Radiocontrolled Bot instead of serial?
Hi guys,
Does anyone have any experience with replacing the serial cable with
a RF gizmo? I'd like to keep in constant touch with my computer, so i
can write software on the PC that controls the bot. Maybe in the
future with a CMU-Cam or video-camera. But I can't find anything
usefull about replacing the serial cable. The only thing i could come
up with is to buy a second BS2 with two RF trancievers. But I'm not
that rich. I need a distance of only 10m max.
Any Ideas?
Timmy Kokke
Any Ideas?
Timmy Kokke
also send data to the stamp, you will need two transceivers. You
should be able to hook one up directly to your serial port (use a
max232 in between the computer serial port and the transceiver to
safely downscale the voltages if needed!) and the other on up to your
stamp. To be able to program the stamp via radio would be more
complex (would have to make multiple lines interface with the
transcievers to replicate the serial cable lines. You can buy
transceivers for not too high a price. Check out rentron.com, I got
the 433 transmitter and receiver pair, they didn't work that well,
but they are actually made to actuating things (on/off switches)
remotely, not for serial communication of numbers, etc.
--- In basicstamps@yahoogroups.com, "sorskoot" <timmykokke@h...>
wrote:
> Hi guys,
with
i
come
> Any Ideas?
> Timmy Kokke
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Wednesday, August 13, 2003 5:31 AM
Subject: [noparse][[/noparse]basicstamps] Radiocontrolled Bot instead of serial?
> Hi guys,
> Any Ideas?
> Timmy Kokke
Replacing a serial cable with low end RF modules is tough since they do not have
onboard processors to handle data communications errors, switching between
transmit
and receive modes, etc,. And there *will* be data errors from time-to-time due
to natural
& man made RF interference sources. If an occasional data error isn't a problem
for your
application, you can use pretty much any inexpensive RF modules for simple
wireless
communications, but if you need a true RF transceiver, and one that's reliable,
it will be
on the pricey side.
Maxstream has some of the best RF equipment I've ever used for embedded wireless
communications http://www.maxstream.net/products_9xcitedev.html The 9XCite
modules
are the lower price - shorter range - version of their 9XStream units, and
significantly lower
in price. I believe the 9XCite range is ~300". The 9XStream models have a range
of several
miles.
We carry several inexpensive RF modules, but none of them would offer a solution
for
replacing a serial cable. If you're really on a budget, and you can get by with
infrared,
we have a new 8-pin IC you can use to build a serial data link with that
supports data-rates
up to 19,200bps when used with the high-speed Vishay TSOP7000 IR photo modules.
http://www.rentron.com/remote_control/TX-IRHS.htm
-Bruce
tech@r...
bluetooth?
--- In basicstamps@yahoogroups.com, Tech <tech@r...> wrote:
Original Message
> From: "sorskoot" <timmykokke@h...>
> > Hi guys,
with
so i
come
not
> > Any Ideas?
> > Timmy Kokke
they do not have
between transmit
to-time due to natural
isn't a problem for your
simple wireless
that's reliable, it will be
> on the pricey side.
embedded wireless
9XCite modules
units, and significantly lower
have a range of several
> miles.
offer a solution for
get by with infrared,
that supports data-rates
photo modules.
> Regards,
> -Bruce
> tech@r...
Stamps, bluetooth enabled. One was on a 'bot and the other was on a
BOE with a Memsic accelerometer, so he could direct the 'bot by hand
rotations only. Very cool. I don't remember the name of the
manufacturer, but I think he said the modules were kind of pricey, in
the $200 range.
-- Tracy
>I was just thinking.... Does anyone have any experience with
>bluetooth?
Original Message
>> > Hi guys,
>with
>so i
>come
>not
>> > Any Ideas?
>> > Timmy Kokke
>they do not have
>between transmit
>simple wireless
>> on the pricey side.
>embedded wireless
>9XCite modules
>> miles.
>photo modules.
>> Regards,
>> -Bruce
>> tech@r...
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the
>Subject and Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
read from sensors or so. And as i said before, maybe in the (near) future
read data from a CMU-Cam or something. If there's a cable between my bot and
my computer it can't drive very far. Although, a 3 mile range sounds like
fun...
Timmy
>they do not have
>between transmit
>simple wireless
>> on the pricey side.
>embedded wireless
>9XCite modules
>> miles.
>photo modules.
>> Regards,
>> -Bruce
>> tech@r...
from the same email address that you subscribed. Text in the Subject and
