still got a problem
The motors still are not running on the rev D.
heres the code
symbol speed = b1
low 0
high 0
for speed = 0 to 127 step 1
serout 6,N2400, ($80,0,0,speed)
pause 20
next
for speed = 127 to 0 step 1
pause 20
next
serout 6,N2400, ($80,0,1,speed)
pause 20
next
pause 20
next
Do you Yahoo!?
Protect your identity with Yahoo! Mail AddressGuard
heres the code
symbol speed = b1
low 0
high 0
pause 20
next
pause 20
next
pause 20
next
pause 20
next
Do you Yahoo!?
>heres the code
>symbol speed = b1
>low 0
>high 0
> pause 20
>next
>for speed = 127 to 0 step 1 <<-- Change to step -1 as mentioned before
>pause 20
>next
> pause 20
>next
> pause 20
>next
>Do you Yahoo!?
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
not a hardware error. I heard somebody say that when programming the BS1 the
program knows which way to step without having to specify if it is negative. But
so far it hasn't caught on fire.
Bruce Bates <bvbates@u...> wrote:At 08:30 PM 11/28/03 -0800, Kyle
>heres the code
>symbol speed = b1
>low 0
>high 0
> pause 20
>next
>pause 20
>next
> pause 20
>next
> pause 20
>next
>Do you Yahoo!?
from the same email address that you subscribed. Text in the Subject and Body of
Do you Yahoo!?
>I also tried with -1 but still no luck. I'm hoping its a programming
>error and not a hardware error. I heard somebody say that when
>programming the BS1 the program knows which way to step without having to
>specify if it is negative. But so far it hasn't caught on fire.
How about some more specific symptoms, and what you've tried to date ?
Do the motors not run at all ? How have you wired the motors to the
controller ?
What are you using for a power supply for the motors ? Are all the grounds to
all the power supplies connected together somewhere as they should be ? What
kind of motors are these ?
Answers to many of these questions will prove helpful in providing a solution.
Bruce Bates
up to a pololu dual micro motor controller which is hooked up to the BS rev. D.
Everything is wired up correctly and I triple checked it a few times. I have a
9v power supply going to the BS rev. D and 3v to the motors through the motor
controller. The logic supply for the motor controller is 5v from the 5v pin on
the rev. D. sorry I didnt specify any of this and thanks a million for
reminding me.
Bruce Bates <bvbates@u...> wrote:At 09:03 AM 11/29/03 -0800, Kyle
controller ?
Bruce Bates
Do you Yahoo!?
>The motors dont run at all. the motors are two 3v motors. The motors are
>hooked up to a pololu dual micro motor controller which is hooked up to
>the BS rev. D. Everything is wired up correctly and I triple checked it a
>few times. I have a 9v power supply going to the BS rev. D and 3v to the
>motors through the motor controller. The logic supply for the motor
>controller is 5v from the 5v pin on the rev. D. sorry I didnt
>specify any of this and thanks a million for reminding me.
Are the grounds (- side) on the 9 volt battery and 3 volt supply tied
together as they should be ?
Do you Yahoo!?
>yep all the grounds are wired to the ground pin on the microcontroller
Hi Kyle -
Can we presume you got no errors when you complied the test program ?
Where does the wire on Pin 3 of the motor controller go ?
Where does the wire on Pin 2 of the motor controller go ?
Have you checked that Pins 1 and 3 show a voltage present between them ?
Have you checked the voltage status of the 9 volt battery recently ?
Let's see how far we get with these answers in hand.
Bruce Bates
Bruce Bates <bvbates@u...> wrote:At 09:29 AM 11/30/03 -0800, Kyle
Hi Kyle -
Bruce Bates
Do you Yahoo!?
>did all of it.
Kyle -
I asked 5 specific questions, and got no specific answers. I'm not sure how
to interpret your response. I await your specific answers to my questions
if you
need more help.
Bruce Bates
>Hi Kyle -
>Bruce Bates
>Do you Yahoo!?
supply,pin 2 goes to ground,there is a voltage present between pins 1 and 3,the
9v battery is fully charged.
At 03:25 PM 11/30/03 -0800, Kyle Cooper wrote:
>did all of it.
Kyle -
if you
need more help.
Bruce Bates
>Bruce Bates wrote:At 09:29 AM 11/30/03 -0800,
>Hi Kyle -
>Bruce Bates
>Do you Yahoo!?
Do you Yahoo!?
