Program Memory
ArchiverArchiver Posts: 46,084
edited 2003-08-05 - 17:54:00 in Microcontrollers
I have a few questions regarding the EPROM space that a program
occupies.
* Do REM stattements occupy EPROM space?
* Do variable and subroutine labels occupu more EPROM space if
they are long?
Dwain
  • ArchiverArchiver Posts: 46,084
    edited 2003-01-01 - 10:18:00
    >occupies.
    > they are long?
    >Regards,
    >Dwain
    Hi Dwain -
    Neither REM statements nor LABELS consume EPROM space in the STAMP memory.
    It is therefor appropriate to comment your programs freely, and use
    meaningful names for better documentation and easier program readability.
    Bruce Bates
    >To UNSUBSCRIBE, just send mail to:
    >from the same email address that you subscribed. Text in the Subject and
    >Body of the message will be ignored.
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    edited 2003-01-01 - 17:25:00
    Like Bruce said, remarks and labels do not consume memory, they only exist
    in your source code. They are tools to make it easier to document your code
    and to mark or jump to other code pieces without knowing where they actually
    reside in memory.
    If you can come back to a program you wrote 6 months or a year ago and
    easily figure out what it does, your documentation is good.
    Original Message
    > >occupies.
    > > they are long?
    edited 2003-01-01 - 17:49:00
    In a message dated 1/1/2003 9:28:23 AM Pacific Standard Time,
    daweasel@s... writes:
    How true!!!!!!!!
    When I write even the smallest programs I often thought I don't need to
    document it. My reasoning was, heck, I am the guy who designed the hardware
    and writing the software. Don't need no stinkin documentation!!
    How wrong I was!!!!!!!!! I now thoroughly document all programs. It is time
    well spent!!!!!!!
    edited 2003-08-05 - 03:46:00
    Can anyone please tell me if it's possible to add more program space to a BS2?
    I've filled it up and have shortened my program as much as possible. I know
    nothing about the matter, as I'm a complete newbie.
    Many thanks, John
    Do you Yahoo!?
    SBC Yahoo! DSL - Now only $29.95 per month!
    edited 2003-08-05 - 04:29:00
    Hey John,
    Go to using a bs2e, which will give you 8 x the program space, its really
    quite easy, and the module goes straight into the same ic socket as the bs2,
    same pinout etc.
    Cheers.
    Chris
    Original Message
    To: <basicstamps@yahoogroups.com>
    Sent: Tuesday, August 05, 2003 10:46 AM
    Subject: [noparse][[/noparse]basicstamps] Program memory
    BS2? I've filled it up and have shortened my program as much as possible. I
    know nothing about the matter, as I'm a complete newbie.
    > Many thanks, John
    > Do you Yahoo!?
    edited 2003-08-05 - 05:41:00
    Dear Chris,
    Thanks for the reply.I have a BS2e and SX, Parallax says they have 2x16K. My
    memory map still shows that the program space is %99 full. How do I go about
    using the extra memory?
    Cheers for more help!
    Chris Anderson <fuel@b...> wrote:
    Hey John,
    same pinout etc.
    Cheers.
    Chris
    Original Message
    To:
    > Many thanks, John
    > Do you Yahoo!?
    from the same email address that you subscribed. Text in the Subject and Body of
    Do you Yahoo!?
    edited 2003-08-05 - 12:22:00
    John...
    have a look at the "run" command.
    With the sx and e, you have 8 slots of program space, where the bs2 has one.
    If you check the memory map with the e or sx, you will see that there are 8
    memory maps there, not just one.
    The 8 slots in an e or sx are 0,1,2,3,4,5,6,7
    Say you have some code which does different things depending on the state of
    pin 5, and if pin 5 is high you want to run the program in slot 1....
    'In slot 0
    if in5 = 0 then stayinslot0
    run 1 'makes the program go to slot 1, and run the program in
    there.
    stayinslot0:
    'code here for slot 0 (perhaps your bs2 code)
    You can pass a variable between slots by using the 'put' and 'get' commands
    like this...
    'in slot 0....
    put 0, 27 'puts the value 27 into RAM location 0
    run1 'sends the program off to run the code in slot 1.
    'in slot 1...
    myVar var byte 'declare a byte variable
    get 0, myVar 'get the value in location '0' in RAM, put it into
    myVar
    debug dec myVar 'will show "27" in the debug screen
    You need to declare variables etc at the beginning of each slot, but you
    only need to declare 'dirs' (inputs / outputs) in slot 0.
    There are 63 (0-62) usable bytes of ram with e and sx, BUT, you should have
    a good read of the help manual because you need to set up a $stamp directive
    at the start of each page (slot) of program. You need to do this for the
    whole 8 pages, even if you are only using 1 or 2 slots etc. Once you get the
    hang of it, you will be able to do heaps more with the stamp.
    The 8 slots open up enormous possibilities, and give a huge amount of
    program space. Best thing ever happened was Parallax releasing the bs2e / sx
    / p.
    In my application, the stamp starts by jumping to slot 7 and loading all
    user changeable system settings from Eeprom, and puts them all into ram.
    Then it goes to slot 0 and waits for some user input. Depending on the user
    input, it then runs other slots, with ibutton comms in 1 slot, extra memory
    access (external Eeprom) in one slot, time date setting and display to lcd
    in one slot, keypad input in one slot. I have all 8 slots at least 80% full
    of code, and it is very simple to jump / pass values between them.
    Cheers,
    Chris
    Original Message
    Sent: Tuesday, August 05, 2003 12:41 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Program memory
    > Dear Chris,
    My memory map still shows that the program space is %99 full. How do I go
    about using the extra memory?
    > Hey John,
    bs2,
    > same pinout etc.
    > Cheers.
    > Chris
    Original Message
    > From: "John Baker"
    > To:
    a
    I
    > > Many thanks, John
    > > Do you Yahoo!?
    > Do you Yahoo!?
    edited 2003-08-05 - 14:32:00
    I wrote an article for Nuts & Volts magazine that goes into the
    specifics of multi-bank programming and a method of moving data
    parameters between program slots. GOTO www.parallax.com and navigate
    the menu like this:
    Parallax >> Downloads >> Nuts & Volts Columms
    Click on Volume 3 and download column #87: Multi-Bank Programming.
    -- Jon Williams
    -- Parallax
    Original Message
    From: John Baker [noparse][[/noparse]mailto:johnbaker_erie_pa@y...]
    Sent: Monday, August 04, 2003 11:42 PM
    To: basicstamps@yahoogroups.com
    Dear Chris,
    2x16K. My memory map still shows that the program space is %99 full. How
    do I go about using the extra memory?
    Hey John,
    really quite easy, and the module goes straight into the same ic socket
    as the bs2, same pinout etc. Cheers. Chris
    Original Message
    To:
    > to a
    possible. I know nothing about the matter, as I'm a complete newbie.
    > Many thanks, John
    > Do you Yahoo!?
    > and
    Do you Yahoo!?
    and Body of the message will be ignored.
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
    Thanks Jon and Chris! Chris, your explanation helped immensly. I am now using my
    SX for my robot and have lots of space to spare. The Nuts and Volts article
    helped me understand it more too.
    Cheers to everyone!
    Do you Yahoo!?
