serial cable color coding
Would anyone happen to know of a resource that lists the standard serial
cable color coding?
_________________________________________________________________
Send and receive larger attachments with Hotmail Extra Storage.
http://join.msn.com/?PAGE=features/es
cable color coding?
or JAPAN STANDARD or CANADIAN STANDARD or USA STANDARD ?
Original Message
From: Christian Wentz [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=L0I3_Jf7AcQfj4D4j4sIbYzbSWGJB8AaWYv5tPnUNKdeKvZPKjTtaP66QPl1ik5Pgdpx0qhSgQIaSgZ_h5dx]cwentz86@h...[/url
Sent: Saturday, September 13, 2003 7:19 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] serial cable color coding
cable color coding?
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
me would do them (at least the first 10) in resistor color code, black,
brown, red, etc.
Al Williams
AWC
* Control 8 servos at once: http://www.al-williams.com/pak8.htm
Original Message
> From: Christian Wentz [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=OHdg7x65FVcKQGLkB0l9AZZKO_RSk4coOG9xSWngRk1SX3knG8tKg8Yc1P7p8w3uipSwSD0scOhDBgNv]cwentz86@h...[/url
> Sent: Saturday, September 13, 2003 6:19 PM
> standard serial
> cable color coding?
> Subject and Body of the message will be ignored.
exception of marking pin 1 on ribbon cables, and the color of power
supply and fan wiring. Everything else is probably gonna be factory or
manufacturer specific.
What Jim is trying to say is that because everyone has a different color
code, you need to use an ohm meter or continuity tester to figure out
what color wire goes to which pin on the cable that you have.
> Yea, It's call an OHM METER. Would that be CHINA STANDARD or KOREA STANDARD
> cable color coding?
And don't get me started on the metric versus US electricity.
> I don't think there is a standard, but an old tech who used to work for
> brown, red, etc.
> > standard serial
> > cable color coding?
alw@a... writes:
brown, red, etc.
Al Williams
AWC
I do the same, and think it is a good idea. If you are consistent with this
method, at least one knows number 1 through 10
If you look a telephoneman splicing hundreds of wires , they follow
a color code scheme.
Perhaps there is an ANSI standard (they have standards for almost
everythinng).
cable, you'd better have a standard for what pair
of wires goes where. If you're installing a
50 foot 8-wire cable between a PC and a Modem, you have
a lot more lattitude.
If you are installing an "RS-232" "Standard" cable
(ansi standard RS-232, RS-232b, RS-232c) well:
You could install a DB25 with all pins connected,
all pins defined -- but I don't think they spec
the color.
You could install a DB25 with only the common 8
lines -- RX,TX, CTS,RTS, DCD,DTR,DTS, and Ground.
Oops, forgot 'RI' (ring) used by the PC as IRQ input.
Or you could do DB9. Or you could do RJ45 (like
DEC and Stallion did). Or you could do 'three-wire'
(TX, RX and Ground).
The point is: the RS-232 'Standard' came out so
early that it's evolved quite a lot, and been
used in MANY form factors. It's amazing
that it's as portable, and still works, as it is.
There IS a specification, but I really don't think
it calls out wire colors.
--- In basicstamps@yahoogroups.com, "Albert Catano"
<acatano2002@y...> wrote:
> I do not think the color coding of cables is arbitrarily.
follow
> everythinng).
to color standard ! But I can't find anything. I have used wire color to pin
numbers, but can't find the chart, and it wasn't specific to rs232.
Larry Gaminde
Original Message
To: "Basic Stamp List" <basicstamps@yahoogroups.com>
Sent: September 13, 2003 6:28 PM
Subject: RE: [noparse][[/noparse]basicstamps] serial cable color coding
> There is no general standard for wire color on PC cabling, with the
STANDARD
> > cable color coding?
With a roll of cable at my feet
If I should die before I wake
White, Blue, Orange, Green, Brown, Slate.
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Sunday, September 14, 2003 8:23 AM
Subject: [noparse][[/noparse]basicstamps] Re: serial cable color coding
> If you are a telephone man, with a 50-pair telephone
> the color.
> follow
> > everythinng).
Each factory lot will use the same color sequence, but different
factories/lots will vary. We use a M-F DB9 cable for a commercial
device, by cutting the cable at one end, discarding the connector, and
wiring the cable to our circuits, using a few hundred per year. We try
to buy from the same place, but periodically check the colors and pins
to avoid circuit disasters. We like and use black cables from Jameco,
to match our black instrument cases.
Dennis
Original Message
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=FmrytL7QLfgUs1sJp5oYCdZLUDbW_U7ffyheg03TSRnZ2KqzzdSfMnye_6XC6f75-KcH1pVU3QL_Slq5vkilbVTR9IqjNw]allan.lane@h...[/url
Sent: Sunday, September 14, 2003 8:24 AM
the color.
follow
> everythinng).
Most everything I see has molded ends, which means you have to chop off
one end and put on a fresh connector if you need to make a custom cable.
> As Allan and others have said, there is not a standard for wire colors.
boys -- Brown -- 1
race -- Red -- 2
our -- Orange -- 3
young -- Yellow -- 4
girls -- Green -- 5
behind -- Blue -- 6
victory -- Violet -- 7
garden -- Gray -- 8
walls -- White -- 9
Above is a non-bawdy version of the resistor
numbering color sequence, which DOES NOT apply
(necessarily) to RS-232. ("Bad boys rape our
young girls, but violet gives willingly" is
the 'PG-13' version)
Note that CAT-5 cable has Orange/Orange-Stripe,
Blue/Blue-Stripe, Green/Green-Stripe,
Brown/Brown-Stripe. This CAN be used for
RS-232 also.
--- In basicstamps@yahoogroups.com, "Stephen H Chapman"
<chapman@t...> wrote:
> Now I lay me down to sleep
Original Message
> From: "Allan Lane" <allan.lane@h...>
> > the color.
> > follow
almost
> > > everythinng).
Subject and
There are many variations on the Bad boys... I have also heard Bad Beer
Rots Our Young Guts but Vodka Goes Well.
Bad Betty runs over your garden but Violet Gray won't
Billy Brown Revives On Your Gin, But Values Good Whisky
Better Be Ready, Or Your Great Big Venture Goes West
Black Beetles Running On Your Garden Bring Very Good Weather
The one about batman is unrepeatable but the clean version is
Batman Bests Robin On Yonder Gotham Bridge; Very Good, Will Get
Superman Next
Al Williams
AWC
* Add floating point math to your Stamp program:
http://www.al-williams.com/pak1.htm
Original Message
> From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=XlnSmZBlTCLZtiTaoYfCzkIkPVPn2BL1yCuNR1emK2ZhDrom9vbdEt2mE_m4U8SvbYxvozGLG9lgiLn_l1-d6wAHWHE]allan.lane@h...[/url
> Sent: Monday, September 15, 2003 10:09 AM
> Bad -- Black -- 0
> boys -- Brown -- 1
> race -- Red -- 2
> our -- Orange -- 3
> girls -- Green -- 5
> behind -- Blue -- 6
> garden -- Gray -- 8
> walls -- White -- 9
> RS-232 also.
Original Message
> > > the color.
> arbitrarily. If you
> > > follow
> almost
> > > > everythinng).
> Subject and
Larry Gaminde
Original Message
Sent: September 15, 2003 10:31 AM
Subject: RE: [noparse][[/noparse]basicstamps] Re: serial cable color coding
> I collect these.
> Superman Next
> Al Williams
> AWC
Original Message
> > From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=NOcWQOhv4Mxv5xa3_zLVDHdyta_dqLekdkipYqrlFZGVT44sauoKZSKMybl9gZzTb-x2opcS6f3aej9mz5N3jA9Q]allan.lane@h...[/url
> > Bad -- Black -- 0
> > boys -- Brown -- 1
> > race -- Red -- 2
> > our -- Orange -- 3
> > girls -- Green -- 5
> > behind -- Blue -- 6
> > garden -- Gray -- 8
> > walls -- White -- 9
> > RS-232 also.
Original Message
> > > > the color.
> > arbitrarily. If you
> > > > follow
> > almost
> > > > > everythinng).
> > Subject and
> I collect these.
> Superman Next
