
Do you Yahoo!?
