Syntax help with IN
Suppose I have a BS2 pin 10 connected to an input switch.
e.g. SW1 CON 10
Later, I want to read pin 10's state. I've been using statement like
IF IN10=1 THEN Label1
But this is not "elegant" if I have many input switches, and not very
legible.
Is there a way to check for input by using name of the pin (SW1) in
this case?
e.g. SW1 CON 10
legible.
this case?
but I'm sure Jon will chime in). With the current software, try this:
SW1 CON 10
SW1p VAR IN10
IF SW1p = 1 then Label1
Al Williams
AWC
* New Kits:
http://www.al-williams.com/kits.htm
Original Message
> From: basicstampede [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Y8EpDkjsQKNPgN-4hg68djVkv_yFNeYM0b5TNuHsmXkQMNIIS4vytfSvaFVzdaLW6KJ1-X262l-OSYjjgA]basicstampede@y...[/url
> Sent: Monday, July 07, 2003 6:59 AM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] Syntax help with IN
> Suppose I have a BS2 pin 10 connected to an input switch. e.g. SW1 CON
> 10
> legible.
> this case?
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the
> Subject and Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
with the PIN defintion and a couple of constants. Like this:
StartSw PIN 10
IsOn CON 1
IsOff CON 0
IF (StartSw = IsOn) THEN Label1 ' is the same as IF
(IN10 = 1) THEN Label1
I'm a very big fan of "elegant" programs. So much so that I put
together a document we use interally called "The Elements of PBASIC
Style." If you have the newest compiler, you'll find the document in
the Help file, otherwise you can download the PDF from this link:
http://www.parallax.com/html_pages/downloads/basicstamps/documentation_b
asic_stamp.asp
Just a note about the PIN defintion. The compiler is smart enough to
know what you're doing with a pin and will accordingly. If, for
example, we also had an LED we could do this:
RunLED PIN 8
Since outputs need to have their DIRS bit set too, the easiest way to
initialize the LED off is by doing this:
Init:
LOW RunLED ' same as LOW 8
If you want to initialize the LED as on, use HIGH instead. Now the LED
can be controlled with the previously-defined constants:
RunLED = IsOn ' same as OUT8 = 1
or...
RunLED = IsOff ' same as OUT8 =
0
-- Jon Williams
-- Parallax
Original Message
From: basicstampede [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=kyVARWEPVrGX-inhh8eGvdPF3uhwlWtEW4qD61PZahIJkZLqQvla9iGUD26ZAkBam6BhZwD2NiIexOpPSBYR8A]basicstampede@y...[/url
e.g. SW1 CON 10
legible.
this case?
from the same email address that you subscribed. Text in the Subject
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
explanation.
When you say "SW1_in VAR IN10", you are not
'really' declaring a variable, you are declaring
an 'alias' for IN10. It doesn't take 'ram'
space, it's a signal for the compiler.
You can now read the state of the pin
(assuming you did INPUT SW1 at some point)
with: MyVal = SW1_in, or IF SW1_in = 1 THEN...
You can also have an "SW1_out VAR OUT10" so
that you can write the state of the pin with
"SW1_out = 1", or "SW1_out = 0". Again, this
assumes you've done an OUTPUT SW1 at some
point.
The 'new' compiler (2.5) lets you declare
SW1 PIN 10. Now, the compiler will let you
do MyVal = SW1, or SW1 = MyVal, and both
will work.
--- In basicstamps@yahoogroups.com, "Al Williams" <alw@a...> wrote:
> I know the new software has a clean way to handle this (PIN, I
think,
this:
> SW1 CON 10
> SW1p VAR IN10
> Al Williams
> AWC
> * New Kits:
Original Message
> > From: basicstampede [noparse][[/noparse]mailto:basicstampede@y...]
SW1 CON
> > 10
like
very
> > legible.
in
> > this case?
