pre-newbe, and confused
Hi all,
i need some help,
i want to turn a 6inch disk,, to five diffrent spacific spots,
in any rotation/sequence,
stepper,
with a hand-paddle,/push-button for each of the five settings,
and/or a computer interface/window,
and something to tell me what one of the five im on currently,
as a very green electronicaly chalenged soul,
is there help for me,
and witch board/stamp, should i start with,
thanks,
a most gratefull almost newbe,,
john pike
marysville wa.
i need some help,
stepper,
thanks,
john pike
marysville wa.
I don't know if you can, but maybe you could drill a series of holes on
your disk with all different sizes and mount a led under the disk, and a
photo resistor directly above the led and disk. So when the disk turns,
hole A lets in X amount of light which then tells you which position the
disk is in. Hooking up five push buttons can be easily hooked up to the
stamp. And finally, the Bs2 has a great function called debug which will
lets you send data back to the computer. All of this is covered in the
Stamp manual, which is a great asset. Hope this helps, and if you need
any more help email me off list and ill go into more detail. Being a
newbie I feel I should help [noparse]:)[/noparse]
-Mike
Original Message
From: jpike98271 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=SOQcCGZa_67gIa2rC-mp7QxzmZIqNs8zCGosAnMzrNvlqbZ562-5Gug1qHtSL1TF4rVVhcwXKtd8NpzWFQ]jp.jep@v...[/url
Sent: Wednesday, August 20, 2003 7:32 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] pre-newbe, and confused
Hi all,
i need some help,
stepper,
thanks,
john pike
marysville wa.
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Parallax 'What's a Microcontroller?' courses. This
comes with a servo, and all instructions how to
use it. Put the disk on the servo, add a few
buttons, follow the instructions, and you should
be good to go.
This assumes you already have a BS2 and a Board
Of Education (BOE). If all you have is a BS2, then
you can still do this with a RadioShack breadboard,
but wiring becomes a little more tricky -- and you'll
need a 7805 linear regulator based power supply.
Another alternative is to take advantage of their
$79 homework board offer -- which has the 'What's a
Microcontroller?' along with a surface mounted BS2
and a prototype area. You'll still need to add
an AC/DC adapter (which Parallax sells).
--- In basicstamps@yahoogroups.com, "jpike98271" <jp.jep@v...> wrote:
> Hi all,
> i need some help,
> stepper,
> thanks,
> john pike
> marysville wa.
Original Message
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=3R6s_qIC6kHsC8JEh6NpE-U7kq8fbRfAkZccoOVIdX2-jnA-BrffUbzUPc61GIIPRpMBndrrPhsgL4mO3q9MHcZm5Q]allan.lane@h...[/url
Sent: Thursday, August 21, 2003 8:51 AM
Subject: [noparse][[/noparse]basicstamps] Re: pre-newbe, and confused
If they still have them available, buy one of the
be good to go.
> Hi all,
> i need some help,
> stepper,
> thanks,
> john pike
> marysville wa.
> Hi all,
> i need some help,
> stepper,
> thanks,
> john pike
> marysville wa.
Hi John,
you didn't mention power needed so assuming a light weight disk ?
a set of 3 optical switches from a couple old mice or old floppy or
old printers or something would offer a noncontact sensor. you can
easily use a simple arm to trip each sensor.
The inputs from your switches then would tell the program which point
to go to next.
and you could control a bi-polar stepper with 4 output pins.
this would be a good learning experience.
the inputs are simple in as much as you learn about optos and how to
wire them, and since they are noncontact and board powered, you don't
have to worry about frying things.
also, you get to learn about switches, so you manual inputs are just
an extension of that.
The stepper part can be simple (4 pins for one motor) so you do not
have major learning curve there either.
Now, if you throw high power or high speed, you start to complicate
things.
Dave
