Anyone use a Displaytech 204 LCD 4X20?
Anyone use one? They're on sale at my electronics parts store and I'm
wondering if they are Hitachi 44780 compatible.
Any info apprecitated
thanks
elfa
thanks
elfa
> thanks
> elfa
Looking at the spec sheet at
http://www.displaytech.com.hk/
it appears they use the HD44780 protocol.
The one thing that I couldn't find is whether the voltage on term 3
(for contrast) is nominally +0.3 VDC or it requires a negative bias.
If it requires a negative bias, you might use a ICL7662 or TC7662 to
generate -5.0 from +5 VDC and feed this to terminal 2 of the LCD using
a series potentiometer of 4.7K.
If they have 16 terminals, they may well have an LED backlight as well.
Peter H Anderson, http://www.phanderson.com/stamp/
require the negative contrast voltage. Most of the others will work fine
by grounding the contrast pin, although a 10k pot used as a voltage
divider will allow you to adjust the contrast to just about any viewing
angle.
If you need a negative contrast voltage and have a MAX232 chip on board,
you can suck -9 volts off it for this purpose.
Pin 3 can be grounded for max contrast (which is what
I did). My problem is that it won't work with a
program written for a Hitachi 44780 LCD and I don't
know if I have a bad display and will be forced to buy
another. When I checked the display codes for it, it
matches that of the 44780.
I emailed DisplayTech and asking the simple question
if it was 44780 and all they did was send me a spec
sheet without comment. But the spec sheet indicates
44780 display codes.
elfa
--- pha555 <pha@p...> wrote:
> --- In basicstamps@yahoogroups.com, "faulke"
> parts store and I'm
> > thanks
> > elfa
> voltage on term 3
> a negative bias.
> 2 of the LCD using
> backlight as well.
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
