Memsic 2125 and Velocity
Has anyone tried using the Memsic 2125 to measure velocity?
I am having a hard time with mine with tracking velocity. It drifts alot
when it is not moving.
Also, does anyone have a schematic of this circut. The Memsic documents
reference using two capacitors and a resistor to help filter the data. I
can see 2 surface mount components on the Memsic board, but I don't know
what they are.
Any info would be appreciated.
Pete Miles
what they are.
Pete Miles
An accelerometer cannot directly measure velocity, or, I should add,
unless you rig up something that translates velocity into
acceleration or tilt.
There are a lot of application notes as well as the data sheets
available at <http://www.memsic.com>. The '2125 has a digital PWM X
and Y outputs, and the docs show how to use an RC circuit to convert
the PWM to analog and also filter it to restrict the bandwidth. But
if you use the digital output directly into the Stamp, via PULSIN,
then the lowpass filtering will have to be done digitally in the
Stamp. The docs also suggest a noise-reduction filter circuit for
the power supply that uses two capacitors and a resistor, to filter
the analog and digital supplies.
-- Tracy
>what they are.
>Pete Miles
TO convert Accelereation into velocity, you need to integrate veleocity with
respect to time IE the old Physics equation V=A*T where V=velocity,
A=Acceleration
and T=Time.
Bill Higdon
> Hi Peter,
> -- Tracy
> >what they are.
> >Pete Miles
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and Body
> of the message will be ignored.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
2125 working just fine with my BS2p and a LCD display. Right now it make a
great digital level. So reading the values are not a problem. I even know
the that the PWM X and PWM Y outputs are transmitted at the same time
(something the docs don't mention).
The docs do talk about using two capacitors and a resistor to filter the
data. On the Parallax Memsic 2125 board there are two surface mount
components which the manual, that comes with the device, doesn't explain
what they are. So I was wondering if the filter was already on the board,
or do I still have to add one.
I am aware that you can not measure velocity directly with an accelerometer.
But if you integrate accelleration, you can get velocity.
Using the trapezoid method, velocity is:
velocity = ((delta_T)/2)*Sum(a_0+2*a_1+2*a_2+2*a_3+....+2*a_(i-1)+a_i)
Where a_n values are the acceleration values that are measured, and delta_T
is the time increment between each acceleration measurement. In essence it
is just a summation of the acceleration values.
The program I am using right now, delta_t is consistant at 30 ms. (I
measured this with an oscope).
The problems I am having is there is a lot of drift in the summation values
when the accelerometer is just sitting on a table and not moving. Some
times all it will do is increase, or decrease, or move to some value and
oscillate around it for a while then move to a different value and
oscillate. The other problem, is that the values grow so fast, I overload
the 16 bit number, and it rolls over. I suppose I need to learn how to do
32 bit math on the stamps.
Since there are accelerometer based inertial navigation systems that can be
purchased for several hunderd dollars, I suspect there is a technique that
needs to be used to use these types of things.
My application is for sumo robots, so the exact velocity in not important.
I just need to know if the robot is moving forward, backwards, or sideways,
and the time scale will generally be from 5 to 30 seconds, with a worse case
total time period of 3 minutes.
I originally thought this would be easy, but it has turned out to be a
rather tough problem. Maybe that is why nobody else is doing this.
Pete Miles
petem@o...
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Thursday, August 21, 2003 8:37 AM
Subject: Re: [noparse][[/noparse]basicstamps] Memsic 2125 and Velocity
> Hi Peter,
> -- Tracy
> >what they are.
> >Pete Miles
The surface mount parts are both capacitors, in parallel across the
power supply. I'd guess they are two different values for better
filtering. This is not the 2C + R filter, though, if it is the one
you are referring to in the data sheet (figure 5) that goes between
the analog and digital power supply pins of the '2125. The analog
and digital power supply pins to the '2125 are connected directly
together on the Parallax carrier board.
I see what you mean about integrating the acceleration. I've just
started playing with the memsic chip myself, so I haven't hit those
issues (yet). We are evaluating it for monitoring the choppiness of
a water surface by potting the chip inside a float, but that is AC
and the drift and accumulation of offsets won't matter so much.
In the appnotes memsic has information about temperature correction
of both the offset and the scale factor, so if your 'bot is heating
up, that may be a factor.
Over-sample? Run the samples through an exponential or boxcar filter,
before putting them into the integration. That would decrease the
variance. Or, I don't know, tell it to ignore acceleration readings
below some threshold. Low accelerations with vibration are going to
be the hardest to integrate.
Maybe it would in fact be better to convert the PWM into analog, and
read it via an ADC, so that the sampling error (at 30 ms/) wouldn't
be so under-sampled.
2125 100k
PWMx or y ---/\/\----o--- ADC to Stamp
===== 1uf
Vss
(Data sheet figure 4 except with 1/2piRC = 16 hz instead of 166 hertz.)
Scale it so that the maximum acceleration reading will be ~100, so
that worst case it won't overflow for 10 seconds. (or better yet, do
the double precision thing!) It is just add/subtract and multiply*2,
not hard.
-- Tracy
http://www.emesystems.com
>Pete Miles
>petem@o...
Original Message
>From: "Tracy Allen" <tracy@e...>
> > Hi Peter,
>> -- Tracy
>> >what they are.
>> >Pete Miles
>Subject and Body of the message will be ignored.
Any DC offset gets integrated to a ramp, which eventually causes
overflow. One solution is to use a rate gyro chip, which produces
rotational velocity directly, instead of an accelerometer. Or, use both
in combination, and some extra math, to correct for the accelerometer
offset.
Dennis
Original Message
From: Pete Miles [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=dQNtE7-RJFKvj4ZLVMGasqOdsdPao-UMxx1Hpz1gI7fAqcDQNCBxSjpiMrmH4yR9HBbJ2EwB92XPSdFdiug]petem@o...[/url
Sent: Thursday, August 21, 2003 10:25 AM
To: basicstamps@yahoogroups.com
I have read most of the docs from the memsic website. I have the memsic
make a great digital level. So reading the values are not a problem. I
even know the that the PWM X and PWM Y outputs are transmitted at the
same time (something the docs don't mention).
board, or do I still have to add one.
accelerometer. But if you integrate accelleration, you can get velocity.
delta_T is the time increment between each acceleration measurement. In
essence it is just a summation of the acceleration values.
values when the accelerometer is just sitting on a table and not moving.
Some times all it will do is increase, or decrease, or move to some
value and oscillate around it for a while then move to a different value
and oscillate. The other problem, is that the values grow so fast, I
overload the 16 bit number, and it rolls over. I suppose I need to
learn how to do 32 bit math on the stamps.
be purchased for several hunderd dollars, I suspect there is a technique
that needs to be used to use these types of things.
important. I just need to know if the robot is moving forward,
backwards, or sideways, and the time scale will generally be from 5 to
30 seconds, with a worse case total time period of 3 minutes.
Pete Miles
petem@o...
Original Message
> Hi Peter,
> unless you rig up something that translates velocity into acceleration
> or tilt.
> Stamp. The docs also suggest a noise-reduction filter circuit for the
> power supply that uses two capacitors and a resistor, to filter the
> -- Tracy
> >alot when it is not moving.
> >documents reference using two capacitors and a resistor to help
> >filter the data. I can see 2 surface mount components on the Memsic
> >board, but I don't know what they are.
> >Pete Miles
> and
them?
Pete Miles
Original Message
Sent: Thursday, August 21, 2003 5:20 PM
Subject: RE: [noparse][[/noparse]basicstamps] Memsic 2125 and Velocity
> When integrating acceleration to velocity, drift is almost inevitable.
> offset.
> Dennis
Original Message
> From: Pete Miles [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=FFDBeC2I5AW9G_PSLuGsphwaIkkoEczYuBnD5-pKxvHeyGIEWcypYZ7qNsWaDuX2byV2ti_eKgZ08w]petem@o...[/url
> Pete Miles
> petem@o...
Original Message
> > Hi Peter,
> > or tilt.
> > -- Tracy
> > >Pete Miles
> > and
to mount 2 on the same board, use one A and one B, instead of 2 of the
same. If you need only one, either is OK.
Dennis
Original Message
From: Pete Miles [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ucgh4vQNJ85ZX4sAsV-qRCQaS2d8Xc8bCfo0I-LIWiqiryzu_wy-FWPC0k0txtYAr36sZp766jsbjwQjv1M]petem@o...[/url
Sent: Thursday, August 21, 2003 5:34 PM
I have been thinking about that for some time now. Any recommendations
for them?
Pete Miles
Original Message
> both in combination, and some extra math, to correct for the
> accelerometer offset.
> Dennis
Pete
Original Message
Sent: Thursday, August 21, 2003 5:49 PM
> Murata ECN gyros work well. They come in A and B flavors. If you neet
> Dennis
Original Message
> From: Pete Miles [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=nQrcDhopJSGphpOGPWtRDsB3aCrSEJHw9R3rfbskZHx0j6vTJs-Ra9cRK2m_mS9Bu87AjdvqiOFrC1CG]petem@o...[/url
> for them?
> Pete Miles
Original Message
> From: "Dennis O'Leary" <doleary@e...>
> > Dennis
acceleration?
- Robert
Original Message
Sent: Thursday, August 21, 2003 6:20 PM
> offset.
> Dennis
Original Message
> From: Pete Miles [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-2slBGrRjJslnA05DzD_TbCiW7PX6jouVHEhWPNd9mYBtETJlg1zemqf0qUT2UfA69bTRUUyPKR6fuSChEQ]petem@o...[/url
> Pete Miles
> petem@o...
Original Message
> > Hi Peter,
> > or tilt.
> > -- Tracy
> > >Pete Miles
> > and
they can be mounted anywhere on a rotating body, not just at the center
of rotation, because of the "parallel axis theorem" from rotational
physics. They are often used in combination with accelerometers to sort
out gravitational tilt from linear acceleratation.
Dennis
Original Message
From: Robert Ussery [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=qPixz8ws7hsh7mg9JZS3I0I3TwL8GyeU6Wjrk0QJJ_k5gnr4iSk0ruUDEvfUnj5duVN-FiUoEdKQJDo02g]uavscience@f...[/url
Sent: Thursday, August 21, 2003 6:42 PM
Quick question: How do you use a rotational rate gyro to sense linear
acceleration?
- Robert
Original Message
> Dennis
through-hole, now they seem to be only surface mount.
Dennis
Original Message
From: Pete Miles [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=j-Fi9WKhcfWLNlkNaQ0C40Mk-baynI2sZ2lmG9ePPOEb7dRuboZBRPSHlOrL3V45dvjsvKfKmTRvsvUUng]petem@o...[/url
Sent: Thursday, August 21, 2003 5:58 PM
You have a link for them?
Pete
Original Message
> neet to mount 2 on the same board, use one A and one B, instead of 2
> of the same. If you need only one, either is OK.
> Dennis
Original Message
> recommendations for them?
> Pete Miles
Do you have a source for these chips? In an earlier message you said
you had to buy them in quantity for your postural sway studies a few
years ago. Mouser carries Murata stuff, but not that particular
sensor.
-- Tracy
>Yes -- http://www.murata.com/catalog/s42e3.pdf . Originally, they were
>Dennis
Original Message
>From: Pete Miles [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ebZANZbHit2PuROjWvSlbzgjJldSRVjcGH87uoKkkhxbFbEWtnnFVeezJmkzs8XIQoXbDqop9ZEkQXvouvI]petem@o...[/url
>Thanks,
>Pete
Original Message
>> Dennis
Original Message
>> Pete Miles
Yes, I get them directly from Murata. But I had to buy quantities of
100 each of A's and B's, in order to build them into a medical device
that we manufacture. I'm just now reaching the end of that lot, so I'll
soon have to buy a similar quantity of the newer surface-mount models.
Let me know off list if you need a few of the new lot.
Dennis
Original Message
From: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1ubWkPHRjEaIyUxhb6slr3j3bj8yJ4FeOA_n_GvxqqWwojlRIqrTUCmf1rLoalHG0iW5CXN_99rWFufjRCs]tracy@e...[/url
Sent: Friday, August 22, 2003 10:22 AM
Hi Dennis,
sensor.
-- Tracy
>through-hole, now they seem to be only surface mount. Dennis
Original Message
>From: Pete Miles [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=fSRbdIzi66NnfeLmkNPPvdukIu1aUDGQzb1YtBNw6ZIuiOGnMa__QvTlad2XCv94hXIRJJ89PwW0JgGYWg]petem@o...[/url
>Thanks,
>Pete
Original Message
>> Dennis
Original Message
>> Pete Miles
