Basic stamp programing
Hi, I'm making an automatic paper cutter and will be using a basic
stamp to control it. I was wondering if I could save $50 by just
putting a serial port on the paper cutter to program it instead of
getting the $50 programming board? Or does the programming board
have special circuits required to program it?
power to the Stamp and a serial cable.
Sid Weaver
W4EKQ
Port Richey, FL
that there are a couple of caps in the serial connection and two the
pins are tied together so the editor can do a loopback test. We have
schematics for our various demo boards; any will give the correct
connections to build your own serial interface.
-- Jon Williams
-- Parallax
Original Message
From: ch2surf [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=aJILJY8_t-gbSEL3CWmY4sV8gSGmw2NbVixhtaoTAFwVBx-oxFK8bTpvm4ouz8Ntpeabb2wb-C4z7xmW6ha8Fd7p2fI]sachacrompton@v...[/url
Sent: Monday, August 11, 2003 1:12 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Basic stamp programing
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
serial connector and a serious 5V regulator built onto the board along with
the core BS2 components. It costs about the same as the standard BS2-IC,
and the components are all through-hole which makes it easier form many of
us to repair it or integrate it into other equipment.
Randy
www.glitchbuster.com
> Thanks
pins for what I need.
--- In basicstamps@yahoogroups.com, "Randy Jones" <randyjones@w...>
wrote:
> You might also want to consider the OEM Basic Stamp 2, which has
the DB9
along with
BS2-IC,
many of
> Randy
sachacrompton@v... writes:
> I am getting the BASIC Stamp 2p40, the others dont have enough I/O
More pins are indeed nice but not mandantory........If timing is not
critical, using three stamp pins you can have those 3 pins control 8, 16, 24,
32, 40
or more output pins.
There is s shiftout command and a 7hHC595 serial shift register, and there is
stamp code already written on the web sight. You can do the same with a
74ls299 which can be used to expand input AND output ports.......use shift in
and
shift out..
I always include a 4 pin header aligned with pins 1-4, on all my boards, this
makes changes much easier.
For details see:
http://www.qsl.net/kf4haz/cables/stamps/
> Thanks
port, 8 high current outputs to control valves, motors, etc. and 7
additional inputs for sensors, switches, etc. along with LED's to show the
status of the outputs to make programming and troubleshooting easier. Check
out http://www.geocities.com/jimforkin2003/
jim
Original Message
From: ch2surf [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=m2j77xs3SsyY_9LojIIMCQ3zzLSmyUUXIp57dq4X_5CLDcidBzMunrdFd-aHYMxzRomicCgLvOSi1VgkFJdsjg]sachacrompton@v...[/url
Sent: Monday, August 11, 2003 2:12 PM
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
I/O. Much cheaper. If you need the speed of a p40, that is a different
matter.
Jonathan
www.madlabs.info
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Monday, August 11, 2003 5:15 PM
Subject: [noparse][[/noparse]basicstamps] Re: Basic stamp programing
> the DB9
> along with
> BS2-IC,
> many of
> > Randy
(one in series, one in parallel -- see the
parallax schematics)
which is used to reset the BS2 so it can be
programmed. You can omit them, as long as you
have control of the 'DTR' line (this is the
232 pin 4, which goes to the 'ATN' pin.)
Then in your circuit you'll only need to
add the 4 pins mentioned earlier
(GND, TX, RX, DTR) AND a 'loopback'
wire on the DB-9 adapter, to program the
BS2 in-circuit.
If you are using the Microsoft COMM control,
set DTREnable to FALSE so it won't hold the BS2
in 'reset'.
--- In basicstamps@yahoogroups.com, "ch2surf" <sachacrompton@v...>
> Thanks
I know they've been described by several as "for communicating with
PC". But what exactly do the 2 caps do? And what happens if the
series cap is shorted or parallel cap is opened?
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
wrote:
> Note that the two capacitors go to the 'ATN' pin,
> BS2 in-circuit.
> in 'reset'.
basic
of
> > Thanks
yellowniter@y... writes:
> What exactly does each of the two caps do on ATN pin?
One is a coupling capacitor, the other a bypass cap. If the coupling cap is
bad, no serial comm. If the bypass is bad you might get erratic operation due
to noise.
Sid
level on that line (a series cap will block DC, but allow a transition
to pass -- this is how the Editor resets the Stamp for reprogramming).
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: yellowniter [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=MoALq4Sn9fAFPVqX3yd6oOTgdXpZA-DShqYq18RIWGg-KXYM61D4cWx_cnh38lLpagi89hTvK_G5miKHhuPa3g]yellowniter@y...[/url
Sent: Monday, August 18, 2003 10:41 AM
> BS2 in-circuit.
> in 'reset'.
basic
of
> > Thanks
abuse@p....
