Understanding SERin/SERout commands, need help bad!
I was reading a articl on how to send serial communications between
stamp's , i have a appilicaton where i want to have one stamp running
its own loop based on a trigger, and the second stamp gather sensor
data and serial out the gather information into the other stamp to be
used.... hear is a program i writen, tell me if there is any flaw's
on it, currently i have not tried it on two stamp 2's because i only
have access to one right now.... i want to be able to send the serial
data as fast as poosible with the lowest latency...
program 1 **** this program runs the senor gathering and performs a
lookup to get the correct value for the serial inofmration that will
be outputed to the other stamp...
'{$STAMP BS2}
'{$PBASIC 2.5}
TB_POS VAR NIB
PULSE_WIDTH VAR WORD
X0 CON 1000
X1 CON 1100
X2 CON 1200
X3 CON 1300
X4 CON 1400
X5 CON 1500
X6 CON 1600
X7 CON 1700
MAIN:
HIGH 1 'used for ADC
LOW 1 'used for ADC
SHIFTIN 2,0,MSBPOST,[noparse][[/noparse]TB_POS\3] 'ADC value updated...
LOOKUP TB_POS ,[noparse][[/noparse]x0,x1,x2,x3,x4,x5,x6,x7],PULSE_WIDTH 'the
pulse_width variable is updated...
SEROUT 1\0, 16468, [noparse][[/noparse]PULSE_WIDTH] ' send updated pulse_width value
to second stamp..
GOTO MAIN: ' loop over and over...
program 2 ****
'{$STAMP BS2}
'{$PBASIC 2.5}
INPUT 14
INPUT 13
INPUT 10
OUTPUT 12
OUTPUT 11
BOOTUP:
IF IN14 = 0 THEN STUCK
GOTO MAIN
STUCK:
GOTO MAIN
INJECT1:
PULSOUT 12, PULSE_WIDTH
IF IN14 = 0 THEN MAIN2
GOTO MAIN3
INJECT2:
PULSOUT 11, PULSE_WIDTH
IF IN13 = 0 THEN MAIN4
GOTO MAIN
MAIN: '*** main program area
SERIN 1\0, 16468, [noparse][[/noparse]PULSE_WIDTH] 'receave pulse_width value from
the first stamp 2
IF IN14 = 0 THEN INJECT1 ' in condition is true, perform rest of
the program, if false, loop over agian to receave the pulse_width
from first stamp...
GOTO MAIN ' loop over agian and agian....
MAIN2:
GOTO MAIN3
MAIN3:
IF IN13 = 0 THEN INJECT2
GOTO MAIN3
MAIN4:
GOTO MAIN
***** end of program... as you see in theory it looks nice and
fruity, but my application is time critical, with the inputs on the
second stamp being triggered around 80~120 cycles a second , i cant
have the serin command take long and not beable to reconize the
input's are being triggered while its reading the serial data....
Sean...
'{$STAMP BS2}
'{$PBASIC 2.5}
TB_POS VAR NIB
X0 CON 1000
X1 CON 1100
X2 CON 1200
X3 CON 1300
X4 CON 1400
X5 CON 1500
X6 CON 1600
X7 CON 1700
MAIN:
LOW 1 'used for ADC
to second stamp..
program 2 ****
'{$STAMP BS2}
'{$PBASIC 2.5}
INPUT 14
INPUT 13
INPUT 10
OUTPUT 12
OUTPUT 11
BOOTUP:
GOTO MAIN
STUCK:
GOTO MAIN
INJECT1:
GOTO MAIN3
INJECT2:
GOTO MAIN
the first stamp 2
from first stamp...
MAIN2:
GOTO MAIN3
MAIN3:
GOTO MAIN3
MAIN4:
GOTO MAIN
Sean...
The syntax you posted for master/slave connection with handshake
between two stamps is correct.
to
>the first stamp 2
You might think about a timeout on the SERIN side. That would let
the time-critical task continue even if the SEROUT measurement is not
ready for any reason whatsoever, such as being out of sync, or for
more malignant reasons such as a broken cable or broken sensor.
SERIN 1\0, 16468, 2, continue, [noparse][[/noparse]PULSE_WIDTH] 'receive pulse_width
value from the first stamp 2
With that, if the SEROUT side is not there waiting when the SERIN
side hits that command, the SERIN side will only wait around for 1
millisecond before it jumps to the label "continue". (Note there is
a off-by-one "bug" in the SERIN timeout parameter, so you have to put
a 2 there to get a one millisecond delay).
-- Tracy
http://www.emesystems.com
>'{$STAMP BS2}
>'{$PBASIC 2.5}
>TB_POS VAR NIB
>X0 CON 1000
>X1 CON 1100
>X2 CON 1200
>X3 CON 1300
>X4 CON 1400
>X5 CON 1500
>X6 CON 1600
>X7 CON 1700
>MAIN:
> LOW 1 'used for ADC
>to second stamp..
>program 2 ****
>'{$STAMP BS2}
>'{$PBASIC 2.5}
>INPUT 14
>INPUT 13
>INPUT 10
>OUTPUT 12
>OUTPUT 11
>BOOTUP:
> GOTO MAIN
>STUCK:
> GOTO MAIN
>INJECT1:
> GOTO MAIN3
>INJECT2:
> GOTO MAIN
>the first stamp 2
>from first stamp...
>MAIN2:
> GOTO MAIN3
>MAIN3:
> GOTO MAIN3
>MAIN4:
> GOTO MAIN
>Sean...
