Basic Stamp Schematic- decal silk screen ?
Very interesting !
seems you could use bright yellow on most ink jets to get a visable
image.
water slide paper just went on my shopping list.
Dave
--- In basicstamps@yahoogroups.com, "Al Williams" <alw@a...> wrote:
> Actually, if you really want to do a nice job -- go to a craft or
art supply
> store and get "water slide" paper. You can print on it with a laser
printer
> and make a decal like you put on model cars, airplanes, etc. Of
course the
> legend will be black but very sharp. The decal is very thin so
component
> leads push right through it and the plastic vaporizes under heat so
if you
> have any top-side soldering it will still work.
> This is a real life saver when you have had 500 boards made and
they forgot
> to image the silk screen layer :-) Um, not that I've ever done
that, no no!
> I'll deny it to the end.
> If you are highly motivated, get time on an ALPS printer which can
print in
> white. There are ink jet water slide papers too but I haven't tried
them.
> Al Williams
> AWC
> * Floating point math for the Stamp or any micro
> http://www.al-williams.com/pak1.htm
Original Message
> > From: LJGeib@a... [noparse][[/noparse]mailto:LJGeib@a...]
> > Sent: Tuesday, November 04, 2003 9:39 PM
> > To: basicstamps@yahoogroups.com
> > Subject: [noparse][[/noparse]basicstamps] Re: Basic Stamp Schematic
> > get it done without the silkscreen and use a sharpie
> > LarryIn a message dated 11/4/03 6:55:04 PM Pacific Standard Time,
> > basicstamps@yahoogroups.com writes:
> > In a message dated 11/4/2003 9:18:04 AM Pacific Standard
> > Time, gdii@c...
> > writes:
> > is there a place where i could get PCB done with silk
> > screening with out
> > paying the ridiculous price of express PCB
> > [noparse][[/noparse]Non-text portions of this message have been removed]
> > To UNSUBSCRIBE, just send mail to:
> > basicstamps-unsubscribe@yahoogroups.com
> > from the same email address that you subscribed. Text in the
> > Subject and Body of the message will be ignored.
> > Your use of Yahoo! Groups is subject to
> > http://docs.yahoo.com/info/terms/
image.
Dave
art supply
printer
course the
component
if you
they forgot
that, no no!
print in
them.
> Al Williams
> AWC
Original Message
> > Time, gdii@c...
> > writes:
> > screening with out
"iron" on laser printer toner. This is just like you do to transfer toner
for resist, but you don't remove it. Again, black markings, and it is hard
to get the alignment just right, but the results are impressive.
Al Williams
AWC
* Control 8 servos at once: http://www.al-williams.com/pak8.htm
Original Message
> From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=QP1g0iY-nalANpxTD5z3jWt64TrhwIhVL1_0Y4FR4W9sFajMV-2XV49vLYOdAeOuYZdoVfH6zHT4]davemucha@j...[/url
> Sent: Wednesday, November 05, 2003 10:02 AM
> Subject: [noparse][[/noparse]basicstamps] Re: Basic Stamp Schematic- decal silk screen ?
> Very interesting !
> image.
> Dave
> art supply
> printer
> course the
> component
> if you
> they forgot
> that, no no!
> print in
> them.
> > Al Williams
> > AWC
Original Message
> > > Time, gdii@c...
> > > writes:
> > > screening with out
