Need help troubleshooting Ports on BS2
Hi,
I have a BS2 and feel that the ports P0 - P15 are not working.
How do i trouble shoot this ?
Can I use a simple program like this.
Any help with circuits and sample code will be appreciated.
Kiran
X
X
'{$STAMP BS2}
'{$PORT COM2}
back:
output 1
high 1
debug "state of pin 1 is ", bin out1, cr
pause 2500
low 1
pause 2500
goto back
X
End Cut and Paste
X--
Kiran
X
X
'{$STAMP BS2}
'{$PORT COM2}
back:
output 1
high 1
pause 2500
low 1
pause 2500
goto back
X
End Cut and Paste
X--
kiranshash@y... writes:
Connect a 5V LED from any pin to ground (Vss). If it is not resistorized add
a 270 ohm resistor in series, Then write
x var byte
start:
for 1 = 1 to 100
high pin whatever
pause 500
low pin whatever
pause 500
goto start
Make sure that at the very beginning you declare the Stamp, BS2, BSE, or
whatever you are using. Also declare the language, 2.0 or 2.5.
Sid Weaver
W4EKQ
Port Richey, FL
The reason for this is that it exercises both the output and input
capabilities of a pin. If there's a problem, it will show up using
RCTIME. GOTO the files section on Yahoo! Groups and download
Pin_Test.BS2 to see how this works.
-- Jon Williams
-- Parallax
Original Message
From: kiranshash [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0QiWfQXh-R_Fct0_UjzUojgLW1O7_539CZSU0MY2bf7Yd2_6Qy9-5bbAr6aMZykbSWtvzBfHreUsIA]kiranshash@y...[/url
Sent: Wednesday, August 27, 2003 2:00 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Need help troubleshooting Ports on BS2
Hi,
I have a BS2 and feel that the ports P0 - P15 are not working. How do i
Kiran
X
X
'{$STAMP BS2}
'{$PORT COM2}
back:
output 1
high 1
pause 2500
low 1
pause 2500
goto back
X
End Cut and Paste
X--
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
Kiran, do you have a BOE or just the Stamp module you have built up on a
board?
Sid
