Writing to 24LC515 EEPROM
I recently purchased 4 Microchip 24LC515 EEPROMs. These are
512Kbits each. I have them wired into a 2Mbit group of 4, using
the A0 and A1 pins to designate chips 0 thru 3. A2 is wired to
Vcc. The write-protect pins are left floating, which should
leave the whole chip write-enabled. The SDA and SCK lines use
4.7kohm pull-up resistors. I've checked the wiring and all seems
OK there. I'm using the I2CIN and I2COUT commands on the
BS2p-24.
The problem I have is that I can only write to addresses $8000 to
$FFFF. In other words, I can only write to the part of the chip
where the block select bit is set to 1. If I set it to 0, I
can't read that data back - I get what appears to be all binary
1s in return. I'm setting B0 in the slave address (bit 3) and
not A15 (highest bit in the address, which is a don't care bit)
to select addresses $8000-FFFF.
I have verified I can write to all 4 chips by writing a pattern,
swapping two chips, then reading it back and seeing the pattern
in the wrong order for those chips. Also, I'm not reading and
writing across block or chip boundaries, and my reads/writes are
limited to 32 bytes at a time so I'm not crossing page
boundaries.
Can anyone give me ideas on what to troubleshoot? I can't
believe all 4 chips are half-bad. Here is the test program I use
(lots of extra variables declared from the program this logging
will eventually be used for).
- Mark
Mark D. Conner
E-mail: n9xtn@a...
Homepage: http://members.cox.net/mconner1
"Arrogance and stupidity, all in the same package.....how
efficient of you!" - Ambassador Londo Mollari, Babylon 5
'{$STAMP BS2p}
CLK con 0 ' clock line
ADC_CS con 1 ' chip select for max186
DATA_IO con 2 ' data line
GPS_RXD con 3 ' data from gps
TNC_TXD con 16 '4
GPS_TXD con 5 ' data to tnc
MAIN_V con 6 ' main V undervolt
SSC con 7 ' data to SSC
IO_0 con 8 ' io line 0
IO_1 con 9 ' io line 1
'TNC_TXD con 10 ' io line 2
IO_3 con 11 ' io line 3
LED1 con 12 ' io line 4
LED2 con 13 ' io line 5
CAM con 14 ' io line 6
TNC_RXD con 15 ' io line 7
RS232_Port con 16 ' RS232 line
'* Comm Values *
TNCRate con 16624
B4800N con 16884 'baud for TNC/GPS
'B2400N con 396+$4000 'baud for servo and stretch
B1200N con 18447 'baud for FSK output
B4800 con 500 'Jupiter board
'* Flight Status *
LandingPix var bit
Ascent var bit
Descent var bit
'* General Experiment *
'* Result Variable *
EXP_Value var word 'result of ADC conversion
T_Byte var byte 'temp var
TLMcount var word
LastAscent var bit
LastDescent var bit
PixNow var bit
'* GPS Variables *
Hour var byte
Mins var byte
Secs var byte
Nsats var nib
Lat var word
Latfrac var byte
Lon var word
Lonfrac var byte
Alt var word
Altfrac var nib
Cse var word
Spd var byte
Ft10K var nib
Ft var word
GSAFixType var nib
Sign var bit
I var word
VVel var Alt
VVelfrac var Altfrac
VVelft var Cse
LastGgaSec var Spd
FtHigh var Ft.highbyte
FtLow var Ft.lowbyte
MaxFt10K var T_byte
MaxFtHigh var Alt.highbyte
MaxFtLow var Alt.lowbyte
MaxFt var Alt
ERecHigh var Alt.highbyte
ERecLow var Alt.lowbyte
ERec var Alt
CByte var T_Byte
' Store max altitude in scratch RAM vars 1-3
ScrFt10K con 1
ScrFtHigh con 2
ScrFtLow con 3
' Store seconds of last GGA read in #4
ScrLastGgaSec con 4
ScrLastAlt10K con 5
ScrCam con 6
ScrERecHigh con 7
ScrERecLow con 8
RollSize con 40 ' # frames to take
FOR i=126 to 8191 step 128
ERec = i
Hour = 12
Mins = 15
Secs = i // 100
lat = i
lon = i
cse =315
spd = 35
ft10k = 4
ft = 1689
CByte = 160 + (ERec.bit10*8) + (ERec.bit12*4) + (ERec.bit11*2)
'debug dec5 ERec, " ",dec5 (ERec>>3)//256, " ",dec5
(ERec<<5)//256, CR
debug dec4 i, " ", bin8 CByte, " ", bin8 (ERec>>3)//128, " ",
bin8 ((ERec<<5)//256), CR
I2COUT 8, CByte, (ERec>>3)//128\((ERec<<5)//256),[noparse][[/noparse]Hour, Mins,
Secs, Lat.lowbyte,lat.highbyte, Latfrac, Lon.lowbyte,
Lon.highbyte, Lonfrac, Ft10K, Ft.lowbyte, ft.highbyte,
Cse.lowbyte, Cse.highbyte, Spd]
pause 100
next
FOR i= 126 to 8191 step 128
ERec = i
CByte = 161 + (ERec.bit10*8) + (ERec.bit12*4) + (ERec.bit11*2)
debug dec4 i, " ", bin8 CByte, " ", hex2 (ERec>>3)//128, " ",
hex2 ((ERec<<5)//256), " "
I2CIN 8, CByte, (ERec>>3)//128\((ERec<<5)//256),[noparse][[/noparse]Hour, Mins,
debug dec2 Hour, dec2 Mins, dec2 Secs, " ",dec4 Lat, ".", dec2
Latfrac,"N", dec5 Lon, ".", sdec2 Lonfrac, "W ", dec2 Ft10K, dec4
Ft,"ft ",dec3 Cse,"/",dec3 Spd,CR
pause 100
next
stop
BS2p-24.
boundaries.
- Mark
Mark D. Conner
E-mail: n9xtn@a...
'{$STAMP BS2p}
TNC_TXD con 16 '4
'* Comm Values *
TNCRate con 16624
'* Flight Status *
LandingPix var bit
Ascent var bit
Descent var bit
TLMcount var word
LastAscent var bit
LastDescent var bit
PixNow var bit
'* GPS Variables *
Hour var byte
Mins var byte
Secs var byte
Nsats var nib
Lat var word
Latfrac var byte
Lon var word
Lonfrac var byte
Alt var word
Altfrac var nib
Cse var word
Spd var byte
Ft10K var nib
Ft var word
GSAFixType var nib
Sign var bit
I var word
VVel var Alt
VVelft var Cse
LastGgaSec var Spd
MaxFt10K var T_byte
MaxFt var Alt
ERec var Alt
CByte var T_Byte
ScrFt10K con 1
ScrFtHigh con 2
ScrFtLow con 3
ScrLastGgaSec con 4
ScrLastAlt10K con 5
ScrCam con 6
ScrERecHigh con 7
ScrERecLow con 8
ERec = i
Hour = 12
Mins = 15
Secs = i // 100
lat = i
lon = i
cse =315
spd = 35
ft10k = 4
ft = 1689
(ERec<<5)//256, CR
pause 100
next
ERec = i
pause 100
next
stop
Since you wired A2 pins to vcc, your
Slave id bytes are $A8, $AA, $AC and $AE not $B0 as you mention.
Regards peter
Oorspronkelijk bericht
Van: Mark Conner [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=X9TfIunafB7-hMKpEL7yNBzdTGWC2wENEnT936OwjCvM8kGFgCJhX3Lu8ntTjcRLLYxJYiTtsg]n9xtn@c...[/url
Verzonden: maandag 14 juli 2003 01:00
Aan: basicstamps@yahoogroups.com
Onderwerp: [noparse][[/noparse]basicstamps] Writing to 24LC515 EEPROM
BS2p-24.
boundaries.
- Mark
Mark D. Conner
E-mail: n9xtn@a...
'{$STAMP BS2p}
TNC_TXD con 16 '4
'* Comm Values *
TNCRate con 16624
'* Flight Status *
LandingPix var bit
Ascent var bit
Descent var bit
TLMcount var word
LastAscent var bit
LastDescent var bit
PixNow var bit
'* GPS Variables *
Hour var byte
Mins var byte
Secs var byte
Nsats var nib
Lat var word
Latfrac var byte
Lon var word
Lonfrac var byte
Alt var word
Altfrac var nib
Cse var word
Spd var byte
Ft10K var nib
Ft var word
GSAFixType var nib
Sign var bit
I var word
VVel var Alt
VVelft var Cse
LastGgaSec var Spd
MaxFt10K var T_byte
MaxFt var Alt
ERec var Alt
CByte var T_Byte
ScrFt10K con 1
ScrFtHigh con 2
ScrFtLow con 3
ScrLastGgaSec con 4
ScrLastAlt10K con 5
ScrCam con 6
ScrERecHigh con 7
ScrERecLow con 8
ERec = i
Hour = 12
Mins = 15
Secs = i // 100
lat = i
lon = i
cse =315
spd = 35
ft10k = 4
ft = 1689
(ERec<<5)//256, CR
pause 100
next
ERec = i
pause 100
next
stop
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
out. The debug statements seem to indicate the right bits are
being set.
The B0 I referred to is the block select bit, and not a hex value
for the slave ID. It's bit 3 (of 0-7) in the control byte.
For this EEPROM, the A2 pin must be wired to Vcc for it to
function - it's not a chip select pin.
> Message: 10
> Date: Mon, 14 Jul 2003 07:55:07 +0200
> From: "peter verkaik" <peterverkaik@b...>
> Subject: RE: Writing to 24LC515 EEPROM
> Have you tried using constant slave id bytes.
mention.
> Regards peter
> Van: Mark Conner [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=PAVYqeuSjx_Vj2ztlINwQIDl_SWOow4Az6Nio6RJE6XZ-8XTN3frDxqEd62j6dK89dwUvbdw]n9xtn@c...[/url
using
seems
> BS2p-24.
to
chip
pattern,
are
> boundaries.
use
> - Mark
Each chip has 64k address range but address line A15 is put
In bit3 of the id byte. You need 18 bits to address all eeprom
Locations.
Try the following test routine (may take a while to fill all eeproms)
Bank var byte '0-3 for chipselect eeprom
Address var word 'for 0-FFFF locations inside eeprom
Cbyte var byte 'to hold slave id
Result var byte 'to hold read back values
Eeprom_fill:
For bank=0 to 3
For address=0 to $FFFF 'take a lower value such as 31 to speed up testing
Debug "bank ",dec1 bank," address ",hex4 address,cr
Cbyte = $A0+(bank<<1)+(address.bit15<<3) 'calculate id
I2cout 8,cbyte,address.highbyte&0x7F,address.lowbyte,[noparse][[/noparse]address.lowbyte]
Next
Next
Eeprom_read:
For bank=0 to 3
Cbyte = $A0+(bank<<1)+(address.bit15<<3)+1 'calculate id +1 for read
I2cin 8,Cbyte,address.highbyte&0x7F,address.lowbyte,[noparse][[/noparse]result]
If result == address.lowbyte then done
Debug "invalid byte ",hex2 result," at bank ",dec1 bank," address ",hex4
address,cr
Done:
Next
Next
Debug "program finished",cr
End_program
Goto end_program
Regards peter
Van: Mark Conner [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=HOZy2ML0799oDEVQWV3BILh-3cCGu2_8Fci3dqoQb2wbO0QeUFGikHTpe1cU_BN8jNRp]n9xtn@c...[/url
Verzonden: maandag 14 juli 2003 15:30
Onderwerp: [noparse][[/noparse]basicstamps] RE: Writing to 24LC515 EEPROM
I have not used constants in the slave ID bytes, but will try it
being set.
> Message: 10
mention.
> Regards peter
using
seems
> BS2p-24.
to
chip
pattern,
are
> boundaries.
use
> - Mark
results if the bank selection bit in the control byte is zero. I
dropped a note on the Microchip site to see if anyone there could
help.
The I2CIN/I2COUT docs say that the only thing the Stamp overrides
in the control byte is bit 0 for read/write.
- Mark
'{$STAMP BS2p}
bank var bit
a0 var bit
a1 var bit
addr var word
cbyte var byte
result var byte
pause 1000
for a0 = 0 to 1
for a1 = 0 to 1
for bank = 0 to 1
for addr = 1 to 128 ' max is 7FFB since I add up to 4 with the
A1/A2 bits
'debug "bank ", dec1 bank, " a0 ", dec1 a0, " a1 ",dec1 a1," addr
", hex4 addr
cbyte = $A1 + (bank<<3) + (a1<<2) + (a0<<1)
debug " cbyte ", bin8 cbyte, CR
i2cout 8,cbyte, (addr.highbyte)\addr.lowbyte,
[noparse][[/noparse]addr.lowbyte+(a1*2)+a0]
next
next
next
next
pause 1000
for a0 = 0 to 1
for a1 = 0 to 1
for bank = 0 to 1
for addr = 128 to 1 ' go backwards just to make sure we're
reading the addresses we think we are
", hex4 addr
i2cin 8, cbyte, (addr.highbyte)\addr.lowbyte, [noparse][[/noparse]result]
debug " result ", hex2 result
if result = addr.lowbyte+(a1*2)+a0 then cont:
debug " bad "
cont:
debug $0D
next
next
next
next
Only I would use $A0 in the cbyte calculation in the first part just above
the I2COUT statement.
($A1 indicates a read operation, better to be safe and clear bit0)
Can you give test results of what is supposed to be written and what is read
back? Together
with the location addresses where your results are bad?
The datasheet stated that a 5ms write delay is required after writing bytes.
You could add this delay after the I2COUT command and see what happens.
Regards peter
Van: Mark Conner [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9PL_7ppcNM4swI_CphEpxA-taKmM4ZGNnFL8HYiOob6i5YxEKU_fBf_udziUpoD_rjX0_weA1Q]n9xtn@c...[/url
Verzonden: woensdag 16 juli 2003 04:06
I adapted Peter's test program a little. I still get bad
help.
- Mark
'{$STAMP BS2p}
bank var bit
a0 var bit
a1 var bit
addr var word
cbyte var byte
result var byte
pause 1000
for a0 = 0 to 1
for a1 = 0 to 1
for bank = 0 to 1
A1/A2 bits
", hex4 addr
next
next
next
next
pause 1000
for a0 = 0 to 1
for a1 = 0 to 1
for bank = 0 to 1
", hex4 addr
debug " bad "
cont:
debug $0D
next
next
next
next
