In a message dated 8/18/2003 6:49:59 PM Pacific Daylight Time, h40miami@y... writes:
> Hi.....
> I am new in BS2,
> What is the best way to DIM a LED?
> Tank you,
> Edson
If you want the LED to run at 1 dim setting, the method to make it dim is to
increase the size of the resistor in series with the LED. To vary the
brightness. If you want variable dimming, use PWM.
1 dim setting....
To select an appropriate resistor, you generally do the following:
Generally to run an LED at "normal" brightness, you will want about 20ma
through the LED. This is VERY general and will vary depending on the LED.
The current through an LED is set by the voltage that will be supplied to the
LED AND a the value of a SERIES resistor.
If for example, you want 20 ma through the LED and the voltage source is 5
volts do the following
1) subtract the LED forward voltage from the supply voltage. The forward
voltage is GENERALLY 1.7 to 2.3 volts, and it varies on the LED and how much
current you put through it. As a starting point, say 2 volts is the forward
voltage.
If your supply voltage is 5 volts, 2 from 5 leaves 3 volts.
2) Using ohms law, select a resistor that will yield 20 ma with 3 volts.....
3volts / 20 mA = 150 ohms
For half the current (and a dimmer led) put 10 mA through the LED
3 volts / 10 mA = 300 ohms
These are simply starting values. A calculator really isn't needed. If your
supply is 5 volts, start with about 270 ohms, if the led is too bright for your
taste, simply increase the amount of resistance until you get the desired
level of dimming.
If you want to vary the brightness of the LED typically you will use PWM
(pulse width modulation). This is where you send a pulsing signal to the LED at
a
specific frequency (40 to 100 hz will work) and vary the "high" time or "low"
time of the pulse depening if you are sourcing (sending voltage to) or sinking
(grounding) the LED circuit.......
Ken
The best way is to vary the on-time and
off-time of the LED -- that's what people are
talking about when they say 'PWM'.
If an LED has 20 mA through it (set by the
current limiting resistor), then if you put
a 200 uS on / 200 uS off square wave through it,
you should get a 50% dimmer LED. The BS2
should be able to cycle this fast.
You'll have to experiment with the numbers to
see at what point you see a 'flickering' LED,
instead of a dim one.
--- In basicstamps@yahoogroups.com, "h40miami" <h40miami@y...> wrote:
> Hi.....
> I am new in BS2,
> Tank you,
> Edson
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
And if you wanna play, you can pump 50mA thru it if you pulse it. it
never gets hot enough to blow, but it shines really bright.
if you plan on trying that, keep the on time fixed and vary of the
off time. that way, when you get running slooow, it doen't get hot at
one long pulse and blow.
--- In basicstamps@yahoogroups.com, "Dave Mucha" <davemucha@j...>
it
at
> But play with it and have fun.
> Dave
op's I should have said you can pump 100mA, and that the 50/50 duty
cycle needs to be over 100hz (lower limit) for the thermal time
constant of she'll pop.
If you use some value like 150hz, you'll be safe and if you leave the
ON pulse time the same and extend the off pulse, you'll get dimming.
Try adding a cap across the LED this will eliminate the flickering and if large
enough it will allow your code time to do a few
other things during the process.
> I am try to do a Automatic LED dim
> Going to 5V to OV in a Output Pin.
> How can I do that using PWM?
> Tahnk you,
> Edson
> Tahnk you,
> Edson
Check the manual for how to do the PWM.
very clear and easier to study that than for us to post.
Hy, The First Exemplo works but the second one has a
bub in I= 255
IS anything wrong?
Thank you
> >Tahnk you,
> >Edson
> Maybe something like this, which dims the led from
> full to off in a
> few seconds.
> ' P0---/\/\--->|---Vss
> ' 220ohm led
> i var byte
> DO
> for i=255 to 0
> PWM 0,i,5
> next
> LOOP ' do it again
> The above hovers longer at the brighter level. To
> get a more linear
> appearing effect, dim using a power law, like,
> DO
> I=255
> DO
> PWM 0,i,25
> i = i* 7/8
> next
> LOOP UNTIL X=0
> LOOP
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software http://sitebuilder.yahoo.com
>bub in I= 255
>IS anything wrong?
Well, it is a snippet and variable "I" needs to be declared, and a
couple of typos corrected, and it uses PBASIC 2.5 syntax:
' {$PBASIC 2.5}
' P0---/\/\
>|---Vss
' 220ohm led
' power law intensity rolloff...
i var byte
DO
I=255
DO
PWM 0,i,25
i = i* 7/8
LOOP UNTIL i=0
LOOP
>Thank you
>> >Tahnk you,
>> >Edson
>> full to off in a
>> few seconds.
>> ' 220ohm led
>> i var byte
> > DO
>> for i=255 to 0
>> PWM 0,i,5
>> next
>> LOOP ' do it again
>> get a more linear
> > DO
>> I=255
>> DO
>> PWM 0,i,25
>> i = i* 7/8
>> next
>> LOOP UNTIL X=0
> > LOOP
>> ignored.
>Do you Yahoo!?
>from the same email address that you subscribed. Text in the
>Subject and Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
> a
> >bub in I= 255
> >IS anything wrong?
> declared, and a
> syntax:
> ' {$PBASIC 2.5}
> ' P0---/\/\
>|---Vss
> ' 220ohm led
> i var byte
> DO
> I=255
> DO
> PWM 0,i,25
> i = i* 7/8
> LOOP UNTIL i=0
> LOOP
> >Thank you
> >> >Tahnk you,
> >> >Edson
> from
> >> full to off in a
> >> few seconds.
> >> ' 220ohm led
> >> i var byte
> > > DO
> >> for i=255 to 0
> >> PWM 0,i,5
> >> next
> >> LOOP ' do it again
> To
> >> get a more linear
> > > DO
> >> I=255
> >> DO
> >> PWM 0,i,25
> >> i = i* 7/8
> >> next
> >> LOOP UNTIL X=0
> > > LOOP
> be
> >> ignored.
> >Do you Yahoo!?
> design software
> Text in the
> ignored.
Do you Yahoo!?
> Hi.....
> I am new in BS2,
> Tank you,
> Edson
1 dim setting....
voltage.
level of dimming.
a
Ken
> Hi.....
> I am new in BS2,
> Tank you,
> Edson
allan.lane@h... writes:
The cut off point to notice flickering is about 35 hertz (try it!).
Above 40 hertz, I, nor anybody I know has been able to see flickering.
Dave
it
at
> Dave
Dave
Tahnk you,
Edson
> Tahnk you,
> Edson
> Tahnk you,
> Edson
Dave
>Tahnk you,
>Edson
Maybe something like this, which dims the led from full to off in a
few seconds.
' 220ohm led
i var byte
DO
for i=255 to 0
PWM 0,i,5
next
LOOP ' do it again
The above hovers longer at the brighter level. To get a more linear
DO
I=255
DO
PWM 0,i,25
i = i* 7/8
next
LOOP UNTIL X=0
LOOP
> DO
> I=255
> DO
> PWM 0,i,25
> i = i* 7/8
> ' next <--- no next here!
> LOOP UNTIL i=0 '<-- until i=0
> LOOP
bub in I= 255
IS anything wrong?
Thank you
> >Tahnk you,
> >Edson
> full to off in a
> few seconds.
> ' 220ohm led
> i var byte
> DO
> for i=255 to 0
> PWM 0,i,5
> next
> LOOP ' do it again
> get a more linear
> DO
> I=255
> DO
> PWM 0,i,25
> i = i* 7/8
> next
> LOOP UNTIL X=0
> LOOP
> ignored.
Do you Yahoo!?
>bub in I= 255
>IS anything wrong?
' {$PBASIC 2.5}
' P0---/\/\
>|---Vss
' 220ohm led
i var byte
DO
I=255
DO
PWM 0,i,25
i = i* 7/8
LOOP UNTIL i=0
LOOP
>Thank you
>> >Tahnk you,
>> >Edson
>> full to off in a
>> few seconds.
>> ' 220ohm led
>> i var byte
> > DO
>> for i=255 to 0
>> PWM 0,i,5
>> next
>> LOOP ' do it again
>> get a more linear
> > DO
>> I=255
>> DO
>> PWM 0,i,25
>> i = i* 7/8
>> next
>> LOOP UNTIL X=0
> > LOOP
>> ignored.
>Do you Yahoo!?
Sorry for question, I am new in BS2
> a
> >bub in I= 255
> >IS anything wrong?
> declared, and a
> syntax:
> ' {$PBASIC 2.5}
> ' P0---/\/\
>|---Vss
> ' 220ohm led
> i var byte
> DO
> I=255
> DO
> PWM 0,i,25
> i = i* 7/8
> LOOP UNTIL i=0
> LOOP
> >Thank you
> >> >Tahnk you,
> >> >Edson
> from
> >> full to off in a
> >> few seconds.
> >> ' 220ohm led
> >> i var byte
> > > DO
> >> for i=255 to 0
> >> PWM 0,i,5
> >> next
> >> LOOP ' do it again
> To
> >> get a more linear
> > > DO
> >> I=255
> >> DO
> >> PWM 0,i,25
> >> i = i* 7/8
> >> next
> >> LOOP UNTIL X=0
> > > LOOP
> be
> >> ignored.
> >Do you Yahoo!?
> design software
> Text in the
> ignored.
Do you Yahoo!?
