->Speech recognition?2
What would i need to write/do that would be able to understand what i
am saying if i use pbasic and the microcontroller with eeprom?
what would i need to do if i use a PIC?
and what would i need to do to understand the numbers that the phone
is dialing with pbasic?
p.s. thanks, these are all good thoughts, im sure im going to ask
more too. =-)
--- In basicstamps@yahoogroups.com, "George Bush" <capthoohoo@y...>
wrote:
> --- In basicstamps@yahoogroups.com, "Tim Hart" <tim.hart@h...>
wrote:
> > Thinking out loud here....
> > Motorola (or Nokia) phone with no service contract.....tell it to
> "call home"....have the stamp monitor the output of the phone as it
> dials. Then execute code based on the numbers it dialed.... Of
> course it won't cost anything for the phone to attempt a call
without
> a contract [noparse]:)[/noparse]
> > Sure beats reinventing the speech recognition wheel!!
> > Tim
> Tim - HA! I like it! Excellent suggestion for a work around!
> Dennis - if the A/D wouldn't be able to sample fast enough, we will
> have to speak vvvveeeerrryyy sssllloooowwllyyy to our Stamps! ;-)
> Neil
more too. =-)
without
> > Tim
> Neil
i
> more too. =-)
The first thing you do is decide what you need as specifically as
possible. Are you making "The Clapper" or are you trying to make
something that would emulate the functionality of the cell phone? I
would suggest starting with The Clapper. It would give you practice
with the elements you would need to move on to more complicated sould
recognition. The answer to all your questions is in the
specifications of what you need to build.
The three blocks I talked about before could be the basis of your
design for all of the cases you ask about above. 1) High speed A/D
(How fast, how much data?) 2) FFT function 3) known samples in memory
with a "best fit" comparison algorithm. In each of your cases these
blocks get implemented differently, but conceptually you need all
three. In Tim's phone suggestion you would be sampling phone tones
rather than the human voice.
Neil
FFT and a correlation algorithm will do the trick, but in real life
there are a lot of tricks required to make it all work -- especially
without training.
HOWEVER, there are several Ics that do this already to some degree.
Phillips makes the "Hello IC"
http://www.semiconductors.philips.com/news/content/file_690.html
http://www.sensoryinc.com/html/company/pr99_6.html
ftp://svr-ftp.eng.cam.ac.uk/pub/comp.speech/info/VoiceRecognitionProcess
ors
The OKI looks good as long as you can live with their standard words.
Look at the technology that goes into some of these and you'll see what
I mean.
I don't mean to be discouraging, but this would be a huge undertaking
even on a DSP or other high-performance chip.
Al Williams
AWC
* Analog/Digital I/O with VB, Excel, C++, Java, more...
http://www.al-williams.com/gp3.htm
Original Message
> From: virtualeast [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pfCouqeDOZgPYhLBSHdtMULB6BRm412ZHz1EBVvEybiaKstTAT6seiLwANDddono1ZYvLoYTRI-F]vea@v...[/url
> Sent: Wednesday, July 09, 2003 6:58 PM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] ->Speech recognition?2
> more too. =-)
> without
> > > Tim
> > Neil
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the
> Subject and Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
>I could have sworn I found a speaker-dependent
>speech module, which could be trained to recognize
>15 words, for around $100.00, and which would
>interface with a PIC, AVR, or Stamp.
This may be the unit to which you are making reference:
http://www.imagesco.com/catalog/hm2007/SpeechRecognitionKit.html
Bruce Bates
This approach is your only hope, as the Stamp
by itself does not have the speed or ram space
for voice recognition.
For the numbers -- there are several inexpensive
chips which understand DTMF, and there are
Nuts&Volts articles on the Parallax website
on this part.
i
phone
> more too. =-)
to
it
> without
> > > Tim
will
> > Neil
