Checksum...
Hello Stampers,
How are you all today ?.
I have a query regarding a data checksum.
In the existing version of our data transfer setup, we do a checksum as
follows...
'_______________
checksum var byte
dataout var byte
for counter = 0 to 31 'get 32 bytes of data
get counter, dataout '
serout dataout 'send the data byte
checksum = checksum + dataout 'add to the checksum byte
next
serout checksum 'send the checksum byte
'______________
That works fine. But we are now sending data as ascii words and bytes, such
as,
serout dec wordofdata (or byteofdata)
I dont know how we can checksum this into a byte or word value. We are
receiving the data in VB6 on a pc.
Is there a simple answer ?
Cheers,
Chris Anderson
Western Australia
follows...
'_______________
checksum var byte
dataout var byte
next
'______________
as,
Cheers,
Chris Anderson
Western Australia
Checksum VAR WORD
DataValue VAR WORD
FOR Counter = 0 to 3
DataValue = 1234
SEROUT ... [noparse][[/noparse]DEC DataValue]
CheckSum = CheckSum + DataValue
NEXT
SEROUT ...[noparse][[/noparse] DEC CheckSum]
The only problem with this approach is:
how do you know where numbers begin and end?
Putting a 'comma' between values is the
'normal' VB way of doing it, I suppose.
The point is, as long as your VB side
can re-generate the decimal value that
is going to be sent to it as a CheckSum,
this approach will work.
--- In basicstamps@yahoogroups.com, Chris Anderson <fuel@b...> wrote:
> Hello Stampers,
checksum as
> follows...
> '_______________
> checksum var byte
> dataout var byte
of data
data byte
> next
checksum byte
> '______________
bytes, such
> as,
are
> Cheers,
> Chris Anderson
> Western Australia
The only problem I can see (or am I looking at it the wrong way), is that if
I send the word value 12345 as a decimal, The checksum will store its 2 byte
value, but it actually sends 5 bytes out as ascii.
Then when the pc receives it, it will pick up 5 bytes of data.
Chris
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Thursday, September 18, 2003 5:57 AM
Subject: [noparse][[/noparse]basicstamps] Re: Checksum...
> I believe you can do:
> Checksum VAR WORD
> DataValue VAR WORD
> DataValue = 1234
> NEXT
> > Hello Stampers,
> checksum as
> > follows...
> > '_______________
> > checksum var byte
> > dataout var byte
> of data
> data byte
> > next
> checksum byte
> > '______________
> bytes, such
> > as,
> are
> > Cheers,
> > Chris Anderson
> > Western Australia
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
value as a string, you can take it in and use the Val() function to
convert it. Of course, with variable-length values you know need some
kind of separating chacter that you can use to parse the data.
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: Chris Anderson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=zYmNp8y8xtAAuTR7BaXRDZpbHok1YsMUSXYF12C9cL9dQmAkaIFJxHAE5np18mpRiWErfWawBGQpQN5a]fuel@b...[/url
Sent: Wednesday, September 17, 2003 5:06 PM
To: basicstamps@yahoogroups.com
Subject: Re: [noparse][[/noparse]basicstamps] Re: Checksum...
Cheers Allan,
that if I send the word value 12345 as a decimal, The checksum will
store its 2 byte value, but it actually sends 5 bytes out as ascii. Then
Chris
Original Message
> Checksum VAR WORD
> DataValue VAR WORD
> DataValue = 1234
> NEXT
> > Hello Stampers,
> checksum as
> > follows...
> > '_______________
> > checksum var byte
> > dataout var byte
> of data
> data byte
> > next
> checksum byte
> > '______________
> bytes, such
> > as,
> are
> > Cheers,
> > Chris Anderson
> > Western Australia
> and
and Body of the message will be ignored.
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
Briefly, What does the Val function actually do to the data received ?
Cheers,
Chris
Original Message
Sent: Thursday, September 18, 2003 6:22 AM
Subject: RE: [noparse][[/noparse]basicstamps] Re: Checksum...
> So long as your VB program understands that it is receiving the numeric
> -- Jon Williams
> -- Dallas Office
Original Message
> From: Chris Anderson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=LN72Msd0sGslFQ1BzTAlkMtzAP5hern4v7GZsO2ffMJRUt5bZ26sqx7WwQ5S43FuTNfRkQBuEYdbLVId]fuel@b...[/url
> Cheers Allan,
> Regards,
> Chris
Original Message
> From: "Allan Lane" <allan.lane@h...>
> > Checksum VAR WORD
> > DataValue VAR WORD
> > DataValue = 1234
> > NEXT
> > > Hello Stampers,
> > checksum as
> > > follows...
> > > '_______________
> > > checksum var byte
> > > dataout var byte
> > of data
> > data byte
> > > next
> > checksum byte
> > > '______________
> > bytes, such
> > > as,
> > are
> > > Cheers,
> > > Chris Anderson
> > > Western Australia
> > and
> abuse@p....
monitor your comm input string waiting for the terminating character
(the character that separates values. Everything ahead of that
character should be digits and you can apply use the Val function to
extract it.
So ... you may want to do somethng like this when sending data to the
PC:
SEROUT pin, baud, [noparse][[/noparse]DEC value, ", "]
What you can do is use your OnComm event to look at the last character
received to see if it is a comma.
-- Jon Williams
-- Dallas Office
Original Message
From: Chris Anderson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=vd3tIq3mAmqyEZeblLRpLN2HrEL7YsaA6KnBM_vgjMKYwjEHaevDviYwAvLI2iyZV8ZWVjm_oAFQKmqghw]fuel@b...[/url
Sent: Wednesday, September 17, 2003 5:27 PM
Hello Jon, and thanks,
Cheers,
Chris
Original Message
> numeric value as a string, you can take it in and use the Val()
> function to convert it. Of course, with variable-length values you
> know need some kind of separating chacter that you can use to parse
> the data.
> -- Jon Williams
> -- Dallas Office
Original Message
> Cheers Allan,
> Regards,
> Chris
Original Message
> > Checksum VAR WORD
> > DataValue VAR WORD
> > DataValue = 1234
> > NEXT
> > wrote:
> > > Hello Stampers,
> > checksum as
> > > follows...
> > > '_______________
> > > checksum var byte
> > > dataout var byte
> > of data
> > data byte
> > > next
> > checksum byte
> > > '______________
> > bytes, such
> > > as,
> > are
> > > Cheers,
> > > Chris Anderson
> > > Western Australia
> > Subject and
> abuse@p....
> and
abuse@p....
We actually already send the comma's to create the csv file.
I think you are saying...
1- We send the data as "dec wordofdata",","
2- We checksum wordofdata at the stamp.
3- VB takes each value before a comma and converts it to a number.
4- We then use simple division of 65535 etc to end up with a word value for
the checksum.
Is that feasible ?
Chris
Original Message
Sent: Thursday, September 18, 2003 6:32 AM
> Val will convert string data into a number. What you'll have to do is
> extract it.
> PC:
> -- Jon Williams
> -- Dallas Office
Original Message
> From: Chris Anderson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=GEl1cylLMK7YIh5Yhl8ytF5FK8-n7JbYhzhs8B0RqHCw_xEQKXKG7rv4ULkcY60IEg6OGYNB1EvRxzDeDQ]fuel@b...[/url
> Cheers,
> Chris
Original Message
> From: "Jon Williams" <jwilliams@p...>
> > the data.
> > -- Jon Williams
> > -- Dallas Office
Original Message
> > Cheers Allan,
> > Regards,
> > Chris
Original Message
> > > Checksum VAR WORD
> > > DataValue VAR WORD
> > > DataValue = 1234
> > > NEXT
> > > wrote:
> > > > Hello Stampers,
> > > checksum as
> > > > follows...
> > > > '_______________
> > > > checksum var byte
> > > > dataout var byte
> > > of data
> > > data byte
> > > > next
> > > checksum byte
> > > > '______________
> > > bytes, such
> > > > as,
> > > are
> > > > Cheers,
> > > > Chris Anderson
> > > > Western Australia
> > > Subject and
> > abuse@p....
> > and
> abuse@p....
you'll want to use the modulus operator. When you retrieve a data value
from the stream you can update your (VB) checksum value like this:
checkSum = (checkSum + newVal) Mod 256
If you use a word-sized checksum that the Mod value will be 65536.
-- Jon Williams
-- Dallas Office
Original Message
From: Chris Anderson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=oP8GFYquypz-xF_jWe0NQ2Afe6z6TQJkpd4EhnyB5R2GOUgqmhhGZS7MKWDdpZYpx-YrjiFpIIousw]fuel@b...[/url
Sent: Wednesday, September 17, 2003 5:40 PM
Cheers, Jon,
for the checksum.
Is that feasible ?
Chris
Original Message
> extract it.
> PC:
> -- Jon Williams
> -- Dallas Office
Original Message
> Cheers,
> Chris
Original Message
> > the data.
> > -- Jon Williams
> > -- Dallas Office
Original Message
> > Cheers Allan,
> > Regards,
> > Chris
Original Message
> > > Checksum VAR WORD
> > > DataValue VAR WORD
> > > DataValue = 1234
> > > NEXT
> > > wrote:
> > > > Hello Stampers,
> > > checksum as
> > > > follows...
> > > > '_______________
> > > > checksum var byte
> > > > dataout var byte
bytes
> > > of data
> > > data byte
> > > > next
> > > checksum byte
> > > > '______________
> > > bytes, such
> > > > as,
> > > > We
> > > are
> > > > Cheers,
> > > > Chris Anderson
> > > > Western Australia
> > > Subject and
> > Subject and Body of the message will be ignored.
> > abuse@p....
> > Subject and
> abuse@p....
> and
abuse@p....
Cheers from sunny West Oz
