FPGA — Parallax Forums
FPGA
ArchiverArchiver Posts: 46,084
edited 2003-11-04 15:15 in General Discussion
Guys,
I know this is not the site for FPGA, but I don't know where else to
turn.
I would like a short introduction to what FPGA is. How does it
differ from PLD or PAL?
Is it suitable for combinatorial logic or sequential logic or both?
Which of the offerings by Parallax do you recommend for a FPGA
beginner whose basic goal is to learn and get some hands on
experience?
Can anyone give me an example of how to use an FPGA?
I think I "know" what it is, but I want to make sure before I buy one.
Thanks for help.
  • ArchiverArchiver Posts: 46,084
    Look at Al William's site -- excellent overview.
    All "Programmable Logic" chips allow you to
    implement a digital design of logic gates into
    a chip. When you do this you get a device
    which implements a state-machine, or a logic
    equation -- and can run much faster than the
    equivalent in a microprocessor.
    An FPGA differs from PLD or PAL in that typically
    in a PLD (like 22V10) you actually 'burn' fuses
    in the device -- the device itself holds the
    configuration.
    An FPGA typically has a MUCH larger 'sea-of-gates'
    to be connected. Some of the largest actually
    download their configuration from an attached
    EEPROM on power-up. Also, FPGA can be
    re-programmed in-circuit. Most PLD or PAL
    require a special programmer.
    It is suitable for combinatorial logic. For
    sequential logic, if you can design a
    state-machine implementation, you can put that
    into an FPGA.
    A "typical" small example often used is to
    build a traffic light control state-machine.
    Inputs are the car-sensors in the pavement,
    and a 'clock-tick'. Outputs are the Yellow-Red-
    Green light signals in all 4 directions.
    I've used them for communication capture.
    Some have DSP cores, and can give you fast
    fourier transforms in real-time (derive the
    frequency components of an input signal).
    Some FPGA's are big enough to implement your
    own microprocessor core inside. Some give
    you LOTS of I/O in a small package.
    Parallax sells 3 development boards supporting
    the Altera FPGA's. If your need for signal
    processing speed is not met by the 50 MIPS
    SX processor line, FPGA's give you a higher
    speed alternative.
    --- In basicstamps@yahoogroups.com, "basicstampede"
    <basicstampede@y...> wrote:
    > Guys,
    to
    > turn.
    > experience?
    one.
    > Thanks for help.
