Wall-wart question (newbie followup)
I came across a Toshiba laptop power supply module (external) that
has the following markings:
Input 100V-240V~ 1.2A-0.6A 50-60Hz
Output 15V = (solid over dashed line) 5A
I'm assuming this is a DC supply (and will certainly check).
My question is: Is there anything special I should know about using
these in a basic stamp application? I would power the stamp circut
through a 7805, etc...
As mentioned in an earlier post, I'm looking to drive some DC motors
(via relays) as well as the basic stamp from as few power supplies as
possible. At 5amps, this certainly helps me toward that goal...
Seems too good to be true... What am I missing?
Rob
Rob
be positive, the 'ring' connector GND (I'm assuming
you have a 2.1/5.5 mm power plug on it, or that
you are going to put a 2.1/5.5 mm power plug on it.
What you're missing is that the power supply
probably cost $100.00 or so, which you don't have
to pay because you 'came across it'. It's probably
a 'switching mode' powersupply.
One more thing you might want to check: there may
be a 'minimum load' required to bring the output
voltage up to 15 volts. This wouldn't be a problem
for the Laptop, but your BS2 may not pull enough
current. You can test this with a few resistors,
though (50 mA at 5V == 1.6 mA at 15V, which is
900 ohms).
using
motors
as
> Thanks,
> Rob
there some significance to the solid line over the dotted line?
The unit is labeled "For use with EDP Equipment Only"... Other than
that, I see no other references.
Thanks for the help.
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
wrote:
> Sounds good! Note that the CENTER conductor MUST
> 900 ohms).
that
> using
circut
> motors
supplies
> as
> > Thanks,
> > Rob
Jonathan
www.madlabs.info
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Monday, July 14, 2003 11:31 AM
Subject: [noparse][[/noparse]basicstamps] Re: Wall-wart question (newbie followup)
> How can I find out if it is a 'switching' power supply or not? Is
> > 900 ohms).
> that
> > using
> circut
> > motors
> supplies
> > as
> > > Thanks,
> > > Rob
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
10 volts across it.
Using a LM2575 with a proper layout will get you ~85% effiency with
up to 1A output.
Jason
--- In basicstamps@yahoogroups.com, "Jonathan Peakall"
<jpeakall@m...> wrote:
> Yes, it means DC. A wavy line indicates AC.
> Jonathan
> www.madlabs.info
Original Message
> From: "rrothe64" <rrothe@m...>
than
> > > 900 ohms).
> > that
> > > using
> > circut
> > > motors
> > supplies
> > > as
goal...
> > > > Thanks,
> > > > Rob
Subject and
The dotted line signifies that the output is not perfectly flat DC.
Regards
Eco
Original Message
Sent: Monday, July 14, 2003 8:31 PM
> > 900 ohms).
> that
> > using
> circut
> > motors
> supplies
> > as
> > > Thanks,
> > > Rob
> from the same email address that you subscribed. Text in the Subject and Body
components. Usually quite big and very heavy.
Switching supplies only have a small coil and a fair number of other small
components. Smaller (2/3 to 1/2) and far lighter.
Original Message
provide steady power? I recall reading about the load requirements
when I was researching the use of old PC power supplies. Do I need
to be concerned with this when using this toshiba supply or am I
confusing two issues? (btw, the model # is PA3083U-1ACA).
Rob
--- In basicstamps@yahoogroups.com, pm <pmeloy@s...> wrote:
> Regular power supplies use a honkin' big transformer and very few
other
other small
Original Message
than
You have a switching supply. Your earlier thread
mentioned 100 to 240 VAC input, which indicates a
"universal" input. For a transformer power supply, one
must select the appropriate input voltage with a
switch to select the correct transformer windings.
Rule of thumb about switching power supplies requiring
a load to start:
Switching supplies greater than 100 watts typically
require a load. This prevents excess voltage appearing
across the output capacitors and ensures regulation.
Switching power supplies less than 100 watts generally
work fine with no load. More specifically, the
internal regulation circuit and capactor "bleader"
resistor is an adequate load to prevent problems and
stays within regulation. Since your supply is about 75
watts (15VCD * 5ADC), you can simply plug it in and
power anything requiring 15 volts that does not exceed
5 amps. The output will be a tightly regulated and
filtered DC.
Lastly, the solid line over the dotted line simply
means DC. It's an old-school way of indicating what
the output would look like on a scope.
Dr. Diode
--- rrothe64 <rrothe@m...> wrote:
> Do all switching power supplies require some type of
> load before they
> load requirements
> supplies. Do I need
> supply or am I
> PA3083U-1ACA).
> Rob
> other
> fair number of
> other small
Original Message
> (newbie followup)
> supply or not? Is
> the dotted line?
> Only"... Other
> than
> Text in the Subject and Body of the message will be
> ignored.
__________________________________
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month!
http://sbc.yahoo.com
> Hello,
> "universal" input.
The poster had mentioned that the supply had a graphic depiction
of a solid line over a dashed line. I may be wrong but I don't
believe that it was specifically addressed as to whether the
dashed line on the supply meant "switching supply" or not. Can
someone in the know please address this? I'd love some
clarification on this issue.
Michael Burr
mburr@b... writes:
> Thanks,
> Michael Burr
As far as I know, the dashed line ONLY inidcates DC (direct current).
incorrect information may have been passed on. Wall warts come in 2 DC
versions, regulated and unregulated. Unregulated have 2 lines one solid
and 1 dashed under it. Regulated have a solid line and the output voltage
is stable. You will not read 16VDC on a 12VDC Wall Wart with no load if you
do --- it is unregulated. On a regulated one you will read 12VDC or pretty
close to the 12 VDC load or no load. Of course the regulated cost more..
This can be seen in the Jameco catalog which lists all Wall Warts and notes
which ones are regulated verses non regulated.
Just wanted to add my 1 cents worth.
Eric
Original Message
Sent: Sunday, July 20, 2003 10:24 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: Wall-wart question (newbie followup)
> PH wrote:
> > Hello,
> > "universal" input.
> Thanks,
> Michael Burr
Either way, I was running them through either a 7805 or a 7812. In
fact, I have a small breadboard that has both regulators on it
providing me a source for both +5 and +12 to power the stamp and
associated 12v relay coils.... works well for my purposes.
Rob
--- In basicstamps@yahoogroups.com, "Eric Adams" <hugs102@b...> wrote:
> I have been following this thread about wall warts and it appears
that some
2 DC
solid
voltage
load if you
pretty
more..
and notes
> Eric
Original Message
> From: "Michael Burr" <mburr@b...>
> > PH wrote:
> > > Hello,
> > > "universal" input.
> > Thanks,
> > Michael Burr
Subject and
A switching power supply is ALWAYS regulated. The very
term switching implies Pulse Width Modulation (PWM).
There are a few exceptions (car audio DC-to-DC, HV
supplies, etc.), but not with external laptop power
supplies or PC supplies. These must be tightly
regulated.
Transformer (non-switching) based "WallWarts" come in
many flavors including AC output, pulsating DC output
(non-filtered), DC output, and regulated DC output.
Regardless, if there is a solid line over a dashed
line, it is DC. Not necessarily regulated (I never
stated that it meant regulated), but simply DC.
Bottom line is this: 1st) If it says 100 to 240VAC In
and does not have an input voltage selector switch, it
is a switching power supply (universal input). 2nd)
Whatever the DC output voltage says, measure it with a
DVM. If it is within 2%, it is regulated; if not, it
is unregulated. Very simple to determine.
Dr. Diode
> Thanks for the info... I wondered what the "dots"
> meant...
> or a 7812. In
> regulators on it
> the stamp and
> purposes.
> Rob
> and it appears
> that some
> Wall warts come in
> 2 DC
> have 2 lines one
> solid
> line and the output
> voltage
> Wall Wart with no
> load if you
> will read 12VDC or
> pretty
> the regulated cost
> more..
> all Wall Warts
> and notes
> > Eric
Original Message
> (newbie followup)
> > > PH wrote:
> > > > Hello,
> thread
> indicates a
> > > > "universal" input.
> graphic depiction
> wrong but I don't
> whether the
> supply" or not. Can
> love some
> > > Thanks,
> > > Michael Burr
> Text in the
> Subject and
> ignored.
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
