Measuring long pulses
If this were a pic project, then I would say use something along the lines
of read on pin change state.
Brian
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.512 / Virus Database: 309 - Release Date: 8/19/2003
Brian
I'm trying to build a stamp based system to display on an LCD some error code
that a unit gives out.
The output the unit gives are a series of short pulses (around 3Hz) for about
two seconds, thi is the start sequence.
It then goes low for one second.
Then it goes high for one second and low for one second (ie 1/2 Hz), it does
this several times as a count.
It then goes low for 3 seconds.
Then it does its 1/2 Hz pulses as a second count output.
Finally it does a series of 3Hz pules again to end.
The unit output is designed to be connected to an LED to read the error codes by
eye and then look them up in a manual.
What I'm trying to do is make a LCD display give text descriptions that relate
to the codes.
I thought it would be easy using the PULSIN command but on a BS2 it can only
read pulses up to 655 ms!!
Even RCTIME does not go long enough. I've also got some of Al's PAK7 and this
too doesn't go that long...
I'm now a bit stuck as to how to do it...
Any ideas greatfully recieved...
Cheers all
Kev/.
but I've not made the switch yet...
Kev/.
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Sunday, September 08, 2002 7:54 PM
Subject: Re: [noparse][[/noparse]basicstamps] Measuring long pulses
> Brian
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
David Lawrence. This chip will generate
a 100 mSec square wave, which you can use
to synchronize a counter in your Stamp.
It's an 8-pin DIP, which comes with a
6 MHz resonator.
The beauty of this approach is you get
a relatively accurate 50 mSec 'tick'.
You then use these to time the pulses
coming in on the LED 'blink' line.
--- In basicstamps@yahoogroups.com, "Kev Pearce \(kevp.com\)"
<email.me@k...> wrote:
> Hi all,
error code that a unit gives out.
for about two seconds, thi is the start sequence.
Hz), it does this several times as a count.
error codes by eye and then look them up in a manual.
that relate to the codes.
can only read pulses up to 655 ms!!
PAK7 and this too doesn't go that long...
> Cheers all
> Kev/.
is used for email. In many email systems it is a pain
to track down an unread message its date is incorrect.
Bob Pence
Controls Engineer
> Brian
> Date: 8/19/2003
> removed]
> Text in the Subject and Body of the message will be
> ignored.
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
wrote:
> Folks, please check your system clocks if your system
> Thanks,
> Bob Pence
> Controls Engineer
Maybe, but if we keep our clocks a few minutes slow, (Take note Al)
then we can post a reply BEFORE the question is asked !
Now, Al can take his time and still be the first to respond. kinda
takes the fun outta races though.
Dave
I seem to remember a sci-fi short story some years back where a chemical
reaction would take place a fraction of a second before two solutions were
combined. If you tried to fake it out by starting the mixing sequence but
not actually pipetting the active agent into the test tube, the reaction
never occurred. But if you did actually go through with the mixing action,
sure enough, the solution would start reacting a second before the liquids
actually touched.
Now if I could only figure out how to do this for lottery tickets....
Perhaps with a day or so "pre-reaction" time. ;o)
Mike Sokol
www.modernrecording.com
Original Message
Sent: Monday, September 08, 2003 12:05 PM
Subject: [noparse][[/noparse]basicstamps] Re: Measuring long pulses
> --- In basicstamps@yahoogroups.com, Pence Bob <bobpence_2000@y...>
> > Thanks,
> > Bob Pence
> > Controls Engineer
> Dave
Our Co-Processor has 8 timers that can be read back out. You could
start one for max time (5.1 seconds = 255 * 20 ms) and watch for the
input signal to change. When it does, read the timer value and reset
it for the next pulse time to be read. You can get the details at
www.bluebelldesign.com or email me. The benefit of using the Co-
Processor is that you could do other things with the Stamp while
still timing the inputs.
If you aren't trying to do anything else while timing the pulses you
could do a program counting loop with a PAUSE in it to delay for
some number of ms. Counting a byte variable with a delay of 20 ms
gives 20 ms resolution (probably more than enough) up to 5.1 seconds.
Harry
Stamp Robotics to the next level
> Hi all,
3Hz) for about two seconds, thi is the start sequence.
it can only read pulses up to 655 ms!!
> Cheers all
> Kev/.
Harry
> Hi all,
> Cheers all
> Kev/.
