EQ parts
Hi.
I'm looking for a component (IC or audio component) that can be fed
standard line-level audio signals and will "split" these into multi-band
(7-20) voltages on the output side. Think equalizer. The ultimate device
will feed out 10 or so separate voltages which will be brought into
LM3914 bar graph controllers for output to a multi-segment multi-band
audio display.
I may just buy an old display EQ on ebay, but I'm wondering if there's an
IC-based solution to this?
Sean T. Lamont, Chief Mad Scientist |-- lamont@a...
Zen Chemical Productions |-- http://www.zenchemical.com
Fabricators of Unnecessary Amazement
audio display.
you this. Is this the right approach? Or are there
more 'fixed' band circuits that do this commercially?
--- In basicstamps@yahoogroups.com, "Sean T. Lamont .lost."
<lamont@a...> wrote:
> Hi.
band
device
band
> audio display.
there's an
to make this happen on screen, but I would bet a nickel that a Basic Stamp
doesn't have enough horsepower to manage those calculation in real-time,
plus drive a bunch of displays. Of course, you could build a bunch of
band-pass filters (the old analog way) but that seems to be rather complex
for what you're trying to do.
Is there a new stamp coming out with that sort of power? Certainly would be
fun to play with...
Mike Sokol
www.modernrecording.com
mikes@m...
" One should not increase, beyond what is necessary,
the number of entities required to explain anything"...
-William of Occam-
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Saturday, November 22, 2003 3:20 PM
Subject: [noparse][[/noparse]basicstamps] Re: EQ parts
> I believe a Fast Fourier Transform (FFT) would give
> > Hi.
> band
> device
> band
> > audio display.
> there's an
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
The NJU7507, NJU7508 and NJU7508 from NJR do approximately what you
want, but getting ahold of one could be a problem. I'd like to know
if there are other similar chips out there.
"Band pass filter for audio spectrum analyzer display". It has an
analog output for each of 7 to 14 frequency bands, centered from
about 16khz down to about 40 hz. Internally it is a switched
capacitor multi band pass circuit clocked at 400khz.
The '7502 is an 8-pin chip and uses mux scheme for the output.
There is one audio input pin and one analog output that you feed into
an analog to digital converter. The output steps through the DC
level for each band in turn, dwelling for about one millisecond on
each channel, so you would need a sample and hold or something like
that to use it with a Stamp. The '7508 and' 7509 are dual channel
for stereo.
-- Tracy
>band
>device
>band
>> audio display.
>there's an
