Aux Power Supply Switching
hello,
I'd like to power my stamp with a 9volt battery going into a 7805 regulator, but
also have an auxiliary power input so I can bring power in from a 12v DC wall
wart or battery. Is there a way to hook up a transistor, or some sort of
super-fast switch, that would disconnect the 9v battery and switch to external
power when external power is supplied; without power interruption to the stamp?
I've been perplexed by this for a while. I found that Linear has a chip
(LTC4412) made to do this, but it is in an impossibly small sized surface mount
package so I can't use it.
Stewart
Stewart
If I understand you corectly, all you need to do is use a diode in series
with the battery, say a 1N4004. This will allow the battery to run when
required, and prevent the 12V supply from charging/exploding the battery.
Jonathan
www.madlabs.info
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Wednesday, November 26, 2003 1:56 PM
Subject: [noparse][[/noparse]basicstamps] Aux Power Supply Switching
> hello,
regulator, but
wall
external
stamp?
mount
> Thanks,
> Stewart
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
regulator, but
wall
external
stamp?
Lots of power jacks have provision to disconnect an internal power supply
when you insert the jack. There will be a few ms when you put the jack in,
when neither power supply is available, but if you put a capacitor across
the input power leads to the 7805, that will supply enough power to run
things for those few ms, as well as smoothing out any power noise from
inserting ther jack. It will also increase the drain on the battery a bit,
so it may not be a perfect solution. Depending on load, you probably don't
need much: a 12v 100 mf cap might be plenty. The only downside is that when
you remove all power, the circuit will stay live for some amount of time, as
the cap drains.
There are probably tricks you could do with diodes and resistors to make the
battery more slowly charge the cap, thus decreasing overall drain on the
battery. That's something to experiment with.
But Scott posted putting a '100mf cap' across a connection point....
I'm almost SURE what you mean....but want to clarify.
Do you mean 100uF (microFarad) or 100mF (milliFarad). I don't recall having
seen a 'milliFarad' cap, but would assume they are HUGE!!
sb
Original Message
From: Scott [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=M7FR_Bm4YRjxgh2LWQZDtSoA529Y_n0KJdtXZPgvsBdiaH_V-6EYv_mrTOIxSW27UES9pOOFDGLIzg]scott@m...[/url
Sent: November 27, 2003 7:42 AM
To: basicstamps@yahoogroups.com
regulator, but
> DC
wall
> of super-fast switch, that would disconnect the 9v battery and switch
> to
external
> the
stamp?
the cap drains.
diameter and 1/4" high :-))))))))))).
They are used as a backup 'battery' in some electronic devices.
Klaus
Oorspronkelijk bericht
Van: Brady,Steven [noparse]/noparse]PYR] [noparse][[/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=SXoFLkreCz415GjRldHZe6Q4NFG1kvli0dVAAlFHGsIigTYo7zLJj-FHnFkEvFTcthRz5TukdX768GTXa4E]steven.brady2@e...[/url
Verzonden: donderdag 27 november 2003 16:55
Aan: 'basicstamps@yahoogroups.com'
Onderwerp: RE: [noparse][[/noparse]basicstamps] Aux Power Supply Switching
Sorry to go a little OT here....
sb
Original Message
From: Scott [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Od1QJeC3wntWtnTxf-WGV9X1Gja1nMRrt8hoIKzPQrR5N-p43_icBoB16iUgZRMIgCr7m_G1QTH5]scott@m...[/url
regulator, but
> DC
wall
> to
external
> the
stamp?
the cap drains.
for mF or do they actually mean 'milli'Farad?!
Original Message
From: K de Jong [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_cq2eXP3STGMXo9mURHtLFl9cTFRQHUzPOrqGJp0dI1aXq-UNhBAMdJwymzXDkz5IJsVvPAb-YwnekK2VLD2]Klaus.Jong@n...[/url
Sent: November 27, 2003 12:46
Subject: RE: [noparse][[/noparse]basicstamps] Aux Power Supply Switching
I'm the proud owner of a capacitor of 1 Farad at 5 V !!, it is only about 1"
Klaus
Van: Brady,Steven [noparse]/noparse]PYR] [noparse][[/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=fnLSlZM4GgcG4BgA1DLpG-RhSeU8YGpiTH3HuhqSzb3GL3aiE4-O6w1M2pPTBdnfayeL4cfLegR72Y5rYA]steven.brady2@e...[/url
sb
Original Message
From: Scott [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=uXoeSycyPAJ1zl6NNukfWWboQSPgEjkzCWXd4NaGDLuaT8aaRkxREYvd5AdQ-WKe6pPKrsUDO9wh3Q]scott@m...[/url
regulator, but
> DC
wall
> to
external
> the
stamp?
the cap drains.
there still be some current used from the 9volt battery, or will all the
current only come from the higher voltage source? Also, isn't there some
voltage loss across diodes?
The capacitor also sounds good, but i'm worried about the leakage eating
up battery power over time. Am I correct in assuming a larger capaciter
will leak more current?
I've been thinking of hooking up a transistor triggered by the 12v supply
to disconnect the 9v. I don't know if this would cause a voltage drop also.
Perhaps I should just experiment, hmmmm.
Stewart
>-- Original Message --
>From: "Jonathan Peakall" <jpeakall@p...>
>Date: Wed, 26 Nov 2003 18:50:44 -0800
>Subject: Re: [noparse][[/noparse]basicstamps] Aux Power Supply Switching
>Reply-To: basicstamps@yahoogroups.com
>Stewart,
>Jonathan
>www.madlabs.info
Original Message
>From: "Stewart Mayer" <stamplist@k...>
>> hello,
>regulator, but
DC
>wall
>of
>external
the
>stamp?
>mount
>> Thanks,
>> Stewart
and
reverse bias, so there will be many millions of ohms in series provided by
PN junction. In that case the current going to the battery will be almost
nothing (for all practical purposes, this will be zero draw, but there's
always SOME leakage - in this case the wrong direction, but certainly not
enough to charge the battery in any way). You'll probably want to add a
diode in series with the wall wart as well so the battery doesn't try to
power the wart if it's disconnected from the 120 VAC line, but still plugged
into the stamp.
As far as voltage drops across diodes go, for silicon PN junctions, it's
around 1/2 volt or so (typically 0.6 volts), and for germanium PN junctions
it's about 1/4 volt (typically 0.2 volts or so). Most diodes you'll use will
be silicon, so figure around 8.4 volts getting to the Stamp from the battery
supply, and 11.4 volts from the wall wart supply.
I think this is a very simple and elegant "backup" solution.
Mike Sokol
www.modernrecording.com
mikes@m...
" One should not increase, beyond what is necessary,
the number of entities required to explain anything"...
-William of Occam-
Original Message
Sent: Friday, November 28, 2003 1:36 PM
> That sounds good. If both supplies are hooked up at the same time, will
also.
> Thanks,
> Stewart
> >Stewart,
> >Jonathan
> >www.madlabs.info
Original Message
> >> hello,
> >regulator, but
> DC
> >wall
> >of
> >external
> the
> >stamp?
chip
surface
> >mount
> >> Thanks,
> >> Stewart
> and
Thanks for the thorough answer, I'll definately go with the diodes, and
the input capacitor on the 7805 should be able to absorb any bumps when
switching inputs.
I hope everyone enjoys the holiday weekend!
Stewart
>From: "Mike Sokol" <mike.sokol@m...>
>Date: Fri, 28 Nov 2003 14:02:07 -0500
>When the 12 volt power supply is on, the diode on the battery will be in
by
>into the stamp.
will
>Mike Sokol
>mikes@m...
Atomic clock reciver, because my power goes out all the time. The battery
that is in there is 6 months old, and is fine.
Jonathan
Original Message
Sent: Friday, November 28, 2003 10:36 AM
also.
> Thanks,
> Stewart
> >Stewart,
> >Jonathan
> >www.madlabs.info
Original Message
> >> hello,
> >regulator, but
> DC
> >wall
> >of
> >external
> the
> >stamp?
chip
surface
> >mount
> >> Thanks,
> >> Stewart
> and
inrush current when charging by using a resistor in series with the power
supply when charging. High currents on charging can damage them internally!
jim
http://www.geocities.com/jimforkin2003/
Original Message
From: Brady,Steven [noparse]/noparse]PYR] [noparse][[/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=4nMhGtNXSdo7hCHoADPWqYjU21QLh4fwSuDhSgNoG_HnDApEL-cAdUbIwqTXYYORQR32eZ_FCsF0ZP1TGhmhCvk]steven.brady2@e...[/url
Sent: Thursday, November 27, 2003 4:09 PM
To: 'basicstamps@yahoogroups.com'
Fantastic....but still. Are ppl using the first letter of the word micro
Original Message
From: K de Jong [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=zxnpRxQWmm4mXufmir-G3MNzaVV-DF3bca7N3fM4u0stchHREG2eiNr9EspIJOxjWA6qm74oALqJUlg]Klaus.Jong@n...[/url
Klaus
Van: Brady,Steven [noparse]/noparse]PYR] [noparse][[/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=4nMhGtNXSdo7hCHoADPWqYjU21QLh4fwSuDhSgNoG_HnDApEL-cAdUbIwqTXYYORQR32eZ_FCsF0ZP1TGhmhCvk]steven.brady2@e...[/url
sb
Original Message
From: Scott [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=t8hSGUry6YFid7A1ilGBBZ5N9-99i6D3SIsF1G7jsuLe27R3Tro8-6im4r8lqTw66X2_uRIt2xD9]scott@m...[/url
regulator, but
> DC
wall
> to
external
> the
stamp?
the cap drains.
