Scan buttons with a busy BS2p
I need to check the conditions of 12 different buttons, but my BS2p
is very busy doing other tasks. In the Nuts and Volts #62 a 74165
shift register is used to scan a few buttons. Is this method also
taking care of the problem around "buttons pushed – not detected",
due to over work.
Stein.
due to over work.
Stein.
Stein_Frostad@m... writes:
I must use pulse buttons.
I was also thinking about the RS flip flop 7474, but the required
PCB-space could be too big when I need room for 12. (Have not tried
it)
I'm also forgotten how to use the flip flop long ago.
The clear is obvious. Where should I connect the button in?
What about preset and Ck?
What about noise and ripple when I push the button.
Is there a Nuts and Volts project or other application explaining
how this is done?
Stein.
--- In basicstamps@yahoogroups.com, smartdim@a... wrote:
> In a message dated 8/25/2003 11:57:39 AM Pacific Daylight Time,
BS2p
There are external chips and modules available that implement key
scanning so that all you have to do is read their results. A couple
of URLs...
http://www.solutions-cubed.com/Products/MEMKey/memkey_main.htm
http://www.elabinc.com/ede1144.htm
If you have 7 pins available on your Stamp, it is also possible to
implement scanning of a 3x4 key matrix in software. The trick for
not missing momentary key presses is to put capacitors as a "dynamic
memory" at the matrix cross points in parallel with the switches.
The software has to read the keys and recharge the capacitors. That
adds to the load for your processor of course, maybe 5 milliseconds
of processing time per iteration, and a few bytes of RAM for the
state machine.
-- Tracy
>My stamp is working with some serial transmissions using WAIT.
>it)
>The clear is o
>how this is done?
>Stein.
>BS2p
is not doing anything. Alternate that task between the others and
reading the button. If you do it fast enough it looks like it is doing
so many thing at one time.
On the hardware try use a decoder/multiplexer like 74154. I had a
design for scanning 72 keys of MIDI music keyboard and only use three
connections to the micro controller, up position, down position and
clock. It also measures the speed of the key pressed for velocity.
Heavy programming though. I can't share the full schematic because it
is a commercial design but you can get the idea from there.
- Johari
--- In basicstamps@yahoogroups.com, "stein_frostad"
> due to over work.
> Stein.
debounce and you get a snapshot in time of the switch states. You can
then break your program into tasks (called with BRANCH or ON-GOTO/GOSUB)
to process everything accordingly.
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: stein_frostad [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=yV8UWNjergE7bQG7Ind8zyvM46JNr7Lze7_amXyJaC6wbxtxcJUU7CO_gB1fyRyRLI-AT82WcDYA-h_z0YOlXaE]Stein_Frostad@m...[/url
Sent: Monday, August 25, 2003 1:52 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Scan buttons with a busy BS2p
taking care of the problem around "buttons pushed - not detected",
due to over work.
Stein.
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
One chip I like to use to read multiple keys is the MM74C922. It's an
oldie but a goodie. You can have it scan 16 keys and it has a register
to remember the key pressed and a data available line will tell you
when you have activity. It's brother the MM74C923 can handle 20 keys
and the data sheet shows how to expand even further.
> taking care of the problem around "buttons pushed ? not detected",
> due to over work.
> Stein.
