Combine SIN and SQR to perform TAN.
As you all know, Basic stamp don't perform Tan calculation.
Still, I need to calculate the angle in a triangle with one 90 dgr
angle. *
c * *
* *b=50
* * Tan B= b/a
* B 90*
a=100
If I only have the value b=50 and a=100, I could use Pythagoras to
calculate c, and then perform Sin B=b/c. So in theory I do
c=SQR((50*50)+(100*100)). Then do Sin B= b/c.
This calculation is far too heavy for my code experience. I can't
even get the BS2p to calculate Sin B=2/2.5 correctly.
Is there anybody with code experience done something this
complicated?
Stein.
angle. *
c * *
* *b=50
* * Tan B= b/a
* B 90*
a=100
complicated?
Stein.
The Stamp only calculates with whole numbers, so 2.4 means 2 for the Stamp!
Another thing is that the Stamp devides the angle into 255 'brads', this
correspnds to the usual 360 degrees. (page 65/66 of my manual).
So you have to keep the numbers in the sine-calculation high enough to get
the desired precision and you have to take account for the somewhat strange
(to me) units of the angles used by the Stamp.
I hope this helps a little,
Klaus
Oorspronkelijk bericht
Van:
because the Stamp does have an arctan function, not well documented,
but it has been there all along. angleB = arctan (sideb/sidea)
sideA var word
sideB var word
angleB var word
sideA=100
sideB=50
angleB = ATN (sideB/sideA)
DEBUG "brads=",dec angleB, CR
DEBUG "degrees=",dec angleB */ 360, CR
' prints brads=18 degrees=25
END
Correct value of arctan (0.5) = 26.565 degrees. The resolution is
not too great, but it is based on 256 brads in a full circle.
Conversion from brads to degrees (360 per circle) is done by the */
360 operator in the second DEBUG command.
-- Tracy
>angle. *
> c * *
> * *b=50
> * * Tan B= b/a
> * B 90*
> a=100
>complicated?
>Stein.
The program should read
angleB = sideA ATN sideB
not
The syntax for the Stamp's built in ATN function is,
angle = adjacent ATN opposite
* *opposite
* * Tan(angle)= opposite/adjacent
* * angle = arctan (opposite/adjacent)
* angle 90*
adjacent
There is info about the command in the help system with the IDE and at
http://www.emesystems.com/BS2math3.htm#ATN_HYP
> sideA var word
> sideB var word
> angleB var word
> sideA=100
> sideB=50
> END
> -- Tracy
> >angle. *
>> c * *
>> * *b=50
>> * * Tan B= b/a
> > * B 90*
>> a=100
> >complicated?
> >Stein.
I'm astounded by your replies.
Don't know what I done without this discussion grope.
Stein.
--- In basicstamps@yahoogroups.com, Tracy Allen <tracy@e...> wrote:
> Hi Stein,
> not
> * *opposite
> * angle 90*
> adjacent
and at
> > sideA var word
> > sideB var word
> > angleB var word
> > sideA=100
> > sideB=50
> > END
> > -- Tracy
dgr
> > >angle. *
> >> c * *
> >> * *b=50
> >> * * Tan B= b/a
> > > * B 90*
> >> a=100
to
> > >complicated?
> > >Stein.
I wrote an example program that uses the Debug Terminal to
demonstrate the ATN and HYP operators. It's been sitting on the
StampsInClass group for a while, and I apologize for not thinking to
post it here. The program is now in the files section for this group.
Filename: AtnHypExample.bs2
Path: http://groups.yahoo.com/group/basicstamps/files/
The program allows you to enter Cartesian coordinates into the Debug
Terminal's Transmit windowpane, and displays the hypotenuse magnitude
and angle in degrees in the Receive windowpane. The values for the
Cartesian coordinates can be from -128 to 128. For more information
on the coordinates, see Tracy's explanation of opposite and adjacent
below.
Regards, Andy Lindsay
