question for constructing a simple GUI using visual basic with stamp
I'm currently doing a project which require a simple GUI which can
count the number of item when the basic stamp input the signal .
My idea is let the basic stamp input either 1 or 0 to the computer .
If the computer receive the 1 as one pulse,it will count in the
counter .If it is zero,the computer will not count it in the counter .
But i'm lack of knowledge of input receiving the signal using
computer with visual basic .Someone told me about referring to the
article in nuts & volts about the data exchange using visual basic
and stamp .But when i look through it ,i found that it is too hard
for me to understand and it doesn't need so much for my project .
Since my project only let the computer receive a signal like 1 or 0
while the article show me about the serial in and serial out data
tranfer ,i couldn't understand and modify it to suit my need .
So ,can someone help me about the programming for receiving such
single bit signal from basic stamp to computer ?thanks for your help .
By the way ,when i see the article,it first mention about the flow
control .Is it needed for this case which only a bit of signal is
used for transfer?thanks.
great program where you add the different meters or leds or screens that
your project calls for and the stamp communicates with the program
through a
serial interface. You can get the program here:
www.rhombusinc.com/uGUI.chm
-Mike
Original Message
From: kaijiun83 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=UGxlyplzfIcmALJoJ6pcPLH3urkCYwsLZHLRt7Epsgzni8uUslSXTUhZHAc4b0whj53Kp_RaQFIbmMWOr8U]kaijiun83@y...[/url
Sent: Tuesday, July 15, 2003 8:28 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] question for constructing a simple GUI using
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
reading a 'signal'. It was designed to run
spreadsheets and word processors, drive
printers, etc.
The BS2 IS very good at reading 'signals'.
So what you want is an interface between the
PC and the BS2 so they can tell each other
stuff.
And you have that -- it's the BS2's built-in
serial port. Since you are building 'a simple
GUI', I assume you are using Visual Basic on
the PC side. Since you are using Visual Basic,
you can easily interface with the BS2's serial
port.
So: BS2:
' ******** BS2 SIDE **************************
DataPin VAR IN1
MyData VAR BYTE
SerPin CON 16
SerBaud CON 84 + 16384 ' 9600 baud, 'inverted'
' From BASIC Stamp Prog Man, 2.0c,
' Page 297
MAIN:
MyData = DataPin ' Read the data state on the pin
SEROUT SerPin, SerBaud, [noparse][[/noparse]MyData] ' Send to PC
PAUSE 100 ' Wait (in mS) a while for the next reading
GOTO MAIN ' And loop.
END
' ****** END OF BS2 SIDE ************************
Now, VB Side:
Well, that's a little more complicated for a 'complete'
solution. I'll work on it and download the finished
product in a few days. For now, you should know:
1. You need to check Project, Component,
"Microsoft Comm Control ..". This will put the
serial port component in your toolkit.
2. you need to drag one of these to the form.
3. You need to put a text box on the form, for
the bytes to be displayed in.
4. On 'FormLoad', you can open the port.
MSComm1.DTREnable = FALSE ' Don't reset the BS2
MSComm1.Port = 1 ' Use COM1: port
MSComm1.Open = 1 ' Open the port
5. Make an MSComm1_OnCom event handler.
MyValue = MSComm1.Input
textbox.text = MyValue
--- In basicstamps@yahoogroups.com, "kaijiun83" <kaijiun83@y...>
counter .
help .
difference between using the Microgui program and using Qbasic?
Bill
Original Message
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=h7VzYb0RPmEA_9oxrAHogUqKE4OM2TG0usTOLOvxubnHY9MKN5OpFfV4UtmMtjivPoBMwWUyFHIx37MkKZnDjlFGeg]allan.lane@h...[/url
Sent: Wednesday, July 16, 2003 9:29 AM
Subject: [noparse][[/noparse]basicstamps] Re: question for constructing a simple GUI using
Unfortunately, the PC is not very good at
printers, etc.
stuff.
port.
So: BS2:
DataPin VAR IN1
MyData VAR BYTE
SerPin CON 16
' Page 297
MAIN:
END
Now, VB Side:
counter .
help .
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Original Message
From: Bill Katakis [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=rtfcoIsB-6Ov-egFTUTeD8a0EegyVepvIt1MrR9Afy5tr7jtaSBIQuBOa3TlGXByGSQDB5J5vTkmS0uN]bkatakis@a...[/url
Sent: Wednesday, July 16, 2003 9:12 AM
Subject: RE: [noparse][[/noparse]basicstamps] Re: question for constructing a simple GUI
Doesn't the Microgui use the bs2's serial port also?? What is the
Bill
Original Message
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AeM5l4Iag68lu4k4fZ-Ny3QccOLmmfkXZ4ANAFa5I8IxZC-oZvxJvy8ObDyYW0ybjolbyGcPMiZsvU7BrZ1I_Xw9Hlc9]allan.lane@h...[/url
printers, etc.
stuff.
port.
So: BS2:
DataPin VAR IN1
MyData VAR BYTE
SerPin CON 16
' Page 297
MAIN:
END
Now, VB Side:
counter .
help .
and
measure a pwm signal from PWMpal with the microgui? Could that be done via
the normal connection. I'm looking for a way to verify (with software) that
pwm is being generated.
Original Message
From: Mike Dillon [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=J0BLauDhe78O6pAEcxaTkJ6ZzVw7hrqQ9KDFDoGZlvVaZtLj9y0l_ekXussjIY2li08-EEBNZuS--wgAUqo]laxboy687@e...[/url
Sent: Wednesday, July 16, 2003 11:18 AM
You don't have to write any VB code that's all. It is way easier to use.
Original Message
From: Bill Katakis [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=R5pAIOucquuDQmM5gMFxZm9bHji7GHbkJtRyd72tVErJw-6vTK4E2d6LhB-vxHw-Xa-AOJhDkbsjwnNd]bkatakis@a...[/url
Bill
Original Message
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=8eVqzRlc8G-cI2g1oiEBkK8zskTn06aLXlx7a-BW-g6v1keoASfVeVXYNqu8Sh7a7QKlXzgHHX0wIw1tfy2cFdc8D3DB]allan.lane@h...[/url
printers, etc.
stuff.
port.
So: BS2:
DataPin VAR IN1
MyData VAR BYTE
SerPin CON 16
' Page 297
MAIN:
END
Now, VB Side:
counter .
help .
and
Original Message
From: Bill Katakis [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ltJiWNZt-CGju36vC4y5qdFsGwEKd9QUKk079raAnpUp0_BqTzySjvLciLUWSBAHMNyPIpXgHFwZXLmi4p8]bkatakis@a...[/url
Sent: Wednesday, July 16, 2003 10:23 AM
How would the MicroGui program respond to Parallax's PWMpal? How would
you
via
that
Original Message
From: Mike Dillon [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ie3kUwZnl6j2S3Kw2p7xPryOhoJSt0EB1zy_cyWvCXFItkZOyLJZI2wAyuHU0lSS1Wi4yE4n6Wet8YsVPCBHy3M]laxboy687@e...[/url
Original Message
Bill
Original Message
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=cHckMXzroHWhIyNj0tyPQrd4EeGrqnNyeLebBTMLZV-Nijzc-5RTdgzbrmUc7yA5_u2enE1QhiDIIu8_tcDiiP9zShCv]allan.lane@h...[/url
printers, etc.
stuff.
port.
So: BS2:
DataPin VAR IN1
MyData VAR BYTE
SerPin CON 16
' Page 297
MAIN:
END
Now, VB Side:
counter .
help .
and
and
\AlDemo\BS2_VBDemo.zip
This contains both the BS2 side, and a
very simple VB project, which implements the
MSComm control, and uses it to get data from
the BS2 and display it in a scrolling
text box on the PC.
I've also included a readme.txt file of
instructions how to re-create the VB project
from scratch.
I hope you can use this as the starting point
for more elaborate uses of the BS2 with the
PC.
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
> printers, etc.
> stuff.
> port.
> So: BS2:
> DataPin VAR IN1
> MyData VAR BYTE
> SerPin CON 16
> ' Page 297
> MAIN:
> END
> Now, VB Side:
can
computer .
> counter .
the
basic
hard
0
> help .
flow
data from the stamp .The problem i'm facing now is i can't modifying it to
become a counter .
Since i think is just purely programming after the transfering data problem had
solved ,so i ask my lecturer about letting the text.box display a counter
instead of display all the number .But my lecturer says that textbox shouldn't
include the variable for display purpose .and he also don't understand about one
of the line :
Text1.Text = Text1.Text & MSComm1.Input
the & use here seems to be wierd for me .when i learning c++ and java ,& for me
is a logic function .and my lecturer says that it should be the same for VB also
So ,can you please explain to me what's happen in this textbox?
and can i declare variable like this ?(using c++ since i'm not sure for vb later
i'll try to get it to vb):
int a=0;
if ( MSComm1.PortOpen)
a=a + MSComm1.Inputl
Text1.Text = Text1.Text +a;
i know that the syntax is wrong .but i hope you can get my little concept for
this .thanks again .
Allan Lane <allan.lane@h...> wrote:
OK, in the 'Files' section, I've added:
text box on the PC.
from scratch.
PC.
> printers, etc.
> stuff.
> port.
> So: BS2:
> DataPin VAR IN1
> MyData VAR BYTE
> SerPin CON 16
> ' Page 297
> MAIN:
> END
> Now, VB Side:
can
computer .
> counter .
the
basic
hard
0
> help .
flow
from the same email address that you subscribed. Text in the Subject and Body of
Do you Yahoo!?
The New Yahoo! Search - Faster. Easier. Bingo.
currently a "1", and a "0" if currently a "0". So,
the following should work:
Dim OneCounter As Long
Dim ZeroCounter As Long
Sub UpdateText()
Dim MyStr As String
Dim I As Long
Dim TestChar As String
If MSComm1.PortOpen Then
MyStr = MSComm1.Input
For I = 1 To Len(MyStr)
TestChar = Mid$(MyStr, I, 1)
If TestChar = "1" Then
OneCounter = OneCounter + 1
End If
If TestChar <> "1" Then
ZeroCounter = ZeroCounter + 1
End If
Next I
End If
Text1.Text = ZeroCounter & vbCrLf & OneCounter
End Sub
Put a call to 'UpdateText' in the Timer1.Timer call,
and enable the timer at about a 500 mSec rate.
--- In basicstamps@yahoogroups.com, Cheang Kaijiun <kaijiun83@y...>
wrote:
> Thanks for helping me .At least i know about the code for the pc to
receive the data from the stamp .The problem i'm facing now is i
can't modifying it to become a counter .
problem had solved ,so i ask my lecturer about letting the text.box
display a counter instead of display all the number .But my lecturer
says that textbox shouldn't include the variable for display
purpose .and he also don't understand about one of the line :
java ,& for me is a logic function .and my lecturer says that it
should be the same for VB also .
for vb later i'll try to get it to vb):
> int a=0;
concept for this .thanks again .
> text box on the PC.
> from scratch.
> PC.
> > printers, etc.
> > stuff.
> > port.
> > So: BS2:
> > DataPin VAR IN1
> > MyData VAR BYTE
> > SerPin CON 16
> > ' Page 297
> > MAIN:
> > END
> > Now, VB Side:
> can
> computer .
> > counter .
> the
> basic
> hard
project .
> 0
data
such
> > help .
> flow
is
Subject and Body of the message will be ignored.
> Do you Yahoo!?
for string concatenation -- though you can
use '+' for the same purpose. VB uses
'AND' for the 'and' function.
> int a=0;
> text box on the PC.
> from scratch.
> PC.
> > printers, etc.
> > stuff.
> > port.
> > So: BS2:
> > DataPin VAR IN1
> > MyData VAR BYTE
> > SerPin CON 16
> > ' Page 297
> > MAIN:
> > END
> > Now, VB Side:
> can
> computer .
> > counter .
> the
> basic
> hard
project .
> 0
data
such
> > help .
> flow
is
> Do you Yahoo!?
If I understand properly, I would think that all you really need is a CR
filter to look at the PWM, and read it from the Stamp using its A/D
statement.
Optionally you could output that value to microGUI on the PC and Plot it
along with some other events that may be of interest - see Starter5 project.
www.rhombusinc.com/microgui.html
or look at the gifs here for something similar:
www.rhombusinc.com/ZIPs/Kaijun.zip
David Lawrence
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Wednesday, July 16, 2003 8:40 AM
Subject: RE: [noparse][[/noparse]basicstamps] Re: question for constructing a simple GUI using
> I don't know, but David Lawrence is the guy to ask, maybe he'll chip in.
Original Message
> From: Bill Katakis [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=L-eu2TeJT2FEEcHgCBNIgbOPvNFRSbx-ty96U_4pvnZTWJ8TfLONRMh6l727Dt1ag9BvFDQ__WJanZk]bkatakis@a...[/url
WaitLp:
'---- Check Pulse
INLo = INL
IF INLo.Bit0 = OldPulse THEN WaitLp 'Detect an Edge
OldPulse = INLo.Bit0 'Record it
IF OldPulse = 0 THEN WaitLp 'Limit to +ve edges
Cnt = Cnt + 1 'Else Count
'---- This is the PC Code
SEROUT 16,84, [noparse][[/noparse]CmdNumW,CntLo,CntHi] 'And Display
SERIN 16,84, [noparse][[/noparse]Tmp]
The above displays the Count on a 5 Digit Numeric display.
All I had to do at the PC was:
- New Project
- Setup
- Select '1' Numeric Display (Word size)
- Apply, then Close (Setup screen)
- Save Project as 'Kaijun.prj'
DONE !
It would function totally, completely right there, but I 'chose' to make it
more appealing to me.
I did a Right-Click on the Meter Frame to reach the properties, and then:
- Color Blue for the digits
- Comma Separator to break up such a long count
- Right side (of separator) digit count to 3 (for thousands)
- Labelled the Display 'Kaijun's Count'
I also re-positioned and reduced the Panel size before saving.
A small ZIP here has the .Bs2, and .prj (but you need microGUI demo below)
plus a GIF of what it looks like.
I then went a step further and added this Bs2 code
'---- Plot Count
SEROUT 16,84, [noparse][[/noparse]CmdPlot,CntLo,CntHi]
to plot the Count as 2 separate Analog Channels. The MS byte is very flat
and allows good visual judgement of total, whereas the fast slope of the LS
Channel visually highlights any deviations in rate.
I could also have added a few digital Channels as in Starter5.prj, to
identify events in sync with rate changes.
At the PC I had to hit the Scope Button to make it visible. (There may be a
need here for a small mod, so that the Scope can optionally be Locked down,
rather than Debug style floating).
That GIF is also included in the ZIP - total ZIP is
(Note, to run without a Pulse input I commented out the 4 lines of BS2 code
immediately after WaitLp).
Demo is here - 2.7Megs (including 20+ Ready-to-Run Projects, both .Bs2s and
.Prjs)
David Lawrence
Original Message
Sent: Wednesday, July 16, 2003 8:17 AM
Original Message
> From: Bill Katakis [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pcUy1ahFPi1HQz-j0cFB_hL_cJ4ffR8-BfUYEyBzRAQpKNuy8MCQ804vi-83ut2fe2p0JiGKohQvbUsQug4]bkatakis@a...[/url
earlier - or perhaps it is something to do with College and you must create
your own code - if so, at least see how it would have looked:
David Lawrence
Rhombus
Original Message
Sent: Thursday, July 17, 2003 10:32 AM
Subject: Re: [noparse][[/noparse]basicstamps] Re: question for constructing a simple GUI using
give when i copy and paste it to browse it .
Instead of that ,it goes to other page where tell me that this domain is not
registered .
i would like to check it out since i want to know both VB and micro GUI .can you
check what's the problem behind it?
David Lawrence <david@r...> wrote:
If you are looking for a fast & easy solution you may have missed my post
David Lawrence
Rhombus
Original Message
To:
Do you Yahoo!?
in PSP, and all OK.
Anyway I have now put it in the Stamp Files section - just saw notification
so it has arrived and should work out for you this time.
David Lawrence
Rhombus
Original Message
Sent: Thursday, July 17, 2003 6:19 PM
> Actually i wanted to see it .But i don't know why i can't access the
website you give when i copy and paste it to browse it .
not registered .
.can you check what's the problem behind it?
create
> David Lawrence
> Rhombus
Original Message
> From: Cheang Kaijiun
> To:
using
> Do you Yahoo!?
should put them correctly but the output turns out to be nothing or remain the
same.I put the source code at here .I'm really out of idea to let it become
counter .tested almost 2-3days for this program..........i give up on it .So
,please help me .thanks
I don't want to use the microGUI because i know my examiner will deduct my mark
by saying that it is copy and not my work .it is kind of unlucky to have that
kind of lecturer .So,please help me to correct this source code .thanks for
everything .
Private Sub Command1_Click()
Dim MyObj As Object
Set MyObj = Command1
MyObj.Caption = "Open"
MSComm1.PortOpen = False
Else
MyObj.Caption = "Close"
MSComm1.PortOpen = True
Text1.Text = Text1.Text & vbCrLf
End If
End Sub
Private Sub Command2_Click()
End ' Exit the Program
End Sub
Private Sub Form_Load()
Dim MyVal As Long
MSComm1.DTREnable = False
MSComm1.Settings = "9600,n,8,1" ' 9600 baud, No Parity, 8 databits
MSComm1.CommPort = 2
MSComm1.RThreshold = 1 ' 0 (default) == NEVER kick off OnComm RX event
MSComm1.PortOpen = True ' Opens port
Command1.Caption = "Close"
Command2.Caption = "Quit"
End Sub
Private Sub MSComm1_OnComm()
' To use 'OnComm', MUST set the MSComm1.RThreshold
End Sub
Private Sub Timer1_Timer()
Call UpdateText
End If
End Sub
Sub UpdateText()
Dim MyStr As String
Dim I As Long
End If
End If
Next I
End If
Text1.Text = vbCrLf & OneCounter
End Sub
With the current code, the BS2 sends a "1" if it's
Sub UpdateText()
Dim MyStr As String
Dim I As Long
End If
End If
Next I
End If
End Sub
> int a=0;
> text box on the PC.
> from scratch.
> PC.
> > printers, etc.
> > stuff.
> > port.
> > So: BS2:
> > DataPin VAR IN1
> > MyData VAR BYTE
> > SerPin CON 16
> > ' Page 297
> > MAIN:
> > END
> > Now, VB Side:
> can
> computer .
> > counter .
> the
> basic
> hard
project .
> 0
data
such
> > help .
> flow
is
> Do you Yahoo!?
Do you Yahoo!?
The BS2 code you were given does not generate "0" and "1"
David Lawrence
www.rhombus-tek.com/microgui.html
hi,unfortunately,after testing the code ,i still can't get it .i feel that
i should put them correctly but the output turns out to be nothing or
remain the same.I put the source code at here .I'm really out of idea to
let it become counter .tested almost 2-3days for this program..........i
give up on it .So ,please help me .thanks
> > > So: BS2:
> > > DataPin VAR IN1
> > > MyData VAR BYTE
> > > SerPin CON 16
> > > ' Page 297
> > > MAIN:
> > > END
your post) uses the '_OnComm' event to
transfer the data to the Text Box.
Instead, you should use a 'Timer'.
Call the 'UpdateText()' routine from
the 'Timer' routine.
feel that i should put them correctly but the output turns out to be
nothing or remain the same.I put the source code at here .I'm really
out of idea to let it become counter .tested almost 2-3days for this
program..........i give up on it .So ,please help me .thanks
deduct my mark by saying that it is copy and not my work .it is kind
of unlucky to have that kind of lecturer .So,please help me to
correct this source code .thanks for everything .
> Dim MyObj As Object
> Else
> End If
> End Sub
> End Sub
> Dim MyVal As Long
databits
RX event
> End Sub
> End Sub
> Call UpdateText
> End If
> End Sub
> Sub UpdateText()
> Dim MyStr As String
> Dim I As Long
> End If
> End If
> Next I
> End If
> End Sub
> Sub UpdateText()
> Dim MyStr As String
> Dim I As Long
> End If
> End If
> Next I
> End If
> End Sub
to
data
lecturer
sure
> > int a=0;
> > text box on the PC.
> > from scratch.
> > PC.
> > > printers, etc.
> > > stuff.
> > > port.
> > > So: BS2:
> > > DataPin VAR IN1
> > > MyData VAR BYTE
> > > SerPin CON 16
> > > ' Page 297
> > > MAIN:
> > > END
> > > Now, VB Side:
which
> > can
signal .
> > computer .
the
> > > counter .
to
> > the
> > basic
> > hard
> project .
1
> or
> > 0
> data
> such
your
> > > help .
> > flow
signal
> is
> > Do you Yahoo!?
> Do you Yahoo!?
SHOULD BE:
SEROUT SerPin, SerBaud, [noparse][[/noparse]DEC MyData] ' Send to PC
' The 'DEC' modifier sends out the decimal
' equivalent. Without it, you get CHR(0) or
' CHR(1). With it, you get "0" or "1".
' (in other words, the STRING "0")
' The VB side expects the STRING "0".
--- In basicstamps@yahoogroups.com, "David Lawrence" <david@r...>
wrote:
> At the PC you are looking for ASCII "0" and "1" (Dec 48 & 49 or $30
& $31)
> David Lawrence
feel that
idea to
program..........i
> > > > So: BS2:
> > > > DataPin VAR IN1
> > > > MyData VAR BYTE
> > > > SerPin CON 16
> > > > ' Page 297
> > > > MAIN:
> > > > END
