Do i Unsolder the broken pin first or would that put too much heat on the
Bs2. i have a desoldering braid.
, thanks Gary D
At 02:24 PM 11/3/2003 -0500, you wrote:
>I did the same thing, Gary!
>I smashed an old 7700 series chip and retrieved a pin.
>Carefully soldering the IC pin to the BS-2 revived it
>nicely. If you have some 4% silver solder available,
>use it for the added strength.
>Clamp the stamp in a vice for support, and do your
>soldering as quickly as possible.
>John
Original Message
>From: "Gary Denison" <gdii@c...>
>To: <basicstamps@yahoogroups.com>
>Sent: Monday, November 03, 2003 2:07 PM
>Subject: [noparse][[/noparse]basicstamps] broken stamp I/O pin
> > i have Broken I/O pin 7 on my Bs2 what do i do for repairs? will parallax
> > fix it? thanks for any help Gary D
> > To UNSUBSCRIBE, just send mail to:
> > basicstamps-unsubscribe@yahoogroups.com
> > from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
> > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
John
Original Message
I removed the old pin first.
Note that the pins are attached to both sides of the
circuit board. Unsolder one side first; allow the stamp
to cool then do the other side. When you solder the
new/old IC pin on, make sure that both sides are attached.
Solder one side, cool it, and then the other.
For desoldering, I used an Edsyn "solder sucker", but I
don't see why you couldn't use light guage braid if you
work quickly.
I relegated the fixed stamp to a permananent use where I
wouldn't be moving it in and out of a socket all the time.
I tried this as a last resort, and was willing to accept failure!
I didn't have a backup Stamp at the time.
John
Original Message
Sent: Monday, November 03, 2003 2:22 PM
Subject: Re: [noparse][[/noparse]basicstamps] broken stamp I/O pin
> , thanks Gary D
> >John
Original Message
parallax
For future protection why not just use a wire-wrap socket?
Plug the stamp into the wire-wrap socket, then use the
wire-wrap socket piggy-back style into whatever suits your
needs.... (SBB) solderless bread board, existing socket, etc.
When you are ready for a more permanent solution, unplug the
stamp from the wire-wrap socket and plug it in directly.
-Beau Schwabe
>Gary,
>work quickly.
>John
Original Message
> > , thanks Gary D
> > >John
Original Message
>parallax
parallax
Depending on how is it broken, you could use a chip carrier or chip
socket. stick a resistor lead in the matching socket and then stick
the Stamp in. then solder the lead to the stamp.
that way, all the ruture abuse will be on the chips socket.
>parallax
>Dave
Dave,
I think we're on the same wavelength here. I had mentioned
the use of a wire-wrap socket primarily for the length (cut
as desired) and durability of the 'pins' relative to just a
standard IC socket. Forget for the moment that you can
wire-wrap to the socket and just use it as a durable conduit
for the Stamp.
Plug the stamp into the wire-wrap socket, then use the wire-wrap socket
piggy-back style into whatever suits your needs.... (SBB) solderless bread
board, existing socket, etc. When you are ready for a more permanent
solution, unplug the stamp from the wire-wrap socket and plug it in
directly.
-Beau Schwabe
>Gary,
>new/old IC pin on, make sure that both sides are attached. Solder one
>work quickly.
>I relegated the fixed stamp to a permananent use where I wouldn't be
>moving it in and out of a socket all the time. I tried this as a last
>resort, and was willing to accept failure! I didn't have a backup Stamp
>at the time.
>John
Original Message
> > on the Bs2. i have a desoldering braid.
> > , thanks Gary D
> > >I smashed an old 7700 series chip and retrieved a pin. Carefully
> > >soldering the IC pin to the BS-2 revived it nicely. If you have
> > >some 4% silver solder available, use it for the added strength.
> > >Clamp the stamp in a vice for support, and do your soldering as
> > >John
Original Message
>parallax
To UNSUBSCRIBE, just send mail to: basicstamps-unsubscribe@yahoogroups.com
yeah, those work great. I think they're pretty expensive new, but I got
some at the local junk shop for about a buck a piece.
d...
Original Message
> From: Brady,Steven [noparse]/noparse]PYR] [noparse][[/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=zaISOxOG-P80adPNervKDZbLFAuruEhu3G11xWjWeOaAuhq8vJQZOv1_duYqbbUAzmAdy8F0T1QfljoyS_j2]steven.brady2@e...[/url
> Sent: Monday, November 03, 2003 6:31 PM
> To: 'basicstamps@yahoogroups.com'
> Subject: RE: [noparse][[/noparse]basicstamps] broken stamp I/O pin
> What about a ZIF socket? I hope I'm thinking of the right thing... Zero
> Input Force I think is what it stands for!
> It has the little lever on the side that will clamp it down. Used in
> programmers mostly (at least as far as I've seen it!
> sb
Original Message
> From: Beau Schwabe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-y_Xaj_RGB2_tAwR4V2PtTPDelRpx1jeoKENU0zgu8q1kDlRlaWyrfU1S99RfQ-qQJx36MzANcEb5t4sa1aamSM]bschwabe@a...[/url
> Sent: November 3, 2003 12:19 PM
> To: basicstamps@yahoogroups.com
> directly.
> -Beau Schwabe
> >Gary,
> >work quickly.
> >at the time.
> >John
Original Message
> > > , thanks Gary D
> > > >John
Original Message
> >parallax
> Subject and Body of the message will be ignored.
In a message dated 11/3/2003 6:40:16 PM Pacific Standard Time, dokagaki@w... writes:
> Zero Input Force I think is what it stands for!
ZIF.....not that it matters but: Zero "Insertion" Force
--- In basicstamps@yahoogroups.com, "Brady,Steven [noparse][[/noparse]PYR]"
Zero
in
> sb
These would be great after he fixes the pin. a little bulky for a
finshed product, but a great device for testing when you move the
chip in and out of the device.
The reason they are popular with other micros is that many cannot be
easily programed unless you remove the chip, put it on a programmer
(seperate device) burn the program, then return it to your project.
since the Programmer only has the chip for a few minutes, the ZIF
reduces the potential for damaging pins.
I do have a ZIF (zero insertion force) socket that i use now. i have
several so i just solder those in place when i make a project. thanks. but
i want to know if parallax will repair my stamp.
>-Beau Schwabe
> >Gary,
> >work quickly.
> >John
Original Message
> > > , thanks Gary D
> > > >John
Original Message
> >parallax
, thanks Gary D
>John
Original Message
John
Original Message
work quickly.
John
Original Message
> , thanks Gary D
> >John
Original Message
parallax
-Beau Schwabe
>Gary,
>work quickly.
>John
Original Message
> > , thanks Gary D
> > >John
Original Message
>parallax
parallax
Dave
>parallax
>Dave
Dave,
for the Stamp.
-Beau Schwabe
sb
Original Message
From: Beau Schwabe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=j4C0m40WLldg3AtFNrEiAkPUL6eMZzEg-kA14sggAjAHp5WVfNn-ho9HDypfX3Q7yFJgRFTia0hc-6mpsj4tE98]bschwabe@a...[/url
directly.
-Beau Schwabe
>Gary,
>work quickly.
>at the time.
>John
Original Message
> > , thanks Gary D
> > >John
Original Message
>parallax
d...
Original Message
> sb
Original Message
> directly.
> -Beau Schwabe
> >Gary,
> >work quickly.
> >at the time.
> >John
Original Message
> > > , thanks Gary D
> > > >John
Original Message
> >parallax
_________________________________________________________________
that....remember to pick up jam at store....yup [noparse];)[/noparse]
sb
Original Message
From: smartdim@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_2NyiWE2JDLabgzqGz_HI4dCLpUyM6Q1RkXAR3ZSHrR0p2EaGFTHm7117ZIzHJlKWXjBEgfNjnBY]smartdim@a...[/url
Sent: November 3, 2003 7:23 PM
Zero
in
> sb
more than you wanted to know ?
Dave
>-Beau Schwabe
> >Gary,
> >work quickly.
> >John
Original Message
> > > , thanks Gary D
> > > >John
Original Message
> >parallax
