Looping a program
I am a newbie so forgive. I am trying to loop through a stamp set of
instructions several times (to get triplicate readings). I am using
the FOR-NEXT code but am unable to program any loops that make
sense.The main body or the program works fine for my purposes.
Any hints would be appreciated.
Thanks Mike Z
'{$STAMP BS2}
Define variables, set status of pins
reps VAR WORD
x VAR WORD
y VAR WORD
z VAR WORD
cnt VAR WORD
cmt VAR WORD
clt VAR WORD
S0 CON 0
S1 CON 1
S2 CON 2
S3 CON 3
LED1 CON 11
LED2 CON 12
LOW S0 'Sets status of TSL230 pins
HIGH S1
HIGH S2
LOW S3
LOW 4 'Toggle state to enable/disable chip – change this if there is
no
'output from the TSL230
Main program loop
ROUTINE1
LOW LED1
PAUSE 2000
FOR x = 1 TO 2000
COUNT 5, 1, cnt 'Count on pin 5 for 1 ms, store value in cnt
DEBUG DEC cnt, CR 'Send value of cnt, as a decimal to the computer
NEXT 'Do it all over again, 2000 times
IF x=2000 THEN ROUTINE2
ROUTINE2:
PAUSE 2000
FOR y = 1 TO 2000
COUNT 6, 1, cmt 'Count on pin 6 for 1 ms, store value in cmt
DEBUG DEC cmt, CR 'Send value of cmt, as a decimal to the computer
IF y=2000 THEN ROUTINE3
ROUTINE3:
HIGH LED1
LOW LED2
PAUSE 2000
FOR z = 1 TO 2000
COUNT 7, 1, clt 'Count on pin 6 for 1 ms, store value in clt
DEBUG DEC clt, CR 'Send value of clt, as a decimal to the computer
HIGH LED2
IF z = 2000 THEN ROUTINE4
ROUTINE4
FOR reps = 1 TO 3
GOTO ROUTINE1
NEXT
END
Thanks Mike Z
'{$STAMP BS2}
reps VAR WORD
x VAR WORD
y VAR WORD
z VAR WORD
cnt VAR WORD
cmt VAR WORD
clt VAR WORD
S0 CON 0
S1 CON 1
S2 CON 2
S3 CON 3
LED1 CON 11
LED2 CON 12
HIGH S1
HIGH S2
LOW S3
no
Main program loop
ROUTINE1
LOW LED1
PAUSE 2000
FOR x = 1 TO 2000
ROUTINE2:
PAUSE 2000
FOR y = 1 TO 2000
ROUTINE3:
HIGH LED1
LOW LED2
PAUSE 2000
FOR z = 1 TO 2000
HIGH LED2
ROUTINE4
FOR reps = 1 TO 3
GOTO ROUTINE1
NEXT
END
many ways to construct a loop in BASIC.
1) To loop forever, use GOTO Label or DO-LOOP
Main:
' looped statements
GOTO Main
Main:
DO
' looped statements
LOOP
I tend to use GOTO when there are a lot of loop statements, DO-LOOP when
there are just a few.
2) To loop a specific number of times, use FOR-NEXT
Main:
FOR idx = 1 TO 5
' loop statements (that will run five times)
NEXT
3) To loop while some condition is true:
Main:
DO WHILE (condition)
' loop statements
LOOP
The loop statements will not run if the condition is false when the loop
is encountered.
4) To loop until a condition becomes true
Main:
DO
' loop statements
LOOP UNTIL (condition)
Since the test is at the end of the loop, the loop statements will run
at least one time using this construct.
Okay, by now your head is probably spinning. Take a deep breath, talk
through your program (out load -- this really helps), then loop through
the templates above to see what will work best. Make sure that you have
the latest BASIC Stamp compiler installed so you can consult the help
file for additional details.
Good luck and have fun.
-- Jon Williams
-- Parallax
Original Message
From: mziegler1485 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wh-Cwb1wasuLnWTxAw8s3jOZMWfxCjTABM-mV4KULA_vSga2kEbMiI6pDCMr7YxMnzO7FfqSsC32bUo]mziegler@h...[/url
Sent: Tuesday, July 08, 2003 10:12 AM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Looping a program
Thanks Mike Z
'{$STAMP BS2}
reps VAR WORD
x VAR WORD
y VAR WORD
z VAR WORD
cnt VAR WORD
cmt VAR WORD
clt VAR WORD
S0 CON 0
S1 CON 1
S2 CON 2
S3 CON 3
LED1 CON 11
LED2 CON 12
HIGH S1
HIGH S2
LOW S3
LOW 4 'Toggle state to enable/disable chip - change this if there is
no
Main program loop
ROUTINE1
LOW LED1
PAUSE 2000
FOR x = 1 TO 2000
COUNT 5, 1, cnt 'Count on pin 5 for 1 ms, store value in cnt DEBUG DEC
cnt, CR 'Send value of cnt, as a decimal to the computer NEXT 'Do it all
over again, 2000 times IF x=2000 THEN ROUTINE2
ROUTINE2:
PAUSE 2000
FOR y = 1 TO 2000
COUNT 6, 1, cmt 'Count on pin 6 for 1 ms, store value in cmt DEBUG DEC
cmt, CR 'Send value of cmt, as a decimal to the computer NEXT 'Do it all
over again, 2000 times IF y=2000 THEN ROUTINE3
ROUTINE3:
HIGH LED1
LOW LED2
PAUSE 2000
FOR z = 1 TO 2000
DEBUG DEC clt, CR 'Send value of clt, as a decimal to the computer NEXT
'Do it all over again, 2000 times HIGH LED2 IF z = 2000 THEN ROUTINE4
ROUTINE4
FOR reps = 1 TO 3
GOTO ROUTINE1
NEXT
END
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
'GOTO' is not a 'GOSUB'. Once you 'GOTO' someplace,
you don't return, so Routine4 will enter once and
then Jump to Routine1, never to return.
--- In basicstamps@yahoogroups.com, "mziegler1485" <mziegler@h...>
of
> Thanks Mike Z
> '{$STAMP BS2}
> reps VAR WORD
> x VAR WORD
> y VAR WORD
> z VAR WORD
> cnt VAR WORD
> cmt VAR WORD
> clt VAR WORD
> S0 CON 0
> S1 CON 1
> S2 CON 2
> S3 CON 3
> LED1 CON 11
> LED2 CON 12
> HIGH S1
> HIGH S2
> LOW S3
is
> no
Main program loop
> ROUTINE1
> LOW LED1
> PAUSE 2000
> FOR x = 1 TO 2000
> ROUTINE2:
> PAUSE 2000
> FOR y = 1 TO 2000
> ROUTINE3:
> HIGH LED1
> LOW LED2
> PAUSE 2000
> FOR z = 1 TO 2000
> HIGH LED2
> ROUTINE4
> FOR reps = 1 TO 3
> GOTO ROUTINE1
> NEXT
> END
FOR X = 1 TO 1000
' Do Stuff
NEXT
' Do More Stuff
It's good software practice not to depend on 'X'
having ANY particular value in the 'Do More Stuff'
part. However, if you decide to do so, it's value
is probably 1001 in this example, as the 'FOR'
loop won't terminate until 'X' is GREATER THAN
the last value.
In your code below, you check if it's EQUAL to
the last value -- which it won't be. This does
no harm in your code fragment, since the GOTO
and the 'fall-through' go to the same code.
but this could cause problems were that not
the case.
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
wrote:
> One problem: Routine4:
> of
using
> > Thanks Mike Z
> > '{$STAMP BS2}
> > reps VAR WORD
> > x VAR WORD
> > y VAR WORD
> > z VAR WORD
> > cnt VAR WORD
> > cmt VAR WORD
> > clt VAR WORD
> > S0 CON 0
> > S1 CON 1
> > S2 CON 2
> > S3 CON 3
> > LED1 CON 11
> > LED2 CON 12
> > HIGH S1
> > HIGH S2
> > LOW S3
> is
> > no
Main program loop
> > ROUTINE1
> > LOW LED1
> > PAUSE 2000
> > FOR x = 1 TO 2000
> > ROUTINE2:
> > PAUSE 2000
> > FOR y = 1 TO 2000
> > ROUTINE3:
> > HIGH LED1
> > LOW LED2
> > PAUSE 2000
> > FOR z = 1 TO 2000
> > HIGH LED2
> > ROUTINE4
> > FOR reps = 1 TO 3
> > GOTO ROUTINE1
> > NEXT
> > END
with a GoTo. First, use GOSUBs in the loop (with RETURNs in the
appropriate places at the routine end) and, second, place your RoutineX
stuff BELOW the main calling loop. you need to trace your code line by
line to see the error of your ways.
PS-We ALL start by making spaghetti code, but it's a good habit to
break. You might look at the BLOCK IF in BS2.5 to help you.
> Thanks Mike Z
> '{$STAMP BS2}
> reps VAR WORD
> x VAR WORD
> y VAR WORD
> z VAR WORD
> cnt VAR WORD
> cmt VAR WORD
> clt VAR WORD
> S0 CON 0
> S1 CON 1
> S2 CON 2
> S3 CON 3
> LED1 CON 11
> LED2 CON 12
> HIGH S1
> HIGH S2
> LOW S3
> no
Main program loop
> ROUTINE1
> LOW LED1
> PAUSE 2000
> FOR x = 1 TO 2000
> ROUTINE2:
> PAUSE 2000
> FOR y = 1 TO 2000
> ROUTINE3:
> HIGH LED1
> LOW LED2
> PAUSE 2000
> FOR z = 1 TO 2000
> HIGH LED2
> ROUTINE4
> FOR reps = 1 TO 3
> GOTO ROUTINE1
> NEXT
> END
the simplest if not most elegant solution which was to include the
whole program in a FOR-NEXT sequence with minor alterations.
Mike Z
ROUTINE3 three times, the simplest way to do this would look like
this:
FOR reps = 1 to 3
LOW LED1
PAUSE 2000
FOR x = 1 TO 2000
PAUSE 2000
FOR y = 1 TO 2000
HIGH LED1
LOW LED2
PAUSE 2000
FOR z = 1 TO 2000
HIGH LED2
NEXT 'do this three times
END
When you exit a FOR NEXT loop, the variable should be one greater
than the loop. For example at the bottom of ROUTINE1 where the IF
statement is, x will be 2001. The IF statement is not needed because
the program will execute the next line anyway.
The comments you added in this program are helpful. You may also find
it helpful to indent any code in a loop or an if statement to make it
easier to see what is supposed to happen where. This is especially
true if you have loops inside of loops.
FOR x = 1 to 4
FOR y = 1 to 8
do some stuff here 'this stuff gets done 32 times
FOR z = 1 to 10
do some other stuff here 'this stuff gets done 320 times
NEXT 'this NEXT lines up with FOR z so you can see it
NEXT 'this NEXT lines up with FOR y
NEXT 'this NEXT lines up with FOR x
In a longer program with more code it is easy to miss a NEXT or some
other end of condition statement. I hope this helps.
Paul Caesar
of
> Thanks Mike Z
> '{$STAMP BS2}
> reps VAR WORD
> x VAR WORD
> y VAR WORD
> z VAR WORD
> cnt VAR WORD
> cmt VAR WORD
> clt VAR WORD
> S0 CON 0
> S1 CON 1
> S2 CON 2
> S3 CON 3
> LED1 CON 11
> LED2 CON 12
> HIGH S1
> HIGH S2
> LOW S3
is
> no
Main program loop
> ROUTINE1
> LOW LED1
> PAUSE 2000
> FOR x = 1 TO 2000
> ROUTINE2:
> PAUSE 2000
> FOR y = 1 TO 2000
> ROUTINE3:
> HIGH LED1
> LOW LED2
> PAUSE 2000
> FOR z = 1 TO 2000
> HIGH LED2
> ROUTINE4
> FOR reps = 1 TO 3
> GOTO ROUTINE1
> NEXT
> END
