Multiple LED status indicators
I have a project where I need to be able to light about 120 LEDs as status
indicators. I will need to be able to choose any individual LED and determine
whether it is to be lit or not, and I need the circuitry to drive them. I guess
a simple memory latch with a multiplex/driver scheme makes most sense? I would
like to be able to send all the data on a single line, or as few lines as
possible. Anyone recommend any particular chips to use for this purpose?
TIA,
David Reaves
TIA,
David Reaves
Maybe some 15 cascaded '595 serial to parallel latches may do it.
The '595 have the neccessary pins to cascade them. It would require
just a single serial line (synchronous) to send a string of 120 bits -
plus an other line to transfer the shiftregister contents to the
outputs (latch).
The '595 are 8bit, maybe there is a different style with 16bit or so.
Regards
Adrian
I believe it has the required current output on-chip
also, so you won't have to use any additional
drivers with the LED's. I recommend DIP factor
current limiting resistors for size and neatness.
Each '595 can control 8 LED's. They can be wired
into a full string of 15 chips, or you can
'split strings' to provide faster updates.
At the 1 uS cycle clock of 'SHIFTOUT', you can
update all 120 LED's in 120 uSec or so. You'll
need 15 bytes to store the info -- which the BS2
has.
Sounds like a cool project!
status
determine
them. I guess
sense? I would
lines as
purpose?
> TIA,
> David Reaves
up to 40 volts, 125 ma each). It easily interfaces with the Stamp
using SHIFTOUT, and multiple UCN5833s can be chained together.
http://www.allegromicro.com/sf/5833/
-- Tracy
>them. I guess
>TIA,
>David Reaves
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the
>Subject and Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
tracy@e... writes:
> The UCN5833 is a 40 pin chip with 32 outputs (latched, open collector
Good heavens, Tracy!! That is over 4 billion combinations per chip!
If he needs four daisy-chained, that could be a programming nightmare.
Sid
control 128leds I do believe. Maxim makes quite a few led based
shift registers so have a look through their site. There are
tutorials in the Nuts/Volts column on Parallax's website for the
MAX7219 driver that will give you some insight as well as the
application notes on Maxim's site.
http://www.maxim-ic.com/Display.cfm
Resc.
--- In basicstamps@yahoogroups.com, Newzed@a... wrote:
> In a message dated 11/12/2003 11:22:26 AM Eastern Standard Time,
> tracy@e... writes:
collector
Stamp
chip!
nightmare.
> Sid
