Pressure sensor for water tank
Hi all,
A friend of mine wants to build a Stamp controller for his nifty home-made
water filtration system. The tank he has is 7 feet deep, and we would like
to be able to determine the water level within a foot or so. I am thinking
of a air type sensor with a tube from top to bottom of the tank. Any
recommendations? 0-5V output, or perhaps a resistive type.
Thanks!
Jonathan
www.madlabs.info
Thanks!
Jonathan
www.madlabs.info
external depth sensing system. You need a plastic tank as it used the
capacitance change between the water and an external aluminum strip on
the outside.
rondoc
amps@yahoogroups.com, "Jonathan Peakall" <jpeakall@m...> wrote:
> Hi all,
home-made
would like
thinking
> Thanks!
> Jonathan
> www.madlabs.info
Air pressure wont work due to the fact the air dissolves into the water over
time, plus condensation problems
It can be done, but its not that simple unfortunately!
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Friday, July 11, 2003 3:20 PM
Subject: [noparse][[/noparse]basicstamps] Re: Pressure sensor for water tank
> HI IN a NUts and VOLts article on STAMPS there was a very neat
> the outside.
> rondoc
> > Hi all,
> home-made
> would like
> thinking
> > Thanks!
> > Jonathan
> > www.madlabs.info
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
1) A float and sprung reel. Hook it up to a multiturn pot somehow. Could be
a tab hokey but it might work.
2) Ultrasonic - Drill holes along the length of a PVC tube to let water in
and out. Put an ultrasonic range finder on top then put the tube into the
tank. Measure the distance to the top of the water and deduct the missing
volume. Infra-red might work, not sure if water would reflect or absorb it
though.
Original Message
<tim.stockman@s...>
Sent: Thursday, July 10, 2003 10:58 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: Pressure sensor for water tank
> or a plastic pipe external to the tank with the strip(s) on that :-)
over
Original Message
> From: "rondoc69" <rdoctors@c...>
> > the outside.
> > rondoc
> > > Hi all,
> > home-made
> > would like
> > thinking
> > > Thanks!
> > > Jonathan
> > > www.madlabs.info
and
A car oil preasure gauge would be to high preasure, but something along
those lines should work well, and be very easy to install and read in software.
-Kerry
At 12:09 AM 7/11/03 -0700, you wrote:
>Well, you know the depth and width of the tank - you could always try
>though.
Original Message
>From: "Tim Stockman, STOCKMAN ELECTRONICS"
><tim.stockman@s...>
>over
Original Message
>> > the outside.
>> > rondoc
>> > > Hi all,
>> > home-made
>> > would like
>> > thinking
>> > > Thanks!
>> > > Jonathan
>> > > www.madlabs.info
>and
-Yours with much regard
-Kerry
it to reflect the ultrasonic.
Original Message
From: pm [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=vHEszRgr9oIO7KpVM5Rh3PV0RhHvIvdTqm1A-eEs95TGxkgk4M6rv5wm8H-OcPS-XN5DrF6srRM]pmeloy@s...[/url
Sent: Friday, July 11, 2003 3:09 AM
To: basicstamps@yahoogroups.com
though.
Original Message
<tim.stockman@s...>
over
Original Message
> > the outside.
> > rondoc
> > > Hi all,
> > home-made
> > would like
> > thinking
> > > Thanks!
> > > Jonathan
> > > www.madlabs.info
and
Drat! Good point. So do you think IR or sonic is the way to go? IR would be
easier to protect from the enviroment, but will water reflect IR or absorb
it?
Jonathan
www.madlabs.info
Original Message
<tim.stockman@s...>
over
Original Message
> > the outside.
> > rondoc
> > > Hi all,
> > home-made
> > would like
> > thinking
> > > Thanks!
> > > Jonathan
> > > www.madlabs.info
and
enviroment. I'm not sure how I could prtect the sonic sensor from
condensation and moisture. I'll have to find out if water will reflect IR or
not, it would be easy to make IR waterproof.
Jonathan
www.madlabs.info
Original Message
Sent: Friday, July 11, 2003 12:09 AM
be
> though.
Original Message
> <tim.stockman@s...>
> over
Original Message
> > > the outside.
> > > rondoc
> > > > Hi all,
> > > home-made
> > > would like
> > > thinking
> > > > Thanks!
> > > > Jonathan
> > > > www.madlabs.info
> and
and
Good idea! I could do IR this way too, which would be easier to protect from
water.
Thanks!
Jonathan
www.madlabs.info
Original Message
Sent: Friday, July 11, 2003 7:12 AM
Subject: RE: [noparse][[/noparse]basicstamps] Re: Pressure sensor for water tank
> On item #2 if the tube is big enough why not float a ping pong ball and
use
Original Message
> From: pm [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Kk6xL-CXroIShMnOhKI3umd4G050deqbgm8dBQNNY1_cUnBR7bzz7Vo2OE65eoG5jEUVhkB-WQk]pmeloy@s...[/url
be
> though.
Original Message
> <tim.stockman@s...>
> over
Original Message
> > > the outside.
> > > rondoc
> > > > Hi all,
> > > home-made
> > > would like
> > > thinking
> > > > Thanks!
> > > > Jonathan
> > > > www.madlabs.info
> and
and
Original Message
Sent: Friday, July 11, 2003 10:19 AM
> Tim,
be
> it?
> Thanks,
> Jonathan
> www.madlabs.info
Original Message
> <tim.stockman@s...>
> over
Original Message
> > > the outside.
> > > rondoc
> > > > Hi all,
> > > home-made
> > > would like
> > > thinking
> > > > Thanks!
> > > > Jonathan
> > > > www.madlabs.info
> and
and
bottom of the board cut at an angle. the two end traces go to edge of pcb board
where they can be put in a circuit as a resistance. the higher the water, the
lower the resistance, etc.
bill hart
Jonathan Peakall <jpeakall@m...> wrote:
Sadler,
water.
Thanks!
Jonathan
www.madlabs.info
Original Message
To:
use
Original Message
> From: pm [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1NTm0DbiVvefjgceXPRmFcrlQXl43b8XG2JMsa_XqGu3EROMSHBlHUQiSXcnKqMurV8wtJDx]pmeloy@s...[/url
be
> though.
Original Message
> To:
> over
Original Message
> > From: "rondoc69"
> > To:
> > > the outside.
> > > rondoc
> > > amps@yahoogroups.com, "Jonathan Peakall" wrote:
> > > > Hi all,
> > > home-made
> > > would like
> > > thinking
> > > > Thanks!
> > > > Jonathan
> > > > www.madlabs.info
> and
and
from the same email address that you subscribed. Text in the Subject and Body of
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month!
When the water level gets low the ball no longer floats and pulls the switch.
That's how my high tech toilet knows when to stop filling....it's ran for years
without any complex electronics monitoring it's levels...[noparse]:)[/noparse]
Of course this only works if we are talking about an open tank. A pressurized
tank is another story [noparse]:)[/noparse]
>>> hellkat909@y... 07/11/03 09:56AM >>>
a pcb board with a series of traces close together, parallel, not connected. the
bill hart
Sadler,
water.
Thanks!
Jonathan
www.madlabs.info
