PCB Boards
A recent issue of Nuts and Volts mentions futurlec.com as the least
expensive place to get Printed Circuit Boards made. They require that
your work be Protel PCB files. Does anyone have any recommendations for
relatively inexensive software (and hopefully easy to use) for creating
Protel PCB files.
bob
Protel PCB files.
bob
>Protel PCB files.
>Thanks
>bob
Bob -
Unless you're located "down under" I'd question that futurlec.com is the
least expensive place to get printed circuit boards made. They're located
in Australia.
You may want to take a look at theses folks:
http://www.pcbexpress.com/
There is a link right on the home page to obtain the appropriate software
to design your PCB. I'm sure there will be many recommendations by others
on this list.
Bruce Bates
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
bob@t... writes:
> Protel PCB files.
> Thanks
> bob
Wow!!
Those boards are indeed inexpensive......you can usually get a trial version
of the Protel software. So if this is a one time deal, and you can design your
board before the trial period runs out, you are set.
Another option for more $$ is <A
HREF="www.expresspcb.com">www.expresspcb.com</A>
3 double sided boards, 3.25 X 2.5 (or close to that) for $62. Bit nowhere
close to the ~$20 for same quantity and size from futurlec
chapman@t... writes:
> Is that quote from futurlec, $20 in Australian or U S dollars?
Don't know.....I went to the web sight, entered options for a double sided no
silk-screen or soldermask 3.25 by 2.5 inch pcb.......quantity 3. Nor did I
look into how long to receive the boards
The same options from <A HREF="www.expresspcb.com">www.expresspcb.com</A> (qty
3.....3.8 by 2.5 inches) and
other options same as above is about $66 US dollars (including shipping) and the
boards are at your door in three business days.
I have been extremely satisfied with the service. The PCB layout software is
free and extremely easy to use.
