Reset pin bypassing
I have solved several noise problems with my project (many thanks to all who
responded!!), but am somewhat worried about the reset pin. Do I need to
pull it up with a 1 kOhm resistor to help with noise, or is it pretty much
immune to noise?
immune to noise?
I think it is pretty much immune to noise. Proper shielding/housing
and GND layout practice is advised however.
regards
Adrian
going back over it after it was built<G>.
Understand ground layout<G>, we pulse at up to 800 Amps around here<G>.
Many thanks!!
Original Message
From: Adrian Schneider [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9jCzETpxCF_ZOrxebxhZifdk0qbLa0AQksHcaWvUP59rcZhhiw1atU13sEA94-0bWCIcFQo6PAHKz9Jgx8rTSnTHE9Zh]adrian.schneider@t...[/url
Sent: Tuesday, November 18, 2003 7:18 AM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Re: Reset pin bypassing
The RES pin is internally pulled up by a 10k resistor, thus
I think it is pretty much immune to noise. Proper shielding/housing and GND
regards
Adrian
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
