How to wait for a signal?
Dear Freinds, Hi
I just registered in this group and this is my first message.
In my program I have to wait 30sec and if non of the input pins give
stamp a command, I should finish the program and turn of a relay.
I am not sure if there is a special command for these situations?
I am using a for-loop to check all the inputs each 100ms.
Please let me know if you have better suggestion.
Thank You Nima
Thank You Nima
parallax.com's download section. This is in there, but anyway:
serin 1,16428,2000,NoData,[noparse][[/noparse]dec mydata]
debug "got the data!",cr
stop
NoData:
debug "didn't get data within 2 seconds!",cr
you can change the 2000 number to reflect different times to wait for
data before stopping the wait.
--- In basicstamps@yahoogroups.com, "NIMA" <nimjah@y...> wrote:
> Dear Freinds, Hi
give
> Thank You Nima
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
232-type signal on each of the input pins -- is that
the case?
If you're looking for a level change (0 to 5V or
5V to 0) then the given solution won't work for you.
Also, you can only 'look' for a 232 type signal one
pin at a time, since (as you should be aware) the BS2 is
a single-tasking beast. This means it can only accept
232 signals on the pin it is listening to at the time.
There IS a 'timeout' parameter used in the example --
but that just gives the 'sender' a window to send data
in before it monitors the next pin.
> Dear Freinds, Hi
give
> Thank You Nima
