Taking two sample arrays
Hi All
Is there a way of taking two sample arrays ON A BS2
ie
SA VAR W1 ........ SAMPLE A
too
SL VAR W12 ........ SAMPLE L
ARRAY...ONE VAR WORD(12)....... first run of SAMPLE A - SAMPLE L
ARRAY.....TWO VAR WORD(12).....second run of SAMPLE A - SAMPLE L
start:
PULSIN 0,0 SA
TO
PULSIN 0,0 SL
ARRAYONE(0) = SA
ARRAYONE(11) = SA
PUSLIN 0,0 SA
TO
PULSIN 0,0 SL
ARRAYTWO(0) =SA
ARRAYTWO(11)= SL
THEN DO SOME MATHS COMPARISONS
I am pretty sure I run out of space to store two arrays???
Max I can do is 5 samples and array(5) TIMES TWO.... OR I could do one VAR and
ARRAY(14) but slower I WOULD think in out come.. i.e. miss some samples.
Rob
This email is confidential and may also be privilege.
If you are not the intended recipient, please notify us immediately.
You should not copy or use it for any purpose, nor disclose it's contents to any
other person.
ie
too
start:
PULSIN 0,0 SA
TO
PULSIN 0,0 SL
ARRAYONE(0) = SA
ARRAYONE(11) = SA
PUSLIN 0,0 SA
TO
PULSIN 0,0 SL
ARRAYTWO(0) =SA
ARRAYTWO(11)= SL
Rob
other person.
one VAR Word(6)
two VAR Word(6)
... but that would leave you without any variables to do your math. So,
the practical limit for your application is going to be five elements.
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
[noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=C5LK_BmZUtyNcRjaasWDA2DKRIHOAKSe4QhyYIZy65TzmTYWhdTy47vjW9tPOnEq1j5O1GJE036-JfqiqeqCTNcuMw]ftech@n...[/url
Sent: Wednesday, November 05, 2003 7:46 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] TAKING TWO SAMPLE ARRAYS
Hi All
ie
too
start:
PULSIN 0,0 SA
TO
PULSIN 0,0 SL
ARRAYONE(0) = SA
ARRAYONE(11) = SA
PUSLIN 0,0 SA
TO
PULSIN 0,0 SL
ARRAYTWO(0) =SA
ARRAYTWO(11)= SL
VAR and ARRAY(14) but slower I WOULD think in out come.. i.e. miss
some samples.
Rob
contents to any other person.
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
Thats what I thought from the manual ...but I was hoping there might have
been a trick to get around it.....is there anyway of adding extra memory to
expand that or is there away I can store results of 1-9999 in smaller value
array say a byte?
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Thursday, November 06, 2003 12:41 PM
Subject: RE: [noparse][[/noparse]basicstamps] TAKING TWO SAMPLE ARRAYS
> The Stamp has just 12 word-sized registers, so you an your max would be:
> one VAR Word(6)
> two VAR Word(6)
> -- Jon Williams
> -- Dallas Office
Original Message
> From: Rob Farrand ... FTech Connection
> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jLOVbifldXr9Sj2DCA8B0KKNM1aQumLFSUbweZZIW5p-laY_WkcNhtqqfhs8wM3xLM_UzAzKjt5ADi2NetceGQ]ftech@n...[/url
> Hi All
> ie
> too
> start:
> PULSIN 0,0 SA
> TO
> PULSIN 0,0 SL
> ARRAYONE(0) = SA
> ARRAYONE(11) = SA
> PUSLIN 0,0 SA
> TO
> PULSIN 0,0 SL
> ARRAYTWO(0) =SA
> ARRAYTWO(11)= SL
> some samples.
> Thanks
> Rob
> abuse@p....
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
you'll make Bill Gates look like a chump. Don't spend your energy,
though, it won't happen.
You can't add variable memory to the Stamp. If you use one of the
multi-bank Stamps you have more RAM space -- in the Scratchpad. It's
not as easy to access, but not tough and even the BS2e gives you 64
extra bytes (32 words -- two 16-word arrays). You have to use PUT and
GET to access the Scratchpad. Here's some starter code to give you an
idea:
' {$STAMP BS2e}
' {PBASIC 2.5}
idx VAR Nib
addr VAR Byte
pulsVal VAR Word
tVal1 VAR Word
tVal2 VAR Word
Test_1:
FOR idx = 0 TO 11
PULSIN pin, level, pulsVal
addr = 2 * idx
PUT addr, Word pulsVal
NEXT
Test_2:
FOR idx = 0 TO 11
addr = 24 + (2 * idx)
NEXT
Compare:
FOR idx = 0 TO 11
addr = 2 * idx
GET addr, Word tVal1
addr = addr + 24
GET addr, Word tVal2
' do your thing with tVal1 and tVal2 here
NEXT
-- Jon Williams
-- Dallas Office
Original Message
[noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=erT4qGjfcFmlzMczvWEZsh5Fy6eAKVOQ7DwKyQKU4CK4plhUP38RhXKTYYycyz9rauvaj8RM3veXQwgcp09f_wQ2]ftech@n...[/url
Sent: Wednesday, November 05, 2003 8:22 PM
Subject: Re: [noparse][[/noparse]basicstamps] TAKING TWO SAMPLE ARRAYS
Thanks Jon
have been a trick to get around it.....is there anyway of adding extra
memory to expand that or is there away I can store results of 1-9999 in
smaller value array say a byte?
Original Message
> be:
> one VAR Word(6)
> two VAR Word(6)
> So, the practical limit for your application is going to be five
> elements.
> -- Jon Williams
> -- Dallas Office
Original Message
> Hi All
> ie
> too
> start:
> PULSIN 0,0 SA
> TO
> PULSIN 0,0 SL
> ARRAYONE(0) = SA
> ARRAYONE(11) = SA
> PUSLIN 0,0 SA
> TO
> PULSIN 0,0 SL
> ARRAYTWO(0) =SA
> ARRAYTWO(11)= SL
> one VAR and ARRAY(14) but slower I WOULD think in out come.. i.e.
> miss some samples.
> Thanks
> Rob
> abuse@p....
> and
abuse@p....
yes I could do with bills cash too
no I was thinking of
SA/255 so 9999 would be 39.21
I am new to this program thing... it all seems simple on paper
problem then is if I get a
SA 235
SB 245
SC 9999
CAN I MAKE IT SOMEWAY TO SAY THAT SC WAS /255
Thanks anyway
Original Message
Sent: Thursday, November 06, 2003 1:19 PM
> If you can figure out how to store a value from 1 - 9999 in a byte
> idea:
> ' {$STAMP BS2e}
> ' {PBASIC 2.5}
> idx VAR Nib
> addr VAR Byte
> pulsVal VAR Word
> tVal1 VAR Word
> tVal2 VAR Word
> Test_1:
> FOR idx = 0 TO 11
> addr = 2 * idx
> NEXT
> Test_2:
> FOR idx = 0 TO 11
> NEXT
> Compare:
> FOR idx = 0 TO 11
> addr = 2 * idx
> addr = addr + 24
> NEXT
> -- Jon Williams
> -- Dallas Office
Original Message
> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=CIS4YgOU2hYGIzzh-GAt2PqPe0JMzAOYceCDvqUBgm8CFNoaFsq8F_nIBexLophPRkEc-zmNeyQnTXksHRQ8]ftech@n...[/url
> Thanks Jon
Original Message
> From: "Jon Williams" <jwilliams@p...>
> > be:
> > one VAR Word(6)
> > two VAR Word(6)
> > elements.
> > -- Jon Williams
> > -- Dallas Office
Original Message
> > Hi All
> > ie
> > too
> > start:
> > PULSIN 0,0 SA
> > TO
> > PULSIN 0,0 SL
> > ARRAYONE(0) = SA
> > ARRAYONE(11) = SA
> > PUSLIN 0,0 SA
> > TO
> > PULSIN 0,0 SL
> > ARRAYTWO(0) =SA
> > ARRAYTWO(11)= SL
> > miss some samples.
> > Thanks
> > Rob
> > abuse@p....
> > and
> abuse@p....
One way to collapse data X that covers a wide range, into a smaller
range, is to work with the logarithm of X instead of X itself. That
is justified when percentage changes are more important that absolute
changes, for example, if a change from 100 to 200 counts for as much
as a change from 1000 to 2000.
With log base 2, numbers from 1 to 65535 can become compressed into
the range from 0 to 256, but still maintain the correct order of
magnitudes among your samples. The Stamp does not have a logarithm
operator per se, but it comes close, with the NCD operator. That is
essentially a log base 2. Here is a URL with more explanation of how
it works and also a simple extension to the fractional part, which is
commonly called the quick bitlog function:
http://www.emesystems.com/BS2math3.htm#bitlog
Your example numbers were, 235,245,9999.
Transformed to log base 2, the sequence is:
7.87, 7.94, 13.29
or multiplying each value *16 (in order to scale it into one byte),
you would have,
125, 127, 212.
I haven't the foggiest idea what the numbers you are collecting
represent, so I can't really say what is appropriate mathematically.
As to the processing, you might be able to do the math as you bring
in successive values, rather than collecting them all into an arrays
first. This will involve accumulating several sums: 1)the sum of the
values, 2)the sum of the squares of the values, and also 3) probably
the sum of a cross product. The computations will take time on the
Stamp, so that approach won't work if the samples have to be taken in
a split second. It is possible that some non-parametric statistic
might give you the answer you need, without so much computation.
-- regards,
Tracy
>Thanks Jon
>SA 235
>SB 245
>SC 9999
>Thanks anyway
Original Message
>> idea:
>> ' {$STAMP BS2e}
>> ' {PBASIC 2.5}
>> idx VAR Nib
>> addr VAR Byte
>> pulsVal VAR Word
>> tVal1 VAR Word
>> tVal2 VAR Word
>> Test_1:
>> FOR idx = 0 TO 11
>> addr = 2 * idx
>> NEXT
>> Test_2:
>> FOR idx = 0 TO 11
>> NEXT
>> Compare:
>> FOR idx = 0 TO 11
>> addr = 2 * idx
>> addr = addr + 24
>> NEXT
>> -- Jon Williams
>> -- Dallas Office
Original Message
>> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=CWeEKuizVwLz1NYtdIEH2ne3zCNC9e2TBX3YJ9VAbhlBjnw27a2kqS0x9tkAkpiBA3Pq8wbcsdN7lJjIXYmN5w]ftech@n...[/url
>> Thanks Jon
Original Message
>> > be:
>> > one VAR Word(6)
>> > two VAR Word(6)
>> > elements.
>> > -- Jon Williams
>> > -- Dallas Office
Original Message
>> > Hi All
>> > ie
>> > too
>> > start:
>> > PULSIN 0,0 SA
>> > TO
>> > PULSIN 0,0 SL
>> > ARRAYONE(0) = SA
>> > ARRAYONE(11) = SA
>> > PUSLIN 0,0 SA
>> > TO
>> > PULSIN 0,0 SL
>> > ARRAYTWO(0) =SA
>> > ARRAYTWO(11)= SL
>> > miss some samples.
>> > Thanks
>> > Rob
If you're running low on available RAM on your BS2 you might like to
consider using the RAM Pack B from Solutions Cubed.
http://www.warburtech.com/Modules/RAM Pack B/RAM Pack B.htm
The RAM Pack B module maintains 8Kx8 bytes of RAM and makes use of buffers
and an on board microcontroller to allow addressable access to the RAM using
only 1 or 2 I/O lines on your BASIC Stamp. The 8Kx8 bytes of static RAM
comes socketed and may be expanded to handle 32Kx8 bytes of RAM.
If you would like more information about the RAM Pack B, or need help with
your BASIC Stamp code, just let me know. I look forward to hearing from you.
Best regards,
Russell Warburton
email: russell@w...
website: http://www.warburtech.com
telephone: +44 (0)7814 044 754
Original Message
From: "Rob Farrand ... FTech Connection" <ftech@n...>
Sent: Thursday, November 06, 2003 1:46 AM
> Hi All
> ie
> too
> start:
> PULSIN 0,0 SA
> TO
> PULSIN 0,0 SL
> ARRAYONE(0) = SA
> ARRAYONE(11) = SA
> PUSLIN 0,0 SA
> TO
> PULSIN 0,0 SL
> ARRAYTWO(0) =SA
> ARRAYTWO(11)= SL
VAR and ARRAY(14) but slower I WOULD think in out come.. i.e. miss some
samples.
> Thanks
> Rob
I will look at Your Idea Russell as option thanks
Tracy I think that is possibly the way to do it!
I lead you all up a path a bit with the 9999 value it will of course only be
as high as max pulsin value (I don't know what that is maybe it is I assume
65535 I haven't reached it yet).
Its not a life and death result so extreme accuracy is not needed but a
reliable average would be good if that makes sense.
The trick is in capturing the input pulses which could happen in 4 samples
or over 48 -60
samples then working out the increase or decrease in the pulses. The action
of the pulse can be re sent over an over once a action/stray is detected
from the norm..... so the math time is not an issue... ie...
nothing happening
nothing happening
change (start sample show
warning
saying...that sampling..then when result worked out and displayed you can
re in act the change if its what I want do for X if not
continue) ----nothing
happening. etc
Thanks heaps everyone
Original Message
Sent: Thursday, November 06, 2003 4:40 PM
> Hi Rob,
> 7.87, 7.94, 13.29
> you would have,
> 125, 127, 212.
> -- regards,
> Tracy
> >Thanks Jon
> >SA 235
> >SB 245
> >SC 9999
> >Thanks anyway
Original Message
> >> idea:
> >> ' {$STAMP BS2e}
> >> ' {PBASIC 2.5}
> >> idx VAR Nib
> >> addr VAR Byte
> >> pulsVal VAR Word
> >> tVal1 VAR Word
> >> tVal2 VAR Word
> >> Test_1:
> >> FOR idx = 0 TO 11
> >> addr = 2 * idx
> >> NEXT
> >> Test_2:
> >> FOR idx = 0 TO 11
> >> NEXT
> >> Compare:
> >> FOR idx = 0 TO 11
> >> addr = 2 * idx
> >> addr = addr + 24
> >> NEXT
> >> -- Jon Williams
> >> -- Dallas Office
Original Message
> >> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=MW01ziPZS8DsD1cvvWdlCemhAVJgUsT9CafhBBdRUR9j5qOKm7KVmXeegGTULCKOXlBpjzL_ntlVwVOiK6FfTzD7]ftech@n...[/url
> >> Thanks Jon
Original Message
> >> > be:
> >> > one VAR Word(6)
> >> > two VAR Word(6)
> >> > elements.
> >> > -- Jon Williams
> >> > -- Dallas Office
Original Message
> >> > Hi All
> >> > ie
> >> > too
> >> > start:
> >> > PULSIN 0,0 SA
> >> > TO
> >> > PULSIN 0,0 SL
> >> > ARRAYONE(0) = SA
> >> > ARRAYONE(11) = SA
> >> > PUSLIN 0,0 SA
> >> > TO
> >> > PULSIN 0,0 SL
> >> > ARRAYTWO(0) =SA
> >> > ARRAYTWO(11)= SL
> >> > miss some samples.
> >> > Thanks
> >> > Rob
