basic stamp, ir instead of serial port ?
Is is possible to use the ir port of a laptop to send instructions
and code to the stamp instead of the serialport?
can i use the ir buddies to do that. I am using a BOE.
Thanks.
Thanks.
http://groups.yahoo.com/group/basicstamps/message/33184
You can search the Group on "IRBuddy", and get
comments on earlier askings of this question.
Basically, it lets you send PHILLIPS RC-5
IR Remote keypresses, and receive IR Remote
keypresses. 320 Bits/Second max data rate.
It's very useful for what it does.
If you're trying to replace the BS2 programming
interface with IR, I don't think so. I believe
Parallax makes an RF based gizmo to do this --
see their web-site, and look for RF stuff.
The Maxim 3100 and 3110 chip will provide an
SPI port to the BS2, which talks 'IR' to your
laptop or palmtop -- but you'll have to write
the send/receive code yourself.
And if your laptop does not HAVE a serial
port, you can use a USB to serial adapter.
This uses your laptop's USB port to provide
a high-speed 232 link.
Keyspan makes a nice unit, and the Parallax
site has one they recommend. Stay away from
Belkin, as they don't properly implement the
handshake signals you need.
> Thanks.
Thanks for the info. The situation is, I have an old thinkpad laptop
i am using. It has a serial port and an infrared, but no usb. I would
like to use the ir port to control a bot that i am building and then
use the serial port for other things. Right now I am typing ascii
characters via the serial port that the stamp interprets as
directional control. (ie w is forward, s is backward...)
So I guess the question is, can i get ir to recieve ascii characters
from the laptops ir port and interpret them as commands for the bot?
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
wrote:
> For an overview of the IRBuddy, see:
instructions
> > Thanks.
palm-tops, etc is they are VERY limited in
distance (10 feet), so this is not very
likely to work. Plus, the 'standard' they
use requires you to add too much hardware
(an IR Reciever diode and a MAX3100 chip,
with oscillator and two capacitors).
It sounds like what you want to do is put an
IRBuddy on the Robot. It very easily interfaces
with the BS2. Then, get a very simple $10.00
Radio Shack universal remote, set it for
Phillips RC-5 code. Now, you can write code
for the BS2 to respond to the IRBuddy
receiving signals from the hand-held remote.
BUT, this still uses up your serial port on
the PC if you want the PC to control the
Robot under program control. You can put
a second IRBuddy (they come in pairs)
on the serial port (with a
simple interface board and MAX-232 chip)
but that still uses up your serial port.
With USB, this would be solvable, since with
it you can put up to 16 232 ports on a PC.
You could perhaps add a small PC card with
serial ports on it? You could perhaps build
a parallel to serial interface to talk to the
second IRBuddy? I think you're out of simple
answers. Sorry.
> Hmmmm,
laptop
would
then
characters
> instructions
> > > Thanks.
