Metal proximity detection — Parallax Forums
ArchiverArchiver Posts: 46,084
edited 2003-11-12 19:45 in General Discussion
Hello all,
I'm trying to find out what sort of sensor I would need to use to
detect the proximity of a large metallic object (say, umm, a car...)
I am trying to design a new driveway monitor. The current one uses
a motion sensor which picks up everything from my dog to UPS trucks,
and everything in between...
I would love to make it metallic-sensitive so I could eliminate the
dogs, cats, deer, groundhogs, etc from setting it off.
Somewhere through my purposeless searches on the internet in years
past, I seem to remember there being a metallic object sensor... Some
sort of proximity sensor... that has a field of detection that is
fairly large(several feet)... Does such a device exist?
In the end, I would like to totally build a monitor system based on
a stamp to take care of this problem for me...
Thanks!
  • ArchiverArchiver Posts: 46,084
    edited 2003-11-12 19:40
    In a message dated 11/12/2003 2:37:25 PM Eastern Standard Time,
    brad@g... writes:
    Could you put a metal detector in the center of your drive way?
    Sid
    It's possible...
    I just found a link that is sort of interesting:
    http://www.smarthome.com/7170.html
    It shows a sensor that appears to be contained in PVC piping... Not
    sure exactly whats within the pipe, but I suspect its some sort of
    large ferrite rod with a coil on it... My guess is that the control
    unit senses the changes in inductance when a vehicle drives over it...
    Unfortunantly, I'm not much for figuring out analog-ish circuits.
    Digital is what I know. lol.
    Anyway, I'm going to keep digging. Thanks!
    > Sid
