2 LCD displays
I have two Hitachi Compatible 2 x 16 displays, and a BS2p. I would like to
control both of them. I was thinking of controlling them this way
main:
' for lcd display one
LCDOUT 0, 1 [noparse][[/noparse]"Hello World"]
LCDOUT 0, 64+64 [noparse][[/noparse]"Two displays"]
' for lcd display two
LCDOUT 1, 1 [noparse][[/noparse]"Working"]
LCDOUT 1, 64+64 [noparse][[/noparse]"Together"]
end
This is just a thought. I think it should work. I am paining to connect R/W, RS,
and DB4-DB7 together. Hook E of display one to pin 0, and E of display two to
pin 1. I am trying to use as little of pins as possible.
If anyone thinks this will not work please let me know.
Thanks.
TC
main:
end
Thanks.
TC
initialize each before you can start writing to them.
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: Anthony Conti [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=UALOLoniLG-ynLoEku3hE-4UulDjZe7fOukiPNJo7H4xbLQWO0k0KDGMB_0qnBxuzyVK_b_22VbxZA]aconti@s...[/url
Sent: Tuesday, September 02, 2003 9:18 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] 2 LCD displays
to control both of them. I was thinking of controlling them this way
main:
end
R/W, RS, and DB4-DB7 together. Hook E of display one to pin 0, and E of
display two to pin 1. I am trying to use as little of pins as possible.
Thanks.
TC
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
single-board computer recently and thats exactly how they do it with two
displays. All the data lines and control lines are shared by both LCD's
except the E (enable) line. The LCD's are wired for 4-bit mode.
Not sure what goes on internally (they have a TSR that outputs DOS
printer calls to a single 10-pin connector), but I'll bet all they do is
select one display or the other with the enable line.
If you want some fun, get a 4x40 display. I found a couple locally at a
surplus place for $10. Although its a single LCD, the top two lines have
one complete Hitachi controller, and the bottom two lines have a second
complete Hitachi controller.
> main:
> end
RS, and DB4-DB7 together. Hook E of display one to pin 0, and E of display two
> Hook E of display one to pin 0, and E of display two to pin 1. I am trying to
-snip-
Perhaps better still, connect E of display 1 to pin 0 and invert pin 0 (a single
transistor inverter) and feed the inverted pin 0
signal to the second.
Make pin 0 high for one display and low for the other.
Matrix LK202 and simply giving each display a separate network address. And
it only takes 2 output pins.
I2COUT 8,$50,[noparse][[/noparse]"Hello World'"]
I2COUT 8,$51,[noparse][[/noparse]"Hello Mars"]
would do the trick. The default address is $50, but you can change it to any
of 127 values. You DO NOT need the memory position bit or submemory position
bit that are shown in the Stamp Basic syntax.
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Tuesday, September 02, 2003 7:18 PM
> main:
> end
> Thanks.
> TC
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
>-snip-
>-snip-
>single transistor inverter) and feed the inverted pin 0
That won't work in this case - the 'enable' line is actually the clock
(latch) line into the display controller. In other words, you have to
pulse the E line during each transfer. Thus, you will also be pulsing the
E line into the other unit.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 19 years of Engineering Innovation (1984 - 2003)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
through the parallax website. The problem I was having was differentiating
between sending text and sending LCD commands such as turning the backlight
on/off. Do you know how to format the data string for text output versus LCD
control commands?
Any help would be greatly appreciated.
MarvL <MarvL@m...> wrote:
You should also consider using an I2C compatible LCD such as the Orbital
Original Message
To:
> main:
> end
> Thanks.
> TC
from the same email address that you subscribed. Text in the Subject and Body of
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
the text. The 254 is apparently an escape character that alerts the LCD that
the next (few) characters are command bytes rather than displayable
character bytes.
I2COUT 8,$50,[noparse][[/noparse]254,88,"Hello World"] 'Clears the display and writes some
text
The only thing I haven't figured out, as yet, is that I still get an extra
character when I try to define the initial power on default screen.
Original Message
Sent: Thursday, September 04, 2003 8:23 AM
Subject: Re: [noparse][[/noparse]basicstamps] 2 LCD displays
> I recently tried using the I2COUT command with the Orbital Matrix LCD
available through the parallax website. The problem I was having was
differentiating between sending text and sending LCD commands such as
turning the backlight on/off. Do you know how to format the data string for
text output versus LCD control commands?
And
any
position
Original Message
> From: "Anthony Conti"
> To:
to
> > main:
> > end
> > Thanks.
> > TC
> Do you Yahoo!?
