P40 Demo Board - Accessing Sout Sin
I just got my P40 demo board from parallax, awesome little bugger,
but how do I access the Sout/Sin pins? All of the output pins seem
to be brought out to convinent little blocks for jumping, but not
Sout/Sin?
Am I missing the obvious?
Any help appreciated.
-John
Sout/Sin?
-John
>Sout/Sin?
>-John
John -
Sin and Sout should appear on the DB9-F programming port connector. You can use
any pin/port you choose to for Serin and Serout however. You are not
restricted
to Sin and Sout although they are level adjusted for RS-232 communications.
Note
also that Sin/Sout will echo data back to the sender. If necessary for your
application, the echoed data may have to be discarded.
Bruce Bates
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
You can use any pin/port you choose to for Serin and Serout however.
You are not restricted to Sin and Sout although they are level
Note also that Sin/Sout will echo data back to the sender. If
necessary for your application, the echoed data may have to be
discarded."
Thanks for the reply Bruce.
So I can use any pin for serial communications, that helps. If I
did want to use sin/sout pins what do I do, program the stamp, have
it wait a minute while I disconnect the programming cable, and plug
in my serial device? Then have the stamp take off again?
Us newbies are a tough bunch [noparse]:)[/noparse]
-John
>"Sin and Sout should appear on the DB9-F programming port connector.
>discarded."
That's certainly one method. If you have control of the "other" end, you
may want to use the WAIT parameter of Serin to wait for a certain character
or set of characters to let you know that it's time to do processing.
>We all atarted there at one time :-)
>-John
>Bruce
Notes:
1. The Sin and Sout use the other system's TX line
for voltage, so the other system MUST set the
TX line to -12 volts.
2. Keeping DTR 'active' (+12) will hold the BS2 in
reset. Either use two .1 uF caps to decouple this,
or don't connect DTR, or keep DTR 'inactive'.
connector.
however.
> discarded."
> -John
