Basic I/O problem
I am very new to writing code for the basic stamp. I am trying to do
a simple 2 in 2 out using the BS2. I wrote the code listed below and
each output (14 & 15) will flash, but if both inputs (buttons)are
pressed at the same time the outputs follow each other. I understand
that the program runs from top down, but is there a way to allow each
input to control it's specified output regardless of where it is in
the program and independently? Am I way off base with
the "IF" "THEN"?
' {$STAMP BS2}
' {$PBASIC 2.5}
DO
IF (IN3 = 1) THEN
HIGH 14
PAUSE 500
LOW 14
PAUSE 500
ELSEIF (IN3 = 0) THEN
LOW 14
ENDIF
IF (IN4 = 1)THEN
HIGH 15
PAUSE 50
LOW 15
PAUSE 50
ELSEIF (IN4 = 0)THEN
LOW 15
ENDIF
IF (IN5 = 1) THEN
HIGH 13
PAUSE 500
LOW 13
PAUSE 50
ELSEIF (IN5 = 0) THEN
LOW 13
ENDIF
PAUSE 50
LOOP
the "IF" "THEN"?
' {$STAMP BS2}
' {$PBASIC 2.5}
DO
IF (IN3 = 1) THEN
HIGH 14
PAUSE 500
LOW 14
PAUSE 500
LOW 14
ENDIF
IF (IN4 = 1)THEN
HIGH 15
PAUSE 50
LOW 15
PAUSE 50
LOW 15
ENDIF
IF (IN5 = 1) THEN
HIGH 13
PAUSE 500
LOW 13
PAUSE 50
LOW 13
ENDIF
PAUSE 50
LOOP
OUTD, or IND (thus reading 4 bits at a time,
and setting 4 bits at a time).
'A' is 0..3, 'B' is 4..7, 'C' is 8..11,
and 'D' is 12..15.
So, if you say:
DIRA = %0000 ' Make pins 0..3 inputs
DIRD = %1100 ' Make pins 15, 14 as outputs
MyVar VAR NIB
MainLoop:
MyVar = INA
OUTD = MyVar
GOTO LOOP
' Then, you'll read 4 pins at a time,
' (only really using 2) and write
' 4 pins at a time (but only 2 of them
' will be outputs.
do
and
understand
each
> the "IF" "THEN"?
> ' {$STAMP BS2}
> ' {$PBASIC 2.5}
> DO
> IF (IN3 = 1) THEN
> HIGH 14
> PAUSE 500
> LOW 14
> PAUSE 500
> LOW 14
> ENDIF
> IF (IN4 = 1)THEN
> HIGH 15
> PAUSE 50
> LOW 15
> PAUSE 50
> LOW 15
> ENDIF
> IF (IN5 = 1) THEN
> HIGH 13
> PAUSE 500
> LOW 13
> PAUSE 50
> LOW 13
> ENDIF
> PAUSE 50
> LOOP
construct because your test variables (inputs) have only two states.
IF-THEN-ELSEIF is appropriate when your test variable can have more than
two states or you are testing more than one variable. And in truth,
your code doesn't even need the ELSE clause because the THEN portion
always leaves the LED off when it's finished (which is what your ELSE
section was doing).
Corrected, here's what on chunk of your loop would look like (Note that
I have added code to make things more readable and easier to update):
' {$STAMP BS2}
' {$PBASIC 2.5}
BtnA PIN 3
LedA PIN 14
Pressed CON 1
LedDelay CON 500
LoopDelay CON 50
Main:
DO
IF (BtnA = Pressed) THEN
HIGH LedA
PAUSE LedDelay
LOW LedA
PAUSE LedDelay
ENDIF
' other buttons / tests
PAUSE LoopDelay
LOOP
As Allan pointed out in his post, you can use parallel I/O groups to
prevent the inter-LED delays caused by sequential code.
' {$STAMP BS2}
' {$PBASIC 2.5}
Btns VAR INA
Leds VAR OUTD
LedDelay CON 500
LoopDelay CON 50
Setup:
Leds = %0000
DIRD = %1111
Main:
DO
Leds = Btns
PAUSE LedDelay
Leds = %0000
PAUSE LedDelay
LOOP
Notice that this code requires a bit of setup for the LEDs as the
program is not using HIGH and LOW which take care of making the
specified pin an output.
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: voltsguy [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=n1yIM-8yEO6DNte2xw6YqVNLmQd6Cu_tZ8ZrWDnVqMYQNv6Eg90bbnqA_9lCMX1KHee12f3e6G8c1Bul]brianr@d...[/url
Sent: Wednesday, September 03, 2003 7:15 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Basic I/O problem
the "IF" "THEN"?
' {$STAMP BS2}
' {$PBASIC 2.5}
DO
IF (IN3 = 1) THEN
HIGH 14
PAUSE 500
LOW 14
PAUSE 500
LOW 14
ENDIF
IF (IN4 = 1)THEN
HIGH 15
PAUSE 50
LOW 15
PAUSE 50
LOW 15
ENDIF
IF (IN5 = 1) THEN
HIGH 13
PAUSE 500
LOW 13
PAUSE 50
LOW 13
ENDIF
PAUSE 50
LOOP
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
couldn't verify the code.) The colon allows you to stack statements on the
same line, which works rather well.
You have to uses the DIRS statement to indicate that some of the pins are
outputs, otherwise they are all inputs and you can get some very flaky
results from the floating pins. I suspect the lack of a DIRS statement is
the source of your problem.
The inputs are scanned constantly until a button is pushed, whereupon the
light is on for 500 msecs and is then reset.
' {$STAMP BS2}
' {$PBASIC 2.5}
DIRS $1110000000000000
LOW 15 : LOW 14 : LOW 13
DO
IF (IN3 = 1) THEN HIGH 14 : PAUSE 500 : LOW 14
IF (IN4 = 1) THEN HIGH 15 : PAUSE 500 : LOW 15
IF (IN5 = 1) THEN HIGH 13 : PAUSE 500 : LOW 13
LOOP
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Wednesday, September 03, 2003 5:14 PM
> the "IF" "THEN"?
> ' {$STAMP BS2}
> ' {$PBASIC 2.5}
> DO
> IF (IN3 = 1) THEN
> HIGH 14
> PAUSE 500
> LOW 14
> PAUSE 500
> LOW 14
> ENDIF
> IF (IN4 = 1)THEN
> HIGH 15
> PAUSE 50
> LOW 15
> PAUSE 50
> LOW 15
> ENDIF
> IF (IN5 = 1) THEN
> HIGH 13
> PAUSE 500
> LOW 13
> PAUSE 50
> LOW 13
> ENDIF
> PAUSE 50
> LOOP
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
register bit for the specified pin so it is not necessary to deal with
DIRS if you choose to use HIGH and LOW. If, however, you want to work
with output bits directly, then setting the DIRS bit for your pin is
necessary.
-- Jon Williams
-- Dallas Office
Original Message
From: MarvL [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=S7TjHdtgl839r7gfi4xGt8r41S9UZLoTG0EhClEqt2KI0aWKJv9ZxVF9MNQ95ZG_qBJVazj3FN0]MarvL@m...[/url
Sent: Wednesday, September 03, 2003 9:18 PM
Subject: Re: [noparse][[/noparse]basicstamps] Basic I/O problem
Here's a cleaner version of the same code. (My Stamp is at work, so I
the same line, which works rather well.
are outputs, otherwise they are all inputs and you can get some very
flaky results from the floating pins. I suspect the lack of a DIRS
statement is the source of your problem.
the light is on for 500 msecs and is then reset.
' {$STAMP BS2}
' {$PBASIC 2.5}
DO
LOOP
Original Message
> I am very new to writing code for the basic stamp. I am trying to do a
> the program and independently? Am I way off base with the "IF" "THEN"?
> ' {$STAMP BS2}
> ' {$PBASIC 2.5}
> DO
> IF (IN3 = 1) THEN
> HIGH 14
> PAUSE 500
> LOW 14
> PAUSE 500
> LOW 14
> ENDIF
> IF (IN4 = 1)THEN
> HIGH 15
> PAUSE 50
> LOW 15
> PAUSE 50
> LOW 15
> ENDIF
> IF (IN5 = 1) THEN
> HIGH 13
> PAUSE 500
> LOW 13
> PAUSE 50
> LOW 13
> ENDIF
> PAUSE 50
> LOOP
> and
abuse@p....
