Averaging numbers...
Hello Stampers,
Is there an easy way to average large word numbers?. For example, I wish to
average 62319 and 62323, which averages at 62321. I cant add them together
obviously.
Is there a way to "and" them together or something ?
I would like to average a list of 10 words this way.
Cheers,
Chris Anderson
Sunny Western Australia
obviously.
Cheers,
Chris Anderson
fuel@b... writes:
> obviously.
How accurate do you have to be? You could divide each number by 2, get your
average, the double your result. Your average would be off by 1, I think.
Sid Weaver
W4EKQ
Port Richey, FL
question... Its 5:40 AM here, I shouldnt have gotten up so early.
Thankyou very much...
Cheers,
Chris
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Friday, November 28, 2003 5:34 AM
Subject: Re: [noparse][[/noparse]basicstamps] Averaging numbers...
> In a message dated 11/27/2003 4:27:36 PM Eastern Standard Time,
> fuel@b... writes:
to
together
> > obviously.
your
> Sid Weaver
> W4EKQ
> Port Richey, FL
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
fuel@b... writes:
> That is such a stupidly simple answer, that I am embarrassed I asked the
No problem, Chris. Anything for a cobber.
Sid
An average is also N value each divided by N, then summed, but has the
advantage that the largest computed number is always less than the largest
value.
As you are dealing with integer numbers, to be entirely accurate you should
multiply the result by 1.005 to account for the fractional portion of the
number that was dropped during the integer divide.
Original Message
Sent: Thursday, November 27, 2003 1:34 PM
> fuel@b... writes:
to
together
> > obviously.
your
> Sid Weaver
> W4EKQ
> Port Richey, FL
can divide the two numbers first by two, then add them. so (62319/2)+
(62323/2)=62321
Chris Schur
--- In basicstamps@yahoogroups.com, "Chris Anderson" <fuel@b...>
wrote:
> Hello Stampers,
wish to
together
> obviously.
> Cheers,
> Chris Anderson
average of 100 & 200 is 150
average of 50 & 100 is 75 and 75 times 2 is 150.......
Hello Stampers,
obviously.
of numbers is the sum of N numbers divided by N.
>obviously.
>Cheers,
>Chris Anderson
Another way to do this, when all the numbers are close together, is
to work with the differences instead of the absolute numbers. For
example, take 62319 and 62323. The difference is 62323-62319 = 4.
Divide that by 2. You get 2. Add 2 to 62319. You get 62321, which
is the average. Or subtract 2 from 62323, same difference.
The algebra for two numbers goes like this:
(A+B)/2
= {A+A+(B-A)}/2
= A +(B-A)/2
In general (B-A)/2 could be either positive or negative, which just
means you end up either adding or subtracting from A, depending on
whether A>B or vice versa.
The same algebra applies to a long list of numbers:
(A+B+C+D+E+F+G+H+I+J)/10
= {N*A +(B-A)+(C-A)+(D-A)+...+(J-A)}/10
= A + {(B-A)+(C-A)+(D-A)+...+(J-A)}/10
On a microprocessor, the value A is the first one acquired, or it may
be the average from previous readings, or, it really doesn't matter
how you choose A, so long as the sum of the differences remains
small. If the sample values are close to one another and to the
initial value A, then the magnitude of the sum of the differences
will not grow very fast. The numbers do have to be treated as twos
complement values, but that is really no restriction at all. You do
have to be careful on the stamp to respect the sign of the
accumulation when you do the division at the end. Here is an example
average of 10 numbers...
result Var word ' randomized process variable
A Var word ' initial value
Acc Var word ' difference accumulator
i Var nib
average Var word
GOSUB getvalue ' get initial value A
A = result
DO
Acc = 0
FOR i=1 to 9 ' get 9 more samples
gosub getvalue
Acc = (result - A) + Acc ' accumulate differences
NEXT
average = A + (-Acc.bit15^(ABS Acc/10)+1)
IF Acc.bit15 THEN ' respect the sign, bit 15 of Acc
average = A - (ABS Acc / 10) ' negative
ELSE
average = A + (Acc / 10) ' positive
ENDIF
debug ? average ' show it
A = average ' make this the first sample of the next round
LOOP
It is also possible to do the average using double precision. That
is, you would add numbers like 62323 and 62319 together directly and
generate a carry to a high word. At the end, a double precision
division is necessary, but it is not really that hard if the number
of samples is less than 256.
result Var word
Acc0 Var word ' accumulator low word
Acc1 Var byte ' accumulator high byte (less than 256 samples)
i Var byte
average Var word
N Con 10 ' this many samples (N<256)
DO
Acc0 = 0 ' init accumulators
Acc1= 0
FOR i=1 to N ' get N samples
gosub getvalue
Acc0 = result + Acc0
IF Acc0<result THEN Acc1=Acc1+1 ' carry
NEXT
i = Acc1//N ' temporary value
Acc1 = 65535//N*i//N+i+(Acc0//N) ' temporary
average = 65535/N*i+(65535//N*i/N)+(Acc0/N)+(Acc1/N) 'final
LOOP
If the number of samples is fixed at N=10, then some terms in the
double precision division formula can be precomputed. More info
about that, and where the heck that division formula comes from, at
<http://www.emesystems.com/BS2math6.htm>.
-- Tracy
*division*
r0=n1//dv ' remainder from high word
q1=65535//dv*r0//dv+r0+(n0//dv) ' temporary computation
q0=65535/dv*r0+(65535//dv*r0/dv)+(n0/dv)+(q1/dv) ' low
word of quotient
r0=q1//dv ' final remainder
q1=n1/dv ' high word of quotient
*end of division*
accumulation, one using computed logic:
> average = A + (-Acc.bit15^(ABS Acc/10)+1) '<--see below
and the other using IF-THEN logic:
> ELSE
> ENDIF
I put both of them in the program, because I started with the
computed one, and then decided the IF-THEN version was more
transparent, to see what is going on. then forgot to take the first
one out.
Anyway, the computed one should read like this, not as above:
average = A + (-Acc.bit15^(ABS Acc/10)+Acc.bit15)
The computed version divides the absolute value of the number by 10, and
then either makes it negative or leaves it positive, depending on the
value of the sign bit, Acc.bit15.
-- Tracy
each (halving them), and then add?
On Nov 27, 2003, at 4:23 PM, Chris Anderson wrote:
> Hello Stampers,
> wish to
> together
> obviously.
> Cheers,
> Chris Anderson
> and Body of the message will be ignored.
Suppose the numbers are 101 and 99. The average is clearly 100.
However, the integer math of the Stamp comes up with,
average= (101/2)+(99/2) ' = 50+49=99
Not far off. But the problem is the remainders that were dropped.
The stamp can pick up the sum of the remainders, too, and make the
correction:
average= (101/2)+(99/2)+((101//2)+(99//2)/2) ' = 50 + 49 + ((1+1)/2) = 100
The // operator gives the remainder after the division by 2.
Chris said he needed a list of 10 numbers. If you change
average= (A+B+C+D+E+F+G+H+I+J)/10
into
average=(A/10)+(B/10)+(C/10)+(D/10)+(E/10)+(F/10)+(G/10)+(H/10)+(I/10)
+(J/10)
you would get the correct answer on a hand calculator, but the error
due to integer rounding on the Stamp could get to be quite serious.
It could be off by as much as 90. Again in this case you could make
a correction by also adding up the remainders and dividing their sum
by 10.
average=
(A/10)+(B/10)+(C/10)+(D/10)+(E/10)+(F/10)+(G/10)+(H/10)+(I/10)+(J/10)
+ (((A//10)+(B//10)+(C//10)+(D//10)+(E//10)+(F//10)+(G
//10)+(H//10)+(I//10)+(J /10))/10)
The second line is the sum of the remainders (// operator), divided
by 10 at the end. There are so many ways to go about this!
-- Tracy
>> Hello Stampers,
>> wish to
>> together
>> obviously.
>> Cheers,
>> Chris Anderson
rolloevers -- is to divide first. You must, of course, know the number
of samples in order to do this.
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: Chris Anderson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=OscrqZPXiqG59Cx9RtfR6neDpXqlG1z7b_FgR6KoMerkrRZuaOb-rGybCOh1Qqeq-o-pm5D5mnpqM8vDmC8]fuel@b...[/url
Sent: Thursday, November 27, 2003 3:24 PM
To: Stamp Group
Subject: [noparse][[/noparse]basicstamps] Averaging numbers...
Hello Stampers,
to average 62319 and 62323, which averages at 62321. I cant add them
together obviously.
Cheers,
Chris Anderson
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
to all of you.
My application doesnt mind if I am out by 1 at the end of averaging the
numbers, as the numbers will vary by a reasonable amount anyway. But its
good to get answers which will make the answer accurate.
Thanks again everyone, I'll go thru them and work out which method will suit
my application best, which is fluid level measurement with a pressure
sensor. Because I am using a 12 bit ADC, the measurements vary slightly with
very small voltage changes, and I therefore need to take a few samples and
then average them.
Cheers,
Chris Anderson
Western Australia
Original Message
Sent: Saturday, November 29, 2003 6:30 AM
Subject: RE: [noparse][[/noparse]basicstamps] Averaging numbers...
> One way to do it -- that is not without error, but will prevent
> -- Jon Williams
> -- Dallas Office
Original Message
> From: Chris Anderson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=N31qx1G7i5BlqmkQTYVJ9p4PGd9GNtsuMlV-M8EhvZzJehzIIK9JkRjCigYbqYrbkiF5D6_a4by0DuU]fuel@b...[/url
> To: Stamp Group
> Hello Stampers,
> together obviously.
> Cheers,
> Chris Anderson
> abuse@p....
possible rollover error occurs ($FFFF / $FFF = 16). This is probably
more samples than you need for your process so in the end, there are no
worries mate.
-- Jon Williams
-- Dallas Office
Original Message
From: Chris Anderson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-EgIARUSXuTfI_gZC3E77J7pvjvchuP_xZC98_Q2G3GehDpXAi3RfpmGyZtFj4YgNh2qG-dbbGeoIF_k99Y]fuel@b...[/url
Sent: Friday, November 28, 2003 7:25 PM
To: basicstamps@yahoogroups.com
Gee, I'm a bit overwhelmed with all the information coming in, thanks
heaps to all of you.
suit my application best, which is fluid level measurement with a
pressure sensor. Because I am using a 12 bit ADC, the measurements vary
slightly with very small voltage changes, and I therefore need to take a
few samples and then average them.
Cheers,
Chris Anderson
Western Australia
Original Message
> number of samples in order to do this.
> -- Jon Williams
> -- Dallas Office
Original Message
> To: Stamp Group
> Hello Stampers,
> wish to average 62319 and 62323, which averages at 62321. I cant add
> them together obviously.
> Cheers,
> Chris Anderson
> abuse@p....
> and
abuse@p....
(A+B)/2 = (A/2) + (B/2)
or, basically, 62319/2 plus. 62321/2. Unfortunately, since you're dealing
with integer math, you'll have to fake the .5's. In this example, you're
always dropping a .5 if the number is odd, so you could do something like
detect if the numbers are even or odd (using modulus). If there are zero
odd numbers, it's accurate. If there are one, it's .5. if there are two,
you'd have to add +1 to the amount. Of course, the fundamental problem is
you're dealing with a possible decimal value within integer space.
On Fri, 28 Nov 2003, Chris Anderson wrote:
> Hello Stampers,
> obviously.
> Cheers,
> Chris Anderson
> from the same email address that you subscribed. Text in the Subject and Body
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"Do not fear mistakes, There Are None" - Miles Davis
