Pinewood Derby/Raingutter Regatta timer?
Ok,
like some of you may also be, I'm a dad with a 7yr old in cub scouts. I
recently got picked to create the Raingutter Regatta (that'll teach *me*
to show up to meetings on time! [noparse]:)[/noparse] which is like a pinewood derby except
with two raingutters and the boats are powered by the kids using their
lungs to blow the boat down the track.
Anyway, I's like to use a Basic Stamp to make a "winner" detector that
would take the "judges" out of the picture so no one can complain of
favoritism. [noparse]:)[/noparse] So, before I go about re-inventing the wheel, does anyone
have a bit of code or schematic for something like this?
FWIW: I'm planning on using two laser pointers as my "beam" source, a
couple of CDS or phototransister as receivers and a servo holding a
checkered flag at 90 degrees that will drop to 0 degrees or 180 degrees
to announce the winner. All I need is some code to tell me which sensor
is activated first. I have a BSI, a BSII and a BSIIsx that I could use
depending on need.
At first I though about polling inputs in a tight loop, but that would
allow the possibility of one input being detected as first when the other
one was actually first (depending on the loop position). Anyway, if
anyone has already done this and is willing to share the code, I'd be
much obliged! [noparse]:)[/noparse]
Vern
Vern Graner CNE/CNA/SSE | "If the network is down, then you're
Senior Systems Engineer | obviously incompetent so why are we
Texas Information Services | paying you? Of course, if the network
http://www.txis.com | is up, then we obviously don't need
Austin Office 512 328-8947 | you, so why are we paying you?" VLG
depending on need.
Vern
This is a very interesting and intriging question. But it is also a bit
hypothical.
I'll give you my thoughts from the 'waterland' Holland:
Think of the BS2sx running at about 10.000 instructions per second, so the
respons time of your time measurement system will probably be below 1 ms
with a tight loop.
Let us say that e small boat powerd by human breath will move at a speed of
10 centimeters per second. In a millisecond the boat will move 10 cm/1000 =
0.1 mm.
What is the diameter of the beam your laserpointers give and at which level
of accuracy are you able to position them? Probably the error here will be
much more much more than the 0.1 mm accuracy of the BS2sx.
So, my first thoughts say there will not be a real problem here.
Klaus
Oorspronkelijk bericht
Van: Vernon Graner [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=DIxj9keHgF4lWGXsn9sFl9fy_kpPvJepAHmzPAPxPxnYkTWyGwzag4_i98YtCBD1RS-S]vern@t...[/url
Verzonden: donderdag 9 oktober 2003 22:48
Aan: basicstamps@yahoogroups.com
Onderwerp: [noparse][[/noparse]basicstamps] Pinewood Derby/Raingutter Regatta timer?
Ok,
depending on need.
Vern
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Hi Vern,
This idea may not be popular here on the list, but maybe you don't
need a Basic Stamp for your winner detector. How about having the beam
break of each lane trip and latch a double poll, double throw relay? The
power to each relay coil could be wired in series through one set of
contacts of the other lanes relay - that way when one lanes relay tripped
it would disconnect and disable the other, preventing it from
tripping. The other set of contacts of each relay could operate the winner
flag. What do you think?
Tim
Timothy Medema
CrystaLite, Incorporated
3307 Cedar St. (425) 745-6000 800-666-6065
Everett, WA 98201 Fax: (425) 257-0232
www.crystaliteinc.com
<mailto:timm@c...>timm@c...
The information transmitted is intended only for the person or entity to
whom it is addressed and may contain confidential and/or privileged
material. Any review, retransmission, dissemination or other use of, or
taking of any action in reliance upon, this information by persons or
entities other than the intended recipient is prohibited. If you received
this in error, please contact the sender and delete the material from any
computer.
pinewood derby timer. I think it came from Nuts and Volts; check the
Parallax website. The code is quoted in full here; read the article
for a full description of how it works.
Michael
' Program Listing 24.2. BASIC for Beginners Race Timer with Display
' Program RACE2.BAS (Three-lane race timer with display)
' This program shows how the BS1 (or Counterfeit) can
' be used to time a three-lane Pinewood Derby race.
' It converts a raw count of program loops into
' units of 1/100th of a second and presents them on
' a serial LCD display.
SYMBOL time1 = w2 ' Word variable for lane-1 time.
SYMBOL time2 = w3 ' Word variable for lane-2 time.
SYMBOL time3 = w4 ' Word variable for lane-3 time.
SYMBOL start = pin7 ' Start-switch on pin 7; 0=start.
SYMBOL status1 = bit0 ' Status of lane 1; 1=racing, 0=done.
SYMBOL status2 = bit1 ' Status of lane 2; 1=racing, 0=done.
SYMBOL status3 = bit2 ' Status of lane 3; 1=racing, 0=done.
SYMBOL win = bit3 ' Flag to indicate race winner.
SYMBOL stats = b0 ' Byte variable containing status bits.
SYMBOL pos = b11 ' Printing location.
SYMBOL digits = b10 ' Digits to display.
SYMBOL timeDat = w1 ' Timing data to convert/display.
SYMBOL iPre = 254 ' Instruction prefix for LCD.
SYMBOL clrLCD = 1 ' Clear LCD screen.
SYMBOL blank = 8 ' Blank the LCD (but retain data).
SYMBOL restore = 12 ' Restore LCD.
SYMBOL topLft = 128 ' Move to top-left of LCD screen.
SYMBOL topRt = 136 ' Move to top-right of LCD screen.
SYMBOL btmLft = 192 ' Move to bottom left of LCD screen.
SYMBOL btmRt = 200 ' Move to bottom right of LCD screen.
begin:
stats = %111 ' All cars in the race to begin.
time1=0:time2=0:time3=0 ' Clear timers.
serout 3,n2400,(iPre,clrLCD) ' Clear the display.
pause 5
' The line below is sneaky--it prints "Race in Progress" to the
' LCD, then blanks the LCD so that the message is hidden. That
' way, the program can display the whole 16-byte message by just
' sending a 2-byte 'unblank display' instruction.
serout 3,n2400,("Race in Progress",iPre,blank)
hold:
if start =1 then hold ' Wait for start signal.
serout 3,n2400,(iPre,restore) ' Restore "Race in Progress" to LCD.
timing: ' Time the race.
stats = stats & pins & %111 ' Put lowest 3 pin states into stats.
if stats = 0 then finish ' If all cars done, then race over.
time1 = time1 + status1 ' If a car is in race (status=1) then
time2 = time2 + status2 ' increment its timer. If it's done
time3 = time3 + status3 ' (status=0) don't increment.
goto timing ' Loop until race over.
finish:
serout 3,n2400,(iPre,clrLCD) ' Clear display.
pause 5
serout 3,n2400,(iPre,btmRt,"-FINAL-") ' Print FINAL.
timeDat=time1: pos=topLft:gosub Display ' Display race times.
timeDat=time2: pos=topRt:gosub Display
timeDat=time3: pos=btmLft:gosub Display
END ' End program--reset to time another race.
' This subroutine converts the loop count in the variable timeDat
' into a number of hundredths of a second, then prints that value
' (as seconds, with decimal point) at the screen location specified
' by the variable pos.
Display:
serout 3,n2400,(iPre,pos) ' Move to display location.
if timeDat > time1 OR timeDat > time2 OR timeDat > time3 then noWin
serout 3,n2400,("*") ' Put * by winner (or winners, if tie)
goto skip1
noWin:
serout 3,n2400,(" ") ' Put space by non-winners.
skip1:
timeDat = timeDat*8/27 ' Convert to 100ths of a second.
digits = timeDat/100 ' Print hundreds place followed
serout 3,n2400,(#digits,".")' ..by decimal point.
digits = timeDat//100 ' Now print remainder.
if digits > 9 then skip0 ' If remainder is less than 10,
serout 3,n2400,("0") ' ..print "0" (i.e., convert
skip0: ' "6" to "06" for correct display.
serout 3,n2400,(#digits)
return ' Return to program.
--- In basicstamps@yahoogroups.com, "Vernon Graner" <vern@t...> wrote:
> Ok,
> depending on need.
other
> Vern
> other one was actually first (depending on the loop position).
Haven't tried it, Vern, but I think you had the right idea: poll in a tight
loop.
To get around the problem of seeing one pin change before the other, just
examine them both at once. Again, this is not tested code, but something very
like the code below should work. The important points are in this loop:
DO
TriggerValue=INA&%00000011
LOOP UNTIL 0<>TriggerValue
First, it captures the state of both input pins in the same instruction. (This
is not the same as "simultaneously".) Second, the pin values are moved into a
declared variable that will not change before we have time to examine it in code
that follows the loop. This code cannot resolve ties that occur within the short
time interval of that loop, but a millisecond is surely close enough for a
Raingutter Regatta, isn't it? Are you limiting bowsprit lengths?<g>
Good luck,
Gary
'{$STAMP BS2}
'{$PBASIC 2.5}
[noparse][[/noparse] The Finish Line ]
FlagHigh CON 1000 ' Or whatever pulse width causes your servo
' to raise the checkered flag
FlagLow CON 250 ' Again, substitute the calibrated pulse width
' for the flag low position in your servo
[noparse][[/noparse] Variables ]
TriggerValue VAR Byte
cntI VAR Nib
[noparse][[/noparse] Main Code ]
Main:
OUTS=%1111111111111111 'Preset high as a general practice to avoid problems
DIRS=%1111111111111100 'All outputs except the two trigger pins.
'At this point Pin0 and Pin1 are inputs, Pin2 is an output
GOSUB RaiseTheFlag
DO
GOSUB LowerTheFlag
IF 1=IN0 THEN
DEBUG "The RIGHT boat wins!",CR
ELSEIF 1=IN1 THEN
DEBUG "The LEFT boat wins!",CR
ELSE
DEBUG "Gary's code blew it somehow!",CR
ENDIF
END
RaiseTheFlag:
FOR cntI=1 TO 30
PULSOUT 2,FlagHigh
PAUSE 20
NEXT
RETURN
LowerTheFlag:
FOR cntI=1 TO 30
PULSOUT 2,FlagLow
PAUSE 20
NEXT
RETURN
> don't
> winner
> Tim
I built something like this early on in my electronics career (1979 ish!)
to use for a high school quiz show. We noticed that one of the channels
seemed to win more often and during some testing, found this actually was
the case.
It turned out that one of the relays had a little less spring tension so
it would tend to close quicker (that was the consensus when we couldnt
figure out why one channel was "sweeter" than the other). I'm sure this
would be ok, but I have to admit I have a hankerin' to do this with the
basic stamp so I can tell the folks a computer timer with laser sensors
will determine the winner! Just sounds more impressive... plus I have the
gear already, it's just a matter of cobbling it all together... [noparse]:)[/noparse]
Vern
would come through for (lazy!) me! [noparse]:)[/noparse]
Vern
webbm03 said:
> I found this code on the 'net the other day. It's a three-lane
> Michael
> begin:
> pause 5
> hold:
> finish:
> pause 5
> Display:
> goto skip1
> noWin:
> skip1:
>> Ok,
>> *me*
>> except
>> anyone
>> depending on need.
> other
>> Vern
the call I'd say.. [noparse]:)[/noparse] Thanx a bunch I've got some great starting points!
Vern
PS: When I get it done, I'll put up some pictures & share the final code...
Gary W. Sims said:
> From: "Vernon Graner" <vern@t...>
> tight loop.
> very like the code below should work. The important points are in this
> loop:
> DO
> (This is not the same as "simultaneously".) Second, the pin values are
> moved into a declared variable that will not change before we have time
> to examine it in code that follows the loop. This code cannot resolve
> ties that occur within the short time interval of that loop, but a
> millisecond is surely close enough for a Raingutter Regatta, isn't it?
> Good luck,
> Gary
> '{$STAMP BS2}
> '{$PBASIC 2.5}
> cntI VAR Nib
> Main:
> problems
> GOSUB RaiseTheFlag
> DO
> GOSUB LowerTheFlag
> IF 1=IN0 THEN
> ELSEIF 1=IN1 THEN
> ELSE
> ENDIF
> END
> RaiseTheFlag:
> FOR cntI=1 TO 30
> PULSOUT 2,FlagHigh
> PAUSE 20
> NEXT
> RETURN
> LowerTheFlag:
> FOR cntI=1 TO 30
> PULSOUT 2,FlagLow
> PAUSE 20
> NEXT
> RETURN
writes:
Hi Vern,
> don't
> winner
> Tim
the case.
Vern
If interested, I built such a device from a few logic gates and a 555 timer.
I can fax a schematic, but not until next week as I am out of my office until
then.
Ken
this example out of the archives, please note that I just realized I omitted
the test for the case where we have a tie and after talking about it at
length I used the input pins themselves instead of the capture variable.
The evaluation statement should read:
IF (1=TriggerValue) THEN
ELSEIF (2=TriggerValue) THEN
ELSEIF (3=TriggerValue) THEN
DEBUG "We have a tie!",CR
ELSE
ENDIF
Or using one of the features of PBasic 2.5:
SELECT TriggerValue
CASE =1
DEBUG "Left boat wins.",cr
CASE =2
DEBUG "Right boat wins.",CR
CASE =3
ENDSELECT
Just for the record<g>,
Gary
http://www.emesystems.com/BS2fsm.htm#Game%20show
At 08:19 PM 10/9/03 -0700, you wrote:
>Not to belabor the obvious about untested code, but in case someone digs
> ELSE
> ENDIF
>SELECT TriggerValue
> CASE =1
> CASE =2
> CASE =3
>ENDSELECT
>Gary
system (Thanks Gary! [noparse]:)[/noparse] I ended up using this code method (suggested by
Gary) to detect the sensors:
DO
Works great with a couple of toggle switches to stand in for sensors. The
only thing I face now is the actual design of the sensors.
I plan to use some low-cost LED laser pointers as the light source (I can
claim "laser" precision and also, hey it just *looks* cool!) but I'm
still trying to find a way to make a detector that will accurately
produce a binary 1 or 0 for the stamp to read depending on the
presence/absence of light from the pointer.
I tried CDS cells, but they seem to be intermittent and quite susceptible
to ambient light interference.
So, does anyone have a quick circuit that can be used to reliably detect
the light from a laser pointer?
Vern
might help you out. i used it for my laser perimiter alarm. circuit might
need minor alterations but to give you and idea. hope it works. Gary D
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Wednesday, November 12, 2003 3:30 PM
Subject: Re: [noparse][[/noparse]basicstamps] Pinewood Derby/Raingutter Regatta timer?
> Well I have the basic code all done for my Raingutter Regatta race winner
> DO
> Vern
http://www.turbodeuce.com/images/Laser_rcvr.JPG
Original Message
Sent: Wednesday, November 12, 2003 3:47 PM
> Now this is coming from a different Gary !! here is a simple circuit that
Original Message
winner
> > DO
The
can
susceptible
> > Vern
and
think this might be the better. Thanx again! [noparse]:)[/noparse]
Vern
Gary Denison said:
> forgot the link
Original Message
> From: "Gary Denison" <gdii@c...>
>> that
>> might
Original Message
> winner
>> by
>> > DO
> The
> can
> susceptible
>> detect
>> > Vern
> and
>> and
1000 mcd red LED,s connected directly to the pin and had good results.
Craig
> Message: 11
> Date: Thu, 13 Nov 2003 13:31:51 -0600 (CST)
> Subject: Re: Pinewood Derby/Raingutter Regatta timer?
> Cool! Thanx for the pic. I've been experimenting with CDS cells, but I
> Vern
required to make it sensitive enough to trigger a logic "1" or "0" to
the stamp pin? Just curious, since this sounds like a cool idea. Do
you tie the opposite end to "+" or GND? If you have a schematic
example or description, that would be cool... [noparse]:)[/noparse]
Vern
--- In basicstamps@yahoogroups.com, Craig Gardner <csgardner@a...>
wrote:
> You could also replace the photo transistor with an LED, I have
used
results.
> Craig
> > Message: 11
but I
> > Vern
exposing the die inside and activating them as a switch with a light bulb.
Certainly a very cheap phototransistor and probably good enough to detect a
pinewood derby car entering the field blocking the light. You need to bias
the base circuit just below the trigger level when blocked and with the lamp
on the die it should turn on the transistor. This is more sensitive than a
diode used to detect light in that you can bias the base circuit. With a
diode, you need to add gain with an op amp or transistor. Run each detector
into some ttl or cmos logic to accept the first one and your application is
done.
jim
http://www.geocities.com/jimforkin2003/
Original Message
From: Vern Graner [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=gFVHPhD6zdCxZ47H1rTtvLbTeszT9eqbu8_q5p7Dklko4lTRghg4iaPQCLMWiGZKaXjvDgEuWQ]vern@t...[/url
Sent: Friday, November 14, 2003 12:15 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Re: Pinewood Derby/Raingutter Regatta timer?
Does it matter what MCD rating the LED has? Is it the 1000mcd rating
Vern
used
results.
> Craig
> > Message: 11
but I
> > Vern
is being used as a receiver here not a transmitter. when the laser light
hits the photo transistor it provides a forward BIAS to the 2N2222A
transistor creating +V to whichever pin you have. you can replace the
resistor attached to the photo transistor with a 10K Pot for sensitivity
control. the photo transistor is prefered method for laser detecting circuits.
as i am about to use them in a Laser tag project. keep me posted on how you
project turns out.
>Vern
>used
>results.
> > Craig
> > > Message: 11
>but I
> > > Vern
