stepper Motor and gears
Where can i get gears that I can use with the stepper motor i got
from parallax?
Or, where can i get gears for any dc motor in general?
Any recommendations?
from parallax?
dollars a piece, maybe even $10 or $20 (and that's just for plastic). My
favorite suppliers of gears are listed below. The Science Source sells some
very nice (very cheap) small plastic gears in 2:1 and 3:1 ratios. And despite
what the website says, you can drill out the hubs to 1/4" [noparse];)[/noparse]
Edmund Scientific (www.scientificsonline.com)
Small Parts, Inc. (www.smallparts.com)
The Science Source (www.thesciencesource.com)
Ryan Meador
Electrical Engineering Student
Cold Regions Research and Engineering Laboratory
email: ryan.meador@e...
phone: (603) 646-4454
Original Message
From: nestlerv [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7IPsbMPOefCEqL7z3GU880w-9gmRkn2KCrR4rLutNQP_JXalILwJ3BBGjcl_GLdB3eH85yAjFEsmp4U]nestlerv@a...[/url
Sent: Friday, July 25, 2003 3:07 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] stepper Motor and gears
from parallax?
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and Body
of the message will be ignored.
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
stores. Just look up the specs on your motor shaft size (most can be
drilled larger). Also support your local hobby shop and give them a try,
most have replacement gears for servos and cars. Make a CNC mill from your
stepper motors and mill your own! : )
Cheap gears can be pretty hard to come by. Usually they'll cost you
several dollars a piece, maybe even $10 or $20 (and that's just for
plastic). My favorite suppliers of gears are listed below. The Science
Source sells some very nice (very cheap) small plastic gears in 2:1 and 3:1
ratios. And despite what the website says, you can drill out the hubs to
Ryan Meador
Original Message
From: nestlerv [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Jqi_eIo7cEEKCHoI8CNP6hUs9Hhc0G6ld7jiVYmwIpRrf3axmG5n77g1k96mUO3mYn2GiIxxrQ]nestlerv@a...[/url
from parallax?
several gears, motors, shafts, belts and hardware in each for the taking.
Also vcr's are loaded with gears. If you are into scrounging for parts,
maybe you can find what you need in these.
jim
http://www.geocities.com/jimforkin2003/
Original Message
From: daniel.d.dangremond@j... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=P4ojpd8nEeGPiQUC9pyF_BJaONLVIsAv36HJSu48ygzqIj-j311u-ip5aIW0lGKmTZJefeFKENuyYt4xtgrptiIzDsQ]daniel.d.dangremond@j...[/url
Sent: Friday, July 25, 2003 3:52 PM
Subject: RE: [noparse][[/noparse]basicstamps] stepper Motor and gears
Check out Jameco (~$.69/gear) and the other surplus electronic/robot
Ryan Meador
Original Message
From: nestlerv [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_Og6Sis4ptt2FQ-JVBhbMzN8c3LhXh--1qFA7MjwJf8LzTCVPJ-eTfnbDyoJm7QJtNQRk6afNQ]nestlerv@a...[/url
from parallax?
