comparing values in an array
Hi All
my first post so hope I have done it correctly
thanks in advance for any advice
I not sure if you can do it, I got a bit confused in the manual ..
I want to set up an array on a BS2 that has variables in it and then get a
result that tells me if the array is ascending or descending and the position of
the results will be used also to decide a result i.e.
Array might look like these
( 1,2,0,1,2,3,0,1) a result here would be low high gap low high ignoring the 0
and last one
(334,335,336,3,1000,1120,1,5) a result here would be low to high ignore 3 as its
a error
as you can see I can not set a >< as the variables range from 0 - 3000 possibly
I sort of did it with IF OR AND THEN statements just using the variables but the
permutation are to high and some results skip by which maybe the same as the
array idea but be a bit neater as I hope to use the position in working out a
result answer.
I am not after the answer on working out the result just an idea on a better way
than using if then and comparing the input variables any ideas?
Rob
This email is confidential and may also be privilege.
If you are not the intended recipient, please notify us immediately.
You should not copy or use it for any purpose, nor disclose it's contents to any
other person.
and last one
a error
result answer.
Rob
other person.
>get a result that tells me if the array is ascending or descending
>and the position of the results will be used also to decide a result
>i.e.
>ignoring the 0 and last one
>ignore 3 as its a error
>3000 possibly
>variables but the permutation are to high and some results skip by
>which maybe the same as the array idea but be a bit neater as I hope
>to use the position in working out a result answer.
>a better way than using if then and comparing the input variables
>any ideas?
>Thanks
>Rob
I'm not sure what you are trying to do here. One standard way to
detect a trend is to find the straight line that is the best fit to
the sequence of values. Y = m * X + b. Here the X values are just
the sequence of array index, 0,1,2,..,8. There are standard methods
for doing this, using least squares regression. But it gets more
complicated when it has to ignore some of the data, because they are
errors or do not meet some criteria. The computer has to know what
to ignore and what to count.
you have given me some things to think about...
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Wednesday, November 05, 2003 5:40 PM
Subject: Re: [noparse][[/noparse]basicstamps] comparing values in an array
> >Hi All
> >i.e.
> >3000 possibly
> >any ideas?
> >Thanks
> >Rob
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
