lat/long calculations
Does a basic stamp have the math capability to calculate
distance/heading based on gps coordinates? I was thinking about
making an autopilot for my model boat.
http://www.al-williams.com/pak2.htm
Al Williams
AWC
* Measure 8 pulses at once
http://www.al-williams.com/awce/pak7.htm
Original Message
> From: bear_phillips [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZsHJflbJZ6mwInOTfOctHoE-HLsDODnpR-1jJHowC6wmmlI_2BqtdJIKIHjCV0pd5Nn1mJzIUfa2qXb2RnI]bear_phillips@y...[/url
> Sent: Wednesday, September 10, 2003 12:52 PM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] lat/long calculations
> about making an autopilot for my model boat.
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the
> Subject and Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
I am trying to do the same. I looked at Trimble Navigation Ltd, and
they have a device ($75.00) called Lassen LP GPS that can be
connected via an RS-232 and download GPS coordinates. I think
that the Stamp is capable of accessing this information. I am still at
the stage of collecting information and resources.
I am a model boat builder also and I would like to do something like
from the same email address that you subscribed. Text in the Subject and Body
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
For informations about GPS see the large web links collection
(files, sofware, code, ....) of Peter Bennett at:
http://vancouver-webpages.com/peter/
For stamp acquisition, you can use the so-called NMEA0183 format which
is commonly used by most GPS. This format gives the date, the position,
the altitude and other GPS informations in an ASCII format that could
be easily understand by STAMP by using SERIN/SEROUT commands.
Emmanuel
On Wed, 10 Sep 2003, John Colonias wrote:
> Hi,
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=4668&item=3045615146
I borrowed my neighbors and was able to get GPS data to my BS2 with basic
serial routines. All of the data you mention is sent out by the GPS
Fritz
Original Message
To: <basicstamps@yahoogroups.com>
Sent: 10 September, 2003 13:51
Original Message
Cc: "Laurent Emmanuel" <elaurent@o...>
Sent: Wednesday, September 10, 2003 10:25 PM
Subject: Re: [noparse][[/noparse]basicstamps] lat/long calculations
> Hi,
> Emmanuel
> > Hi,
I can't get on that web site. Is there something wrong with it? It gives me an
error in
item 3045615146. The msg says that this item is not posted.
Any suggestions?
John
On 10 Sep 2003 at 21:46, Fritz Braun wrote:
See the GPS Development kit offered here:
Fritz
Original Message
Try
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=4668&item=3046643776
It appears that first link I sent you was already sold. They have a new one
on. In any case if you have trouble, go into eBay and do a search on item#
3046643776
Fritz
Original Message
Sent: 11 September, 2003 10:18
> Fritz,
me an error in
> Any suggestions?
> John
> Fritz
Original Message
> From: "bear_phillips" <bear_phillips@y...>
and
Thanks. I got it. I might buy one too.
John
On 11 Sep 2003 at 21:09, Fritz Braun wrote:
Hello John
Try
3046643776
Fritz
Original Message
> Fritz,
me an error in
> Any suggestions?
> John
> Fritz
Original Message
and
