Always wanted to ask this...
Why doesnt the stamp support Interrupts?
Could someone from parallax also kindly explain.
__________________________________
Do you Yahoo!?
Protect your identity with Yahoo! Mail AddressGuard
http://antispam.yahoo.com/whatsnewfree
Do you Yahoo!?
> Thanks
why not put in your own in the loop ?
persnoally, I would preferr to not use for-next loops if just running
thru the program and doing it one step at time will work just as well.
Dave
> Do you Yahoo!?
Great idea but already used in one OS.
But "Windoze on stamp" sounds great !
Unless Mr Microsoft got it patented and then your are in double
trouble!
They would sue you first and than buy Parallax!
No more nice controller chips to play with!
Forget it! Bad bad idea!
Just kidding. Keep ideas like this comming.
Vaclav
Leroy
: Why doesnt the stamp support Interrupts?
: Could someone from parallax also kindly explain.
: Thanks
: __________________________________
: Do you Yahoo!?
: Protect your identity with Yahoo! Mail AddressGuard
: http://antispam.yahoo.com/whatsnewfree
: To UNSUBSCRIBE, just send mail to:
: basicstamps-unsubscribe@yahoogroups.com
: from the same email address that you subscribed. Text in the Subject and Body
of the message will be ignored.
: Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
dramatically increase the complexity of making things work properly for
several reasons. The key to the Stamp is that it is easy to get impressive
results.
Suppose you have interrupts and you write:
PAUSE 1000
What do you do with an interrupt that occurs during this PAUSE (or PULSOUT)?
Service it? Now the pause is too long. Wait until the PAUSE command
completes? Now you have a giant interrupt latency.
You might say, "But way, you could service the interrupt, add the ISR
execution time to the PAUSE count, and then do the rest of the PAUSE."
That's a good observation, but what about things like SERIN or SEROUT? These
items have critical timing requirements.
Interesting enough compilers like PIC Basic Pro have similar problems. If
you enable their BASIC "interrupts" it is not really interrupts. It checks
for an interrupt in between each BASIC instruction. If you want real
interrupts you have to go to assembly.
That's another problem with interrupts. The Basic Interpreter has to save
its state. That takes some memory. There are several places that it might be
hard to reenter (for example, what if during a SEROUT, and ISR tries to use
SEROUT?).
I'm not saying you couldn't make a Stamp with interrupts. But I am saying it
would add a load of special cases and sources of error to the Stamp which
would defeat its main purpose.
Maybe if they made interrupts optional and you had to know the secret
handshake to get access to them....
Al Williams
AWC
*NEW: Directly Read Position Data from a PS/2 Mouse:
http://www.al-williams.com/pak11.htm
Original Message
> From: harshit suri [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=dtZvVBQ2odagbOBJrflgBsLA9yzgG9zBiRML_aonbUnb9rsOpCHHnzgB4wOXGCgYuU3z3xZPi9WPvsWD]suri_list@y...[/url
> Sent: Saturday, November 08, 2003 1:13 AM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] Always wanted to ask this...
> Thanks
> Do you Yahoo!?
> Subject and Body of the message will be ignored.
What about moving UP to an SX (sold through parallax). Much cheaper than a
stamp, MUCH FASTER than a stamp (I can make a pin go high for 20 nano seconds)
and it supports interupts.
The downside, if you can call it that, is all of the super easy things to do
with a stamp, like a5 mS pause, as you know, the code is "PAUSE 5" This is
not so simple with the SX. For example, a 5 uS pause with the sx has to be
built by "wasting clock cycles" for 5 uS.
Here is code for the SX to make a 5 uS delay
5 uS delay
del_5uS
mov w, #$3d
mov d1, w
del_5uS_0
decsz d1
jmp del_5uS_0
nop
nop
ret
As you can see, there is a bit more work to make a delay. I believe the basic
stamp is an excellent device, and works well in many applications but like
anything, it has limitations.
Ken
> Thanks
Dave
friendly as the Basic Stamp, but much cheaper, faster, and the SX chip also
sold through Parallax supports interupts.
Ken
In a message dated 11/8/2003 7:06:26 AM Pacific Standard Time,
alw@a... writes:
>Thanks
Parallax addressed this issue somewhat in the BS2p and BS2pe, with
the polling commands. These are "interrupts" of the sort that Al
described, that check the state of pins in between each PBASIC
command. This polling scheme is limited in what it can do, in
particular, it cannot run a subroutine and then return from interrupt
to where it left off. It can, however, do a few useful things
without compromising or complicating the timing of the actual
interpreted commands. I use the pollwait commands in my programming
in order to keep the processor sleeping until a timer runs over or
until an event happens on a pin. Also, I use the pollin commands to
capture short pulses on pins so that my program can deal with the
events later without having to check the pins too frequently.
-- Tracy
I hope I don't offend the moderator too much but you
may wish to take a look at BASICX. This device is a
bit cheaper than bigger STAMPs, has twice EEPROM and
has an OS that supports multitasking and interrupts.
I've been very happy with a BSP2p which enabled me to
have a very rapid development time on a project.
However I have decided to evaluate this device as the
looping in the project was getting complex to poll
switches, scroll an LCD module and monitor a rapidly
switching circuit all at once. The BASIC is not as
good as pBASIC and doesn't include LCD and I2C support
- so these have to coded - which is bound to be
slower. The RTC is a bit of a con as it needs the MPU
to be running and can be upset by time-critical tasks.
Also doesn't have raw SX or AVR power. Manuals and IDE
are on line but are not as easy to use as parallex's -
eg commands aren't given with real examples and wiring
set-up.
Choices, choices.
Adrian
________________________________________________________________________
Want to chat instantly with your online friends? Get the FREE Yahoo!
Messenger http://mail.messenger.yahoo.co.uk
I own a couple of BasicX-24. I don't use them. Instead, I use BS2
and BS2p. Why? BX-24 comes with very poor documentation.
How did you learn to use the BX-24?
--- In basicstamps@yahoogroups.com, Adrian <adrian650@y...> wrote:
> Hi,
> set-up.
> Choices, choices.
> Adrian
__
Yahoo!
nobody REALLY does it. What we refer to as "pin polling" (checking
states between instructions) is what others are okay with calling
interrupts -- we don't see them as true interrupts and don't call them
that.
Let me give you an example. What happens if you're executing this
command:
PAUSE 1000
And 200 milliseconds into the PAUSE something happens. What do you do?
If your interrupt process takes 100 millisecond (remember, you're
running BASIC) then is it okay for your PAUSE to be 1100+ milliseconds?
What if that was controlling a machine and the timing was critical? Do
you see where I'm going here? So, BASIC is generally not reentrant, so
not interruptible. In the BS2p we can check pins between instructions
so that the instruction integrity is maintained. We don't call that an
interrupt ... others do.
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: harshit suri [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=mMbuGKktP4RADOk9Wtwm7RGthKNxw_6QsQNXHnAhCuEYLxwdApjMG-lF6PKbO89G-BADJwas9f1snD5VJg]suri_list@y...[/url
Do you Yahoo!?
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
that would require Interrupt. Once the timing was worked out your pause would
not just pause the processor....you would be busy checking on things while your
waiting.
Now during your Main Code segment...that's another matter.
With 4,000 instructions per second....what would you miss if you looked for the
event every once and a while....???
Tim
>>> jwilliams@p... 11/12/03 11:39AM >>>
It's difficult to explain, even more difficult to do -- which is why
that.
command:
PAUSE 1000
-- Jon Williams
-- Dallas Office
Original Message
From: harshit suri [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=hztIlZxFQFxtdVMxYE95SHgnG9JOuKYH9bbIY7xnd05nMAskRU4dQ7vhspCOSRLAHHMBEi4K79npN74w8g]suri_list@y...[/url
Do you Yahoo!?
abuse@p....
programmers have happily lived without them for a very long time.
PBASIC makes it easy to construct a program that "feels" like it's
handle "interrupts" without doing it. I've shared this structure
several times, but here goes again:
Main:
DO
GOSUB Do_Something_Important
ON task GOSUB Task1, Task2, Task3
LOOP
The idea is that the "Do_Something_Important" is your background process
and your tasks are the foreground process. Any of the subroutines can
update the current task pointer to control the flow of the program. I
use this structue all the time and it works well -- and is easy to
manage.
-- Jon Williams
-- Dallas Office
Original Message
From: Tim Hart [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=eiAMF_KnJoDZhYi8UWKVWGL2jM7jDbsIrU4kGscB737oSA6MJsAJnhkA-RCI4FpFUwW6NtIYUiNHs72sYQ]tim.hart@h...[/url
Sent: Wednesday, November 12, 2003 1:49 PM
Subject: RE: [noparse][[/noparse]basicstamps] Always wanted to ask this...
Why not make an intelligent pause....Just run the checking status for
events that would require Interrupt. Once the timing was worked out
your pause would not just pause the processor....you would be busy
checking on things while your waiting.
for the event every once and a while....???
Tim
that.
command:
PAUSE 1000
-- Jon Williams
-- Dallas Office
Original Message
From: harshit suri [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Vpwg8jTxBsXnJ58728EGhtMQBO4XU2q9qodW_czmQn29EH_R0kmjmjZMNLwfJAH0UxnEr4JkcO6G4Q]suri_list@y...[/url
Do you Yahoo!?
abuse@p....
abuse@p....
I have been using Basic Stamps in industrial machines for a long time and I
don't miss interrupts at all.
When I have to wait for something to happen I pause in little bits and take a
look around and if nothing is happening then pause a little bit longer.
Enough_Time = (Your Delay Value)
x = 0 'Clear time counter
Looking_For_Something_To_Do:
if x > Enough_Time then Stop_Goofing_Off 'If the time delay is reached Go
Do Something.
pause 1 'Wait just a little bit
If Input 1 (is true) goto Do_Something 'Check for Something to do.
If Input 2 (is true) goto Do_Something_Else 'Check for Something else to do.
... 'Yada
... 'Yada
... 'Yada
x = x + 1 'Increment the time counter
goto Looking_For_Something_To_Do
In most machinery this simple polling routine may need to be fine tuned for
timing by changing the value of Enough_Time.
This is a little bit of brute force, but it allows leaving the loop without
worrying about If-Then-Next stack errors.
Most machinery is event driven so when you do something while waiting, and
event will send you off the waiting task anyway.
When you go somewhere out of the delay loop it will throw the loop timing
off.
If we were really worried about millisecond timing we would bite the bullet
and spend $2k for the slick PLC unit. But hey for $49 bucks you cant bang any
more bits than a Stamp2.
Alan Bradford
StamPlc.com and PlasmaTechnologies.com
In a message dated 11/12/2003 12:41:15 PM Eastern Standard Time,
jwilliams@p... writes:
that.
command:
PAUSE 1000
-- Jon Williams
-- Dallas Office
Original Message
From: harshit suri [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=SDT5HPROBBSQhRZHrEdKVkZG1ZC6MZlHiCD4_GLzv6ZAmHzI5AIiFoy9ISVvCfh6xij_3_Pc1AuJGc8]suri_list@y...[/url
a kind of an interrupt?
On Wed, 12 Nov 2003, Jon Williams wrote:
> The fact is that MANY microcontrollers DON'T have interrupts and
> Main:
> DO
> LOOP
> manage.
> -- Jon Williams
> -- Dallas Office
Original Message
> From: Tim Hart [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=JOZdy-UREqjSyItO_RdJSi3mDFIS8yqPNY3FFsdU0NnVaUSKwfBN7AC4SemPzrkCVOGFhjHUkfCIocE]tim.hart@h...[/url
> Tim
> that.
> command:
> PAUSE 1000
> -- Jon Williams
> -- Dallas Office
Original Message
> From: harshit suri [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_Hcb-JEpobqLtAG9VMlOWLP6Gyu4g5HspJ1kV8C3KIjMdOzI14Onxvqnsj_r8R2ZyiueJQr3B7UP]suri_list@y...[/url
> Thanks
> Do you Yahoo!?
> abuse@p....
> abuse@p....
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"Do not fear mistakes, There Are None" - Miles Davis
reset ... but this is a bit "brute force" and you'll lose all your
variables as the reset will clear them to zero.
-- Jon Williams
-- Dallas Office
Original Message
From: Sean T. Lamont .lost. [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=XlUiYSqLfTem26en6MFJjYB034XFAep4-avpqG5eb_S8KhLZ-CiDgAY52NqejczKXWAGJzy1NTD9YdH671E0Aw]lamont@a...[/url
Sent: Wednesday, November 12, 2003 5:29 PM
Correct me if I'm wrong, but can't you use the reset button on the BS2
for a kind of an interrupt?
> Main:
> DO
> LOOP
> process and your tasks are the foreground process. Any of the
> subroutines can update the current task pointer to control the flow of
> the program. I use this structue all the time and it works well --
> and is easy to manage.
> -- Jon Williams
> -- Dallas Office
Original Message
> From: Tim Hart [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=z1kCyKfMtFco51a-nRVCMUx1okg-MRtmWp9u0d7TV0EuCGPrV8PRPKLh7WLrfPWy8at65FOd5iIPEGxcgKE]tim.hart@h...[/url
> looked for the event every once and a while....???
> Tim
> that.
> command:
> PAUSE 1000
> do? If your interrupt process takes 100 millisecond (remember, you're
> milliseconds? What if that was controlling a machine and the timing
> was critical? Do you see where I'm going here? So, BASIC is
> generally not reentrant, so not interruptible. In the BS2p we can
> check pins between instructions so that the instruction integrity is
> maintained. We don't call that an interrupt ... others do.
> -- Jon Williams
> -- Dallas Office
Original Message
> From: harshit suri [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=JV1CM-caE7JwtMdIGBuytZ8IMiIRIZJW2MyySKIYm9JqbbKyhaERrzLMxPnJ9Sv6xMtA8dxbAjI36C589AA]suri_list@y...[/url
> Thanks
> Do you Yahoo!?
> abuse@p....
> abuse@p....
Bremerton
abuse@p....
but most people treat interrupts
as something quick, which doesn't clear the entire
state of the micro, and then have an unpredictable
time before your program starts running again.
A Reset is usually considered more of an 'oh-my-god,
everything is hosed, I need to take this thing back
to start and begin again' kind of signal. There is
no way to do a 'reset' then return to your OTHER
executing code in progress -- what most people
mean by an interrupt.
--- In basicstamps@yahoogroups.com, "Sean T. Lamont .lost."
BS2 for
> > Main:
> > DO
> > LOOP
process
subroutines can
program. I
> > manage.
> > -- Jon Williams
> > -- Dallas Office
Original Message
> > From: Tim Hart [noparse][[/noparse]mailto:tim.hart@h...]
for
out
looked
> > Tim
why
(checking
them
> > that.
> > command:
> > PAUSE 1000
you do?
milliseconds?
critical? Do
reentrant, so
instructions
that an
> > -- Jon Williams
> > -- Dallas Office
Original Message
> > From: harshit suri [noparse][[/noparse]mailto:suri_list@y...]
> > Thanks
> > Do you Yahoo!?
Subject
> > abuse@p...
Subject
Subject
> > abuse@p...
(ServNet)
Bremerton
