LEDs row 01234567
For my leds row I have got the simple code below going. This allows
me to control individually the 8 leds on the stamp by pressing 0 to 7
on my keyboard.
But what should I include in the program to be able to access the
stamp with Visual c++ other then the debug window of the editor?
'{$STAMP BS2}
led0 con 0 ' The first LED
led1 con 1 ' The second LED
led2 con 2 '...
led3 con 3
led4 con 4
led5 con 5
led6 con 6
led7 con 7
progPin con 16 ' The programming pin
ledCmd var byte
low led0
low led1
low led2
low led3
low led4
low led5
low led6
low led7
debug "Started.", cr
ReceiveLoop:
Serin progPin, 84, [noparse][[/noparse]ledCmd] ' Get the serial data
if ledCmd = 48 then led0Toggle
if ledCmd = 49 then led1Toggle
if ledCmd = 50 then led2Toggle
if ledCmd = 51 then led3Toggle
if ledCmd = 52 then led4Toggle
if ledCmd = 53 then led5Toggle
if ledCmd = 54 then led6Toggle
if ledCmd = 55 then led7Toggle
if ledCmd = 32 then die
goto ReceiveLoop
led0Toggle:
toggle led0
goto ReceiveLoop
led1Toggle:
toggle led1
goto ReceiveLoop
led2Toggle:
toggle led2
goto ReceiveLoop
led3Toggle:
toggle led3
goto ReceiveLoop
led4Toggle:
toggle led4
goto ReceiveLoop
led5Toggle:
toggle led5
goto ReceiveLoop
led6Toggle:
toggle led6
goto ReceiveLoop
led7Toggle:
toggle led7
goto ReceiveLoop
die:
high 0
low 15
pause 333
low 0
high 15
pause 333
low 0
low 15
debug cr, "Finished",cr
stop
--- In basicstamps@yahoogroups.com, "Dave Mucha" <davemucha@j...>
wrote:
> --- In basicstamps@yahoogroups.com, "alberto_frigo" <artdavi@h...>
> wrote:
> > I would like to control a row of leds (i.e. pin 0 to pin 7)
sending
> > data out of my computer (i.e. if I send out 00000010 then the led
> > conncted to pin 2 is turned on). Anybody could help me?
> > Regards,
> > AF
> are you talking about lighting LED's from a Stamp or your computer ?
on my keyboard.
'{$STAMP BS2}
led2 con 2 '...
led3 con 3
led4 con 4
led5 con 5
led6 con 6
led7 con 7
ledCmd var byte
low led0
low led1
low led2
low led3
low led4
low led5
low led6
low led7
ReceiveLoop:
goto ReceiveLoop
led0Toggle:
toggle led0
goto ReceiveLoop
led1Toggle:
toggle led1
goto ReceiveLoop
led2Toggle:
toggle led2
goto ReceiveLoop
led3Toggle:
toggle led3
goto ReceiveLoop
led4Toggle:
toggle led4
goto ReceiveLoop
led5Toggle:
toggle led5
goto ReceiveLoop
led6Toggle:
toggle led6
goto ReceiveLoop
led7Toggle:
toggle led7
goto ReceiveLoop
die:
high 0
low 15
pause 333
low 0
high 15
pause 333
low 0
low 15
stop
sending
> > Regards,
> > AF
Or,
ReceiveLoop:
if ledCmd = " " then die
OUTL = OUTL ^ (1 << (ledCmd - "0"))
goto ReceiveLoop
See the manual regarding SERIN/SEROUT using I/O 16 for info on
PC<->Stamp serial comm.
Steve
SEROUT ProgPin, 84, [noparse][[/noparse]"MyString", 13]
This will send the 'DEBUG' information back
to C++ on the same serial port you are
using to talk TO the BS2.
You might do:
InDebug CON 1
IF InDebug THEN DebugP1
'ELSE
SEROUT ProgPin, 84, [noparse][[/noparse]"MyString",13]
GOTO SkipP1
DebugP1:
DEBUG "MyString", 13
SkipP1:
' Rest of Program....
' The above code is to allow you to change the
' InDebug constant to 1 when you want 'debug' output,
' and 0 when you want 'SEROUT' output.
7
> on my keyboard.
> '{$STAMP BS2}
> led2 con 2 '...
> led3 con 3
> led4 con 4
> led5 con 5
> led6 con 6
> led7 con 7
> ledCmd var byte
> low led0
> low led1
> low led2
> low led3
> low led4
> low led5
> low led6
> low led7
> ReceiveLoop:
> goto ReceiveLoop
> led0Toggle:
> toggle led0
> goto ReceiveLoop
> led1Toggle:
> toggle led1
> goto ReceiveLoop
> led2Toggle:
> toggle led2
> goto ReceiveLoop
> led3Toggle:
> toggle led3
> goto ReceiveLoop
> led4Toggle:
> toggle led4
> goto ReceiveLoop
> led5Toggle:
> toggle led5
> goto ReceiveLoop
> led6Toggle:
> toggle led6
> goto ReceiveLoop
> led7Toggle:
> toggle led7
> goto ReceiveLoop
> die:
> high 0
> low 15
> pause 333
> low 0
> high 15
> pause 333
> low 0
> low 15
> stop
<artdavi@h...>
> sending
led
> > > Regards,
> > > AF
computer ?
