newbie question about wiring for phototcell
could any one tell me how to wire a cadmium photocell, i've
looked at several web sites and books and i have seen different
ways to do this but i can't seem to get it to work. any help would
be appreciated. thanks in advance.
RCTime command in the Stamp manual and hook up the CdS cell as though it
were a variable resistor. Then use RCTime to read the value of the cell.
If you want an on/off you can then compare the value from RCTime against a
threshold.
There are ways to make it a digital output, but RCTime would be easier.
Hope that helps.
Al Williams
AWC
* Easy RS232 Prototyping: http://www.al-williams.com/rs1.htm
Original Message
> From: jsteff74 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=TOwLOgfutHwTvw4J7nTW3f9RBLAJziNHUeJH0s79pgOpB7SaPxOiVNbU2tXbbgEEuaiR4AKR-7n7ldMF]jsteff74@y...[/url
> Sent: Wednesday, November 26, 2003 6:46 PM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] newbie question about wiring for phototcell
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the
> Subject and Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
A cadmium photocell is basically a variable resistor that
changes it's resistance according to light levels. It's often
wired as half of a voltage divider or sometimes a current
limiter... so there are various ways to use it depending on what
you want to do. You could use it as a voltage divider and
measure '1' or '0' directly at a stamp pin, or add an ADC and
measure a finer granularity, or even use it to charge a cap and
measure that with RCTIME - just depends on exactly what you want
to do.
Michael
thanks for the help. i used the wiring diagram in the
book and instead of getting a reading for the light in
the room, i get a reading of 1. that number only
increases if i touch the photocell. it does not
respond to changes in the ambient light. do you know
what might be causing this? i tried downloading the
rctime program to two different bs2 and i get the same
results. i have to admit that i have limited knowledge
about most of this, i am an artist and i am trying to
learn as i go. so thanks again for your help.
jared
--- Al Williams <alw@a...> wrote:
> There are many possible ways. One nice way with the
> Stamp is to look at the
> threshold.
> Hope that helps.
> Regards,
> Al Williams
> AWC
Original Message
> > From: jsteff74 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=nQFdlIqjX1DEf7X_vvXiFtNGHpmVNqVFqwUuoYaUmuG4UdF7zepwQmKmw96u9OqxG179i-lVAvw]jsteff74@y...[/url
> photocell, i've
> seen different
> Text in the
> Text in the Subject and Body of the message will be
> ignored.
__________________________________
Do you Yahoo!?
Free Pop-Up Blocker - Get it now
http://companion.yahoo.com/
